11-27-2018, 05:55 PM | #23 |
Rep 69
I will probably down to 2.6 in the back. But I am reluctant to go 2.5 all around. In the past, with my M135i I had perfect grip at the "lowest recommended"... but I killed the sides of the tyres so quickly...
11-27-2018, 06:05 PM | #24 |
Luxury at the redline :)
9103
Rep 7,563
Winter tires have a softer compound than MPPS summer tires..
With winter tires, I immediate lost that quick steering feedback and the DSC light flashes more often than before but I did gain a more comfortable ride and the assurance that I won't spin out in freezing temperatures.. Nothing is wrong with your vehicle, it's just the nature of the tires.. That said, I can't wait until springtime so I could get rid of them and regain that control I lost.. |
11-27-2018, 06:11 PM | #25 |
Rep 468
Don't mean to hijack the thread.. but do your M2's feel 'slower' once you put on your winters? I don't mean cornering ability (which is obviously hugely affected and to be expected)... I mean just general driving the car feels slower when I step on it and I was wondering if it's the different rubber...
11-28-2018, 05:42 AM | #26 | |
Rep 3,283
But, I could be wrong. I've been driving more cautiously since putting these. |
11-28-2018, 06:31 AM | #27 |
Rep 3,968
Wider tires are not better if you get ice on those rainy 30 degree days.
https://blog.tirerack.com/blog/hunte...ter-for-winter
11-28-2018, 10:33 AM | #28 |
Rep 8,972
It's to be expected on winters. Softer tread blocks, less lateral grip etc.
There is always a compromise to be made in these things. My old tuned 335i was a hoot on winters, yes a bit slidey and soft but very controllable at and beyond the limit of grip. Lots of TC light flashing. And if you did slide, the way it regained grip was tremendous even on ice and water. On summers when you slide it just floats on the water layer and you're off into the nearest ditch.. Enjoy the winters for what they are and relish spring time when it comes... |
11-28-2018, 03:24 PM | #29 | |
Rep 5,874
11-28-2018, 03:50 PM | #30 |
Rep 8,972
It's more to do with tyre ground pressure.
Narrower tyre's exert a higher pressure on the ground for a given vehicle weight, this will help expel the water layer that forms between tyre and ice and promote a more complete contact patch giving better traction in those conditions. A narrower winter tyre will also use the higher pressure to "dig in" to pack snow and ice and get better traction below the icey top layer that way. Whereas a wider tyre will spin on top of the snow. A wider tyre is more likely to ride up on top of any water layer loosing grip. But then a wider tyre has more grip when it has good direct contact with tarmac with a little snow / ice. So in different situations either can be better.. If you have varied snow / ice / wet tarmac / mild temp's then there will always be a compromise to make. Last edited by doughboy; 11-28-2018 at 03:56 PM.. |
Transfer5250.00 |
11-28-2018, 04:32 PM | #31 | |
Rep 3,968
"Another way to think about this is from the perspective of the contact patch. A tire's contact patch or "footprint" greatly influences its performance. On the same vehicle, the area of the contact patch essentially remains the same with different width tires. When the footprint gets narrower as it will with a narrower width tire, it has to get longer. And the mechanics of the longer footprint help with the longitudinal traction for acceleration and braking. " From here https://blog.tirerack.com/blog/hunte...ter-for-winter
11-29-2018, 06:06 AM | #32 |
Rep 7,294
BMWs winter setup is a little stupid. Using 4 front 437 or 788M with 245 all around or 245/255 is closer to original diameter and better. The front wheels fit perfectly as rears and are only 2mm more recessed.
