12-07-2018, 03:02 PM | #177 | |
Plenipotentiary
2614
Rep 3,046
Do you see the difference between these two frames from that vid? The Y axis zero point is the center of the lane of travel. This is before any mechanical movement occurs. |
12-07-2018, 03:29 PM | #178 |
Rep 55
Okay, very interesting.
Scrubbed back through the transitions into a tunnel and you’re right, there is definitely a change in the cone of light at that moment, just before the projectors move. Hmmmmmmm. |
12-07-2018, 10:14 PM | #179 | |
Rep 1,758
2016 428ix, r, 2018 430iC, 2018 330it
12-07-2018, 11:31 PM | #180 |
Rep 4,551
Drives: 2015 328d xDrive
Not sure. My guess is that It could also be activated by turning on your rear fogs (if you have them) or perhaps it just simply isn't an option present in cars without front fogs.
12-10-2018, 07:15 PM | #181 |
Rep 1,758
I just coded this on in my car today. Won't be driving at night until Wednesday night most likely. I was able to tell a vast difference in how much more the lights move left-right on the garage wall though.
12-10-2018, 09:39 PM | #182 |
Rep 8,364
12-13-2018, 09:38 PM | #183 |
Rep 55
Maybe old news, but did anyone see that this is going on?
https://www.autoblog.com/2018/10/11/...lights-safety/ They were accepting comments on the proposal until 12/10, which you can read at this link if you're curious: https://www.regulations.gov/docket?D=NHTSA-2018-0090 Oddly, it seems like there is some sort of misinformed campaign out there from drive-in movie theater owners who think this tech will mean people can't turn their headlights off to go to a movie...??? But there's also some good stuff on there if you dig, such as comments from Mercedes-Benz, AAA, Ford, etc. I'm sure it's still a ways off, but looks like they are at least making progress! |
12-14-2018, 02:43 AM | #184 | |
Rep 6,637
12-14-2018, 05:58 PM | #185 | |||
Plenipotentiary
2614
Rep 3,046
- Stadt_V_Idx - VLD City Beam Pattern (Not Present on F87) - SAE_Idx - Speed Condition Activation Motorway Beam in conjunction with timer (Not Present on F87) - H_plus4_Idx - Motorway Beam +40km/h not in conjunction with timer (not present on F87) - Blendfreies_Fernlicht_Idx - Glare-Free High Beam (Not present on F87) - Volles_Fernlicht_Lichthupe_Idx - Full High Beam (Not Present on F87) |
01-02-2019, 04:42 PM | #186 | |
Rep 51
M2C Adaptive Full LED Lights partially enabled in USA (Only auto high beams)?
Hi,
I have been reading about the Adaptive Full LED Lights... and in bmw website it only mentions: Quote:
UK video: So... only high beams are enabled in the US even with Executive package? I have been doing some test, and I don't see anything changing when I'm driving in the freeway. Last edited by obazavil; 01-03-2019 at 07:27 PM.. |
01-02-2019, 05:11 PM | #187 |
Rep 442
In my M235i I had to push a button on the end of the turn signal stalk for the automatic high beams to work...every time I drove the car at night. Kinda annoying. In my Honda the automatic high beams work every time without having to push any buttons.
01-02-2019, 05:12 PM | #188 | |
Rep 845
Instagram: @Project_F87
BlkSVT388.50 |
01-02-2019, 05:17 PM | #189 |
Rep 845
https://f87.bimmerpost.com/forums/sh....php?t=1459620
LOT of info in here, I'm still searching for the dedicated thread that has the steps of how to code it using the bimmercode app. I'll post it in here once I find it
obazavil45.00 |
01-02-2019, 05:19 PM | #190 | |
Rep 51
I will buy the app and adapter then . |
01-02-2019, 05:19 PM | #191 | |
Rep 3,077
Was gonna post this same thread Andrew put tons together. I did not know all that VLD did, someone on IG pointed it out and searching I found your topic. Thanks for detailing specifics of what it does and how to code in Expert Mode. Doing it this weekend!
Follow me on IG
AndrewC198910931.00 |
01-02-2019, 05:21 PM | #192 |
Rep 845
Bimmercode for VLD:
***Front Electronic Module*** In Expert Mode: C_AFS_ENA (3073) uncheck the two lines that contain "disable", and checked the the two lines that contain "enable". LUT_FLC_FORWARDLIGHTING_Y (3073) Uncheck the two lines that contain 0xB0, and checked the two lines that contain 0x9C three times. Complete the coding before exiting "expert mode." Done.
01-02-2019, 08:38 PM | #194 | |
Rep 1,015
Drives: Porsche GTS 4.0
01-02-2019, 09:31 PM | #195 | |
Luxury at the redline :)
9105
Rep 7,563
It does work for the Pre-LCI Xenon only. The US version of the LED headlights does not have the proper hardware to properly operate the VLD and GFHB feature, even with the appropiate coding paramaters. The US headlight part numbers are different from the RoW that have these features standard. I first belived the US headlights was capable of being able to code these features, until I verified this fact with a reputable source that It won't work as designed. Good news is the US DOT just finally approved VLD and GFHB for 2021 MY and beyond. So future models will have the same headlight hardware as the rest of world and these features standard. https://www.bimmerpost.com/forums/sh...php?p=22685958 |
4
01-03-2019, 04:27 PM | #198 | |
Rep 51
It was explained by andrewc89 in this post:
