11-04-2018, 04:54 AM | #23 |
Rep 1,794
Drives: E86 3.0si
Garage List '55 Ford F100 [0.00]
'08 Z4 3.0SI [8.50] '66 Triumph TR4A [0.00] '85 Corvette [0.00] '64 Corvette [0.00] '68 Triumph GT6 [0.00] '19 VW Golf "R ... [0.00] |
As only BRM (British Racing Motors) could envision...the incredibly complicated two crankshaft H16 for the new 1966 3L engine formula.
GeorgeA758.00 |
11-05-2018, 04:16 AM | #25 |
Rep 1,408
11-07-2018, 11:34 PM | #26 | |
Rep 1,420
11-09-2018, 12:56 PM | #27 | |
Rep 19,368
According to Wikipedia (not sure if it can be verified elsewhere):
https://en.wikipedia.org/wiki/Formul...–present Quote:
That being said, it occurred to me while reading this thread, BMW happens to have an I6 that displaces 1.6L, just like an F1 V6 does: https://en.wikipedia.org/wiki/BMW_K1600#Technology According to the wiki entry, it is the most compact I6 ever produced. Of course with a cylinder spacing of just 77mm, it would not be able to accommodate the as-big-as 80mm bores the F1 V6 engines use. So, it couldn't achieve as short as stroke as they do either (without decreasing displacement), and thus could not be made to rev as high as they do, and probably therefore couldn't make as much power. Still, I thought it was sort of interesting that BMW's motorcycle engine gives us a glimpse into what an F1 I6 might actually look like if it existed. |
11-10-2018, 08:38 AM | #28 | |
Rep 40
BRAP |
Grumpy Old Man6476.50 |
11-10-2018, 08:54 AM | #29 | |
Rep 3,737
Drives: 2016 M4 DCT Tanzanite/Amaro
(I suspect that Daniel Ricciardo thinks he's been driving that exact car throughout the season just ending) |
11-10-2018, 09:34 AM | #30 |
Rep 3,737
for a taste of what a BMW I6 can sound like watch the YouTube vid pictured below. Having seen and heard this motor in a Jagermeister MARCH 762 at the Watkins Glen historics a few years ago I can certify that that motor is A LOT louder then the video. The other picture is of an F2 car similar to the one I saw at the Glen. The blue car is the same chassis in Formula Atlantic configuration with a four-cylinder Brian Hart Ford BDA. Driver is my brother back in the day.
11-10-2018, 12:56 PM | #31 | ||
#buildnotbought
10855
Rep 4,893
There are multiple formula classes that use an I4 as engine and as stressed part of the frame, like Formula Renault. You can strenghten the block any way you like to have it a stressed member of the frame. I expect F1 to adapt 4cyl engines in the future (or maybe 3 cyl) once electrification becomes more a part of the cars. (I dont think thats an unstoppable trend) I mean 25 years ago they had V12's and gradually the # of cylinders went down with the displacement. Why would that stop; they do this to limit power because of safety. There comes a point that the manufacturers can get 1000hp out of the current # of cylinders and displacement with this turbo pressure. As long as F1 also has an agenda to adapt technology and trends that play a part of daily life cars, fuel consumption and efficiency are factors that play along. And an I4 is in the end more efficient than a V6 at these small displacements imho. What I find a bit disappointing is that competing teams are not free to choose their engine configuration. Why not set the rules so that you can have (or must have) a certain amount of displacement, a certain turbo pressure and you get a certain amount of fuel for a certain track/race and just figure it out. On the one side that may limit certain teams to compete because the diversity means maybe higher costs, but it will result in the most technological innovations.
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
11-10-2018, 02:46 PM | #32 | |
Rep 1,794
Drives: E86 3.0si
11-10-2018, 04:04 PM | #33 | |
Rep 19,368
Yeah, it might not be. It is possible this is a misquote or misinterpretation. There is no attribution on that sentence in the Wikipedia article, and the one for the next sentence does not have any info about this claim.
I agree with you that it is possible in general to use an inline engine as stressed member. Quote:
11-10-2018, 08:38 PM | #34 | |
#buildnotbought
10855
Rep 4,893
I think in the early days they used something like 8 bar boost pressure in qualifying. The size of the turbo's back in those days were immense (and no variable geometry, twinscroll etc, so lag was immense. I wonder how many gears they had back in those days) BTW in the late 70's/early 80's manufacturers didnt necessarily had to use i4 turbo engines within the boosted rules. The first turbo engine in F1 was a V6, and other manufacturers also used v6 engines, but back then manufacturers had the choice. I think thats better.
11-11-2018, 08:08 AM | #35 |
Libertarian
71934
Rep 4,035
That's an easy one, because the car handles better with the much shorter V6.
///M Power-Belgium63356.50 |
