11-23-2018, 02:31 PM | #1 |
Rep 303
KW HAS ?
anyone have the KW height adjustable spring package installed on their M2 ?
How’d it work out for you ? Rear shocks holding up ok ? I note that KW shows the same part number (and spring rates presumably) for the M2 as for the M3/ M4 kit....whereas Dinan has a separate part number for the M2. A quick look shows the M3 / M4 rear spring rates are often greater for the M3 / M4s than for the M2s...so makes me wonder how the same rate can be used for the different platforms. |
11-24-2018, 05:40 PM | #2 |
Rep 4,551
Drives: 2015 328d xDrive
Yup I have them. Installed over a year ago, 0 issues. Ride quality very similar to stock, perfect for daily use. Much better than the non adjustable H&R springs I had on before because you can set the ride height however you like. I highly reccomend them.
11-24-2018, 05:53 PM | #3 |
Rep 303
Wow. Looks great.
I got a pm from a guy..he loved the kw has with one exception. He was not able to get even close to stock ride height for his winter wheel / tire package, even at highest setting. Otherwise no problem. Thanks for the pics. |
12-04-2018, 02:15 PM | #4 |
Rep 245
I have them and like them as well. The only issue I had was that with the lowering and 10mm spacers all around, I occasionally rub when there is a large dip in the road.
And the best part is that they ride like stock. I changed the springs without telling my wife and she still doesn't even know when she sits in the car. |
///M Houbi1655.00 |
12-08-2018, 10:30 AM | #6 |
Rep 4,551
12-17-2018, 09:51 PM | #7 |
Rep 1,418
12-17-2018, 10:52 PM | #8 |
Rep 4,551
Little rubbing up front but only over large dips
