M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > 11" rear wheels Possible? Drag Set up
      02-05-2021, 05:11 PM   #1
GFEA
@333m2c
GFEA's Avatar
Drives: 2020 M2c f87 S55
to my knowledge the biggest I can go is a 10.5 wheel on the rear of a 2020 m2c.
Hypothetically, I'm wondering if I'm wrong and seeing if anyone knows if 11" rear wheels would work on the back for a set of drag racing tires for shift sector.
not exactly worried about anything but straight line performance for this scenario so logic tells me if I put big enough spacers on I should be able to make them fit.
Stock calibers and Mcs coilovers.
If this has been answered elsewhere sorry to kick a dead horse.
@333m2c / Willing to sell my soul for parts..
Build thread: "Going for Broke - a Saga"
https://f87.bimmerpost.com/forums/sh....php?t=1805010
      02-07-2021, 10:18 AM   #2
Rumbloki
Rumbloki's Avatar
Drives: Faster than most
I would look for the correct offset and avoid spacers on a car that is launching hard on sticky tires.
      02-07-2021, 10:39 AM   #3
Rumbloki
Rumbloki's Avatar
Something else to consider is going with an 18 or even a 17 inch wheel for more sidewall. A 10" wide wheel works fine for a 305 tire.
https://photos.app.goo.gl/syGDv3hhbSAorukh7
GFEA228.50
      02-07-2021, 10:52 AM   #4
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
An 11" rear is absolutely possible, but it'll take some tweaking.
- the suspension you have will probably need to be changed to allow more room
- the exact offset will need to be perfect for your suspension choice
- the suspension and exact camber you choose will depend on the tire you choose
- the ride height will have to be catered towards the tire/wheel/offset/suspension
HOWEVER
If you're drag racing regularly you should know that the .5" isn't going to make nearly as much difference as the proper tire and pressure.
Lastly, I've seen a 19 x 11 +43 shod with a 305/30 fit nicely on a standard M2 without much fuss, just camber and height adjustment (and a specific tire was chosen as well), so an M2C fitment isn't that far off, maybe 5mm.
To me, this is mostly about the suspension.
If you choose a very thin suspension you could probably fit a 19 x 11 +48 with a sticky 305.
GFEA228.50
cotmfk2049.50
      02-08-2021, 11:32 AM   #5
GFEA
@333m2c
GFEA's Avatar
Thank you for this! the more I thought about it this weekend the solution seems to just bump the rear 295 to a stickier 305.
      02-08-2021, 11:33 AM   #6
GFEA
@333m2c
GFEA's Avatar
HOWEVER
Thank you! I don't drag race often at all but my friends really into it so I'm doing a few events with him this year, because, why not.
VisualEcho6636.50
      02-08-2021, 12:21 PM   #7
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
Drag racing can be quite frustrating in an M2, as the car isn't made for it at all, but it can be fun. I'm not a drag racer whatsoever, but back when I had my '05 STi I broke a lot of hearts, and that was quite fun, even addictive.
      02-08-2021, 12:32 PM   #8
SEAT TIME RULES
SEAT TIME RULES's Avatar
1103
2020 BMW M2C  [5.00]
Iv'e been looking to run the widest possible rim in the rear of our cars,
I traded some emails with Apex regarding this..
In my case I've decided to get a pair of 18x11's from them and work a set of 305/35's onto the rear. Probably the Toyo RR's 275/35F. 305/35 R
Tom Maloney (APEX Race Parts)
Dec 30, 2020, 2:36 PM PST
Thanks for clarifying that! The most ideal option in terms of rear-wheel fitment for an M2C would be our 19x10.5 ET45 EC-7 wheels. They are made specifically for the M2 rear offset and will be a direct fit for your M2 with 295/30-19 or 285/30-19 tires. The 19x11 ET44s may work for the rear of your M2, but we have not tested them with a 305/30-19 tire so we can't guarantee fitment.
I have had a customer run our 18x11 ET44 wheels on the rear of his M2C with 305/35-18 tires. He said it fit without rubbing, but I believe he was running additional negative camber in the rear which helped. You can view images of that car here:
https://flic.kr/p/2k1s7Rv
https://flic.kr/p/2k1vRYe
If you are looking for a guaranteed fit, I would recommend the 19x10.5 ET45s. If you are willing to experiment, the 11 inch wide ET44 wheels may work, but we can't guarantee fitment. If you'd like to take a look at the setups we recommend, check out our fitment guide: https://support.apexraceparts.com/hc...-Fitment-Guide
Thanks again,
Tom Maloney - BMW Product Expert
APEX Race Parts
I had sent this to him:
I have a set of your 18x10 ET 33 SM-10's in Anthracite.
I'm looking to run the NT01's in the 305/35 for the rears and the 40 offset of your 10.5 " rims will help negate the wider tires.
On my current setup I have 295/35 Yoko A052's in the rear. These will make contact under full compression.
It looks like you have some 19x11's with a ET44 for sale.
I could run them with the 305/30's.
Current Yoko specs 18x10 Et33 with 26.2 Diameter & 11.8 Sec width
With your 19x10's ET 44 and 305/30 NT-01's: 26.26 diameter & 12.32 sec width.
So Diameter is fine, There's a .43" offset difference to help negate the 0.52" width increase.
So I need to make room for 0.09".
This sounds like it will work with some serious, careful fender rolling.
I also have some camber shims I can use to get more than 2.0 Neg in the rear.
Thoughts guys?
2004 Mazda Rev It Up Finalist
2002-Present HPDE Instructor
GFEA228.50
      02-08-2021, 08:34 PM   #9
Karmic Man
Karmic Man's Avatar
1996
Drives: M2C
You can go 305 on a 10.5, why go through all this pain to shove a 11 at the rear? Unless you go 315 but 315 on a 11 won't fit the M2 chassis anyway
Tyre compound is more important than the extra 0.5 wheel width for drag racing
GFEA228.50
      02-09-2021, 11:13 AM   #10
GFEA
@333m2c
GFEA's Avatar
Yeah that's the route to go here the more I weighed out the options. 305 on the rear should do it.
      02-14-2021, 10:43 PM   #11
GFEA
@333m2c
GFEA's Avatar
Thanks again,
APEX Race Parts
Thoughts guys?
Thanks again,
APEX Race Parts
Thoughts guys?
Did you make this work?
I think I'm gonna try to fit 305/35r19 nito nto5r on the back for shift sector
      03-25-2021, 01:37 AM   #12
M2_MEDUSA
M2_MEDUSA's Avatar
Drives: 2021 M2 Comp. SpecialEdition
So 255/30/19 on 9.5” and 285/30/19 on 10.5” is the best in terms of fitment correct? What should be my ET for something as close to flush without rubbing
      03-25-2021, 02:16 AM   #13
GFEA
@333m2c
GFEA's Avatar
With a whole lot of camber I have 265/30/19 and 295/30/19 on the titan 7 m2 fitment. I have suspension and the cars slightly lowered as well
      03-25-2021, 09:25 AM   #14
M2C_OZ
M2C_OZ's Avatar
Drives: 2020 M2 Competition
I have them on
18x11 305/35/18 no tweaking needed
Appreciate 4
Rundskop148.00
GFEA228.50
///MPhatic13862.50
      03-30-2021, 01:31 PM   #15
///MPhatic
The Seeker
///MPhatic's Avatar
13863
Drives: OG M2 • Exige
Originally Posted by M2C_OZ View Post
I have them on
18's don't fit the same as 19's. That same combo in 305/30/19 could easily rub (depending on your offset, drop, suspension, etc).
