11-14-2017, 03:48 AM | #1365 |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
I don't know that you'd want to restore a backup from one car to another; who knows what car-specific stuff (map licensing? I dunno) is stored in those that is not going to work when you try to put it into a different car...
11-14-2017, 09:11 AM | #1366 |
Rep 1,466
I've been talking with the BimmerCode developer overnight, and after looking at some logs from his app, he's saying that the issue is caused by the fact that my Vgate dongle, even though the correct version, is communicating too slow. This is causing the car ECU to time out if the coding command doesn't finish in a reasonable time.
This would explain a lot... Why my first attempt at coding failed and left me with no navigation, and why my backups won't restore correctly. I'm not asking for a Bimmercode backup, in looking for a backup of the original ncd data from FEM and HU taken with E-SYS. I can use the compare tool to see what differences there are before flashing. I most likely wouldn't flash someone else's ncd, I just want to know what the default factory coding was for those two ECUs because I cannot use Bimmercode to get me back there, even though I have my own backups.
2018 ///M2 LCI, LBB, 6MT...
11-14-2017, 01:06 PM | #1367 | |
Rep 8,364
E-sys Coding-Verification can create Factory NCD's to compare. |
11-14-2017, 01:20 PM | #1368 | |
Rep 1,466
I did try using NCD compare to compare some NCD files to what it believes are defaults, and there were a lot of differences highlighted there which weren't correct. Is NCD compare using a different method to determine 'default' values? HU ECU has lots of important values for maps, Bluetooth etc that NCD said was different from default in my NCD, but I'd not changed any of those values. I'm nervous to blast a default file with E-SYS if it's going to set the wrong set of defaults, though I do have a backup I suppose.
11-14-2017, 01:29 PM | #1369 | |
Rep 8,364
NCD Compare is accurate, but only if using side-by-side. Default = Uncoded state. Factory = applying values based on VO. |
11-14-2017, 02:33 PM | #1370 | |
Rep 6,635
I wonder if that's an issue with the car, the Vgate, or the ipad/iphone you are using. Most people I don't think are seeing this issue so there must be something up with one of those elements. Do you have a spare iphone/ipad to try? Order another vGate? |
11-14-2017, 03:54 PM | #1371 | |
Rep 1,466
The vGate uses CAN bus rather than ENET to communicate, which is inherently slower. I don't blame Bimmercode anymore, but if I'm having these problems, others could too, and it could be pretty serious. If I didn't have E-SYS ready last night, I may not have been able to drive this morning... That level of seriousness is worrying that it's even possible, even if unlikely.
11-14-2017, 04:06 PM | #1372 |
Rep 87
FYI, my Vgate (from Amazon by ediag Tools) had the connection dropping issue. It kept losing connection while reading the code. So, I had it replaced and the second one have no issues.
11-14-2017, 04:10 PM | #1373 |
Rep 1,466
Haha, mine came from ediag Tools as well! Mine isn't dropping connection, it's just really slow, and times out a lot. Both reading and writing.... It's annoying, hopeful they'll replace it, but I've had it for over a month because my car was delayed in arriving, and it took a while to find out what was wrong.
11-14-2017, 05:00 PM | #1374 | |
Rep 4,551
Drives: 2015 328d xDrive
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
NYC Bimmer259.50 |
11-14-2017, 05:03 PM | #1375 | |
Rep 1,466
Edit: wow, auto correct did a number on that post initially! Last edited by Nezil; 11-14-2017 at 08:34 PM.. |
11-15-2017, 11:05 AM | #1377 | |
Rep 1,466
I'm actually not a fan of cheat sheets either, except from the point of view of using them as a reference to know what to code, again, because I want to know what I've done. With E-SYS, I was able to recover a big issue created by the ECU timing out when I was using BimmerCode... BimmerCode may not have been able to solve this at all, but for E-SYS, it was a 30 second job. ENET also seems a somewhat more reliable interface than a mobile WiFi connection to a cheap WiFi bridge to a CAN bus. In any case, I have a replacement VGate iCar2 WiFi coming my way, and I'll see if that solves the speed issues. I'm still going to be sticking with E-SYS I think, but it's nice to have an alternative that's with me at all times on my phone, and of course the iCar2 can be used for things other than BimmerCode.
11-19-2017, 12:17 PM | #1378 |
Rep 114
11-20-2017, 12:17 AM | #1379 |
I INDIC8
612
Rep 1,286
Ironically, I was considering sticking a wifi AP in the car and using it in client mode to attach the car to my home wifi. Then I could code from inside the house (my garage isn't heated)...
Although I'd still have to go out there to put the key in the car and put it into run/accessory mode and slap a charger on it (just in case).
11-20-2017, 12:55 AM | #1380 | |
Rep 1,466
If you really wanted to code remotely, I'd set up a laptop with E-SYS and RDP to it from inside. That way the connection to the car is still wired, and the only think that is wireless is your link to Windows, which is totally safe.
11-20-2017, 03:20 PM | #1381 | |
I INDIC8
612
Rep 1,286
11-22-2017, 08:44 AM | #1382 | |
Rep 63
Was interested in increasing brightness but not sure if that works with the new versions.u |
11-22-2017, 03:33 PM | #1383 | ||
Rep 2,948
11-22-2017, 07:44 PM | #1384 | |||
Rep 63
I thought I read somewhere these only had one brightness level. |
11-23-2017, 05:42 PM | #1385 | |
Rep 399
Drives: 2017 BMW M2 6MT
Yes they can be coded to 100% brightness with the headlights on.
'17 BMW M2 LBB 6MT MPE
'13 BMW 335i Estoril Blue - sold |