I question the need to go to 235s while running performance winter tires. IMO if you really need good snow performance you’re going to want a real winter tire like the Xi3. The performance winters won’t kill you, but are closer to an all season then a Blizzak WS80 or Michelin Xi3 Type tire. |
12-01-2018, 08:00 AM | #33 |
Rep 3,283
My drive home from work yesterday afternoon warranted an update to this thread:
The weather in Portland has been pretty weird (even for weird Portland), but the sky decided to dump the day's worth of rain on me during my 25 minute drive home yesterday, with temps between 39 and 41 degrees during the drive. My tires have about 350 miles on them now, so they're broken-in or close to it. Short answer: These tires are fantastic in heavy rain on a cool but not frozen afternoon. I hit one really impressive puddle that caused the newer RAV-4 in front of me to skitter about and my car barely flinched. I was driving carefully, of course, but not overly slowly. I'm deeply pleased. Temps are going down this week, with a possibility of some snow next Saturday, so I should get a better idea how the car and the Alpin's handle winter-ish weather. |
12-03-2018, 10:52 AM | #34 |
Rep 1,092
I'm gonna hijack the thread a bit.
I put square winter setup on (18x9 with 245/40/18 Blizzak WS80). The front felt really twitchy and light but got better as the tires were scrubbed a bit. I don't mind the more tail happy nature of the square setup but I'm experiencing really weird problems with traction in straight line. In lower gears I can hook up with just minimal wheel spin and TC interference. But when I'm cruising in 6th gear at 2500RPMs and floor it the car refuses to accelerate. TC kicks in and I'm not going anywhere (mostly dry road, above freezing temps). Is anyone else experiencing the same thing? Could it be some DTC confusion from the square setup? The stock staggered setup has noticeably larger rolling diameter for the rear tires so the rear wheel actually spins a bit slower than the front. With square setup the rears rotate as fast as the fronts so the DTC could see it as wheel spin. I didn't expect such drastic change in grip. |
12-03-2018, 11:02 AM | #35 | |
Rep 1,237
Drives: M2 Competition
Check your tyre pressure
12-03-2018, 12:04 PM | #37 |
Rep 1,237
Weird. Your description matches exactly what i had as well.
12-03-2018, 12:11 PM | #38 |
Rep 1,092
12-03-2018, 12:14 PM | #39 |
Rep 1,237
No extra thread but mentioned it here and there.
Can you manually check pressure to be 100% sure?
12-03-2018, 12:48 PM | #40 |
Rep 3,968
I had something similar recently but it was while the TPMS was resetting. So maybe check
Pressures and do a TPMS reset. I also agree, the different sizes bmw allows are crazy in terms of diameter changes. |
12-04-2018, 05:18 AM | #41 | |
Rep 142
I do need to point out that I got this wheel setup from new and the TPMS immediately threw a warning. Took it to a gas station to check tire pressure and they were on 3.2 Bar around. The pressure chart in the door says I need to be on 2.1 and 2.2 Bar. Picture for attention: IMG_7977 by Chasing Dreams, on Flickr |
01-18-2019, 11:32 AM | #42 | |
Rep 1,092
Bringing the pressure down to what it should be solved a lot of issues I had with my winter setup (high speed stability, low speed grip, twitchy steering). Strange thing is that I used the same faulty tire gauge on my summer tires and they handled the extra pressure without too many problems. |
///M Houbi1653.00 |
01-18-2019, 11:36 AM | #43 |
Rep 4,253
There is a reason that the official package offered by BMW is staggered. I don't know why people buy an expensive M2 and then cheap out by getting a square setup for rotating.
https://www.shopbmwusa.com/Product/6...L-AND-TIRE-SET https://www.shopbmwusa.com/PRODUCT/6...EL----TIRE-SET https://www.shopbmwusa.com/PRODUCT/6...EL----TIRE-SET (note the 235 rear is a typo, it's 255 congruent with the 9" rear) Like in warm weather even the non comp M2 struggles on 265 rears. A 235 rear winter tire seems basically insane IMO for dry cold weather driving. Plus it looks ridiculous unless you run spacers. And running spacers isn't that desirable in crap conditions.
///M Power
01-18-2019, 12:04 PM | #44 | ||
Rep 1,237
I'm still amazed by the difference setting the correct pressure made...
