01-14-2019, 10:35 AM | #1 |
Rep 153
Volk TE37 18x10 +25 Square setup fitment question
Hello All,
(Yes i searched and no it's not easy to search for wheel sizes given the way people type them out and the content is indexed ) Does anyone know if this will work, or perhaps even run this wheel size as a SQUARE setup? I've got a set of TE37SL's accessible to me for track use and would like to know if this (mostly the offset) is an acceptable option. Thanks! |
01-14-2019, 10:47 AM | #2 |
Rep 2,526
Those are going to stick out well past the fenders.
Assuming you go with 275x35r18 tires, you're looking at the following differences from stock FRONT: - Suspension clearance: 11 mm (0.4'') closer to suspension/brakes components. - Fender Clearance: Will stick out 19 mm (0.7'') farther. REAR: - Suspension clearance: 100% clear (leaves even more room than OEM) - Fender Clearance: Will stick out 20 mm (0.8'') farther. Source: http://www.rimsntires.com/specspro.jsp |
atc556.50 |
01-14-2019, 10:51 AM | #3 | |
Rep 153
01-14-2019, 11:20 AM | #4 |
Rep 3,714
It will fit just fine at stock height with a little camber. I ran 18x10 EC7 +25 with 275 and 285 tires.
https://f87.bimmerpost.com/forums/sh....php?t=1370889 |
atc556.50 |
01-14-2019, 11:31 AM | #5 | |
Rep 2,526
Yeah, if looks like if you're lowered at all, you're going to run into some issues with that aggressive offset. |
01-14-2019, 11:33 AM | #6 | |
Rep 3,714
I had -2.5 camber in the front. |
atc556.50 |
