11-25-2018, 08:10 AM | #1 |
Rep 3,287
Massive cornering stability change with the BMW-recommended 641 Winter Wheels/Tires
I'm having some fun with this but thought it was worth mentioning, especially for any folk who haven't spent a lot of time driving rear-wheel drive cars (I nearly consider myself in this category due to how long it's been since I spent a lot of time behind the wheel of a RWD car...though it's all coming back to me pretty fast).
For my winter set, I went with BMW's recommendation and bought the 641 set with 235 Michelin Alpin's pre-mounted. I put them on the car last Wednesday. Putting the front wheels on took a bit of faith since they honestly didn't look like they were going to fit over the calipers. They did, though I'm slightly terrified of a tiny pebble getting stuck between the wheel and the caliper...there is very little space. To the point: Straight-line traction is just fine so far, but the difference in corners and on long curves is massive. Tripping the traction control on a corner is insanely easy, even at moderate throttle. Between my near-rural suburb and the larger suburb that has more stuff is a road with some very long curved sections of relatively new asphalt, one tighter and one wider. I've driven that route 4 times since Wednesday, twice in each direction and the car's desire to oversteer is much more pronounced. Overall, lateral grip is heavily compromised, more so than I was expecting. A couple of caveats: The tires aren't broken in yet, and it's a bit too warm for the winter rubber. Overall traction at the temperatures I was driving in was better than the PSS's at the same temp in a straight line, but the PSS's were still doing better when I wasn't headed in a straight line. Braking is also noticeably better on the Alpin's at the moderate Pacific Northwest temps since Wednesday. I'm very interested to see if this balance changes as temps drop and I get more miles on these tires. I'm also tempted to head straight to Discount Tire and have them put wider Alpin's on the back (and then save the current rear tires as spares for the front). I really don't want to spend more money on tires right now, though. I get what BMW was trying to do here...these tires would cut through snow better with this setup than with a staggered, wider-in-the-rear setup. Not sure where I'm going to go with this, but if the grip doesn't improve with time, I will have to do something as the margin for error on a curve feels dangerously small right now (though it is kinda fun). |
11-25-2018, 08:14 AM | #2 |
Rep 142
I am putting mine on next week. Same tire and width but 18 instead of 19".
I would hold off with purchasing anything until 1) tires are broken in 2) temps are cool and tires are warm 3) have double checked the tire pressure. |
11-25-2018, 08:19 AM | #3 |
Rep 3,287
Tight fit on the front-right:
cptobvious2531.50 Uncledanny661.50 |
11-25-2018, 08:20 AM | #4 | |
Rep 3,287
#3 is already done, immediately after install and again the next morning. FYI - they were at 45 lbs when I put them on, so don't drive anywhere without checking it. |
cptobvious2531.50 |
11-25-2018, 08:46 AM | #6 |
Rep 2,526
Agreed. I would wait to pass judgment until the temp drops and they are broken in.
Fwiw, I went with 265/35r19 all the way around on my car. I did not notice any loss in lateral grip. But I switched after the Temps were consistently below 50F |
11-25-2018, 09:04 AM | #7 |
Rep 3,287
Temps have been below 50F. Both trips around the fun curves were right about 40F ambient temp.
11-25-2018, 10:36 AM | #10 |
Rep 3,287
That was the main point of the post for others who get this set, though not all that well stated due to the early hour. It's fun, but a lack of experience and a dollop of excessive exuberance could certainly lead to an unfortunate experience with an arboreal barrier.
11-25-2018, 11:17 AM | #11 |
Rep 3,287
One other note: The Michelin Alpin 4's, considering that they are not broken in yet and narrower than the stock tires, are surprisingly quiet and with a softer ride. The car is, overall, a more comfortable drive on these tires, in temps between 38F and about 43F than the PSS stock tires. I was expecting them to be louder than they are.
11-25-2018, 11:21 AM | #12 | |
Rep 3,968
Also, does BMW make those in black or did you get them powder coated? Wish they did that with the 640s - cause yours look great (and I don't feel like spending $500 on powder coating my winters).
11-25-2018, 11:31 AM | #13 | |
Rep 3,287
They came in black. I probably wouldn't have picked black but I didn't have the part numbers for the silver versions of the 641's I've seen in some pics. As it turns out, I love them in black, so that worked out. |
11-25-2018, 11:45 AM | #14 |
Rep 3,468
If I’m reading this right you put 235s on a car this heavy and powerful? I’d say the reason for loss of traction is obvious. You only go narrower for snow if you are dealing with a lot of fresh snow often (on top of a hard surface) and have a vehicle that can put some weight on those narrow tires. Your ground clearance will prevent that anyway. Wider is better.
11-25-2018, 12:14 PM | #15 | |
Rep 281
11-25-2018, 12:26 PM | #16 | |
Rep 1,015
1st world problems. |
11-25-2018, 01:05 PM | #17 |
Rep 5,874
Michelin PA4s are awesome winter tires for the PNW with constantly cold/wet roads but little snow in lowlands. I've had multiple sets on several different cars. They are quiet, comfortable, good overall grip, great handling, and they lose traction in an incredibly soft and controllable manner. I've had 245s all around on an E90 M3, 225/255 on M235xi, and now 255/285 on my E92 M3. I am not in the narrower is better in winter camp at all and quite happy with my super wide setup at present. Especially on a high torque car like the M2, wider makes sense to me.
If you can make it work for you, I would increase section width in the rear if not all 4 tires. Since you already have 235/35 tires, increasing to 255 at least in rear is no big deal except for cost. Also, that wheelset is 8.5" front, 9" rear. I don't understand why BMW didn't spec the package with rear 255s. 235s are just way too narrow. Overall car looks great with those wheels though! |
11-25-2018, 01:07 PM | #18 |
Rep 1,237
Drives: M2 Competition
I remember my collection day with 641M and Michelin PA4. They where also over inflated...
...got a few scary moments! Setting the correct pressure helped a lot, traction control no more intervening all the time. Temperatures coming down 2 weeks later helped as well. But i'm sure handling, grip and precision is nowhere near compared to the summer set of rubber..
11-27-2018, 04:03 PM | #19 | |
Rep 69
11-27-2018, 04:49 PM | #20 |
Rep 1,237
2.5bar (~36psi) is working well for me.
2.8 - 3.0 bar (40.5psi - 43psi) absolutely not OK!!! (Thats how i got the car)
11-27-2018, 05:38 PM | #21 |
Rep 69
I am currently running 2.5 (front)/2.7 (back) and it seems to be already too much for the back: I don't need to set MDM mode in order to drift a bit
11-27-2018, 05:40 PM | #22 |
Rep 1,237
Nope
go 2.5 all around if you‘re alone in the car. You will have much better traction! |
