12-24-2018, 12:25 PM | #90 |
Rep 203
Yes I am using their mid pipes, but my car is a U.S. spec and it does not come with OPFs. My muffler is valved. I didn't have to do any tuning. Eisenmann said no CEL either after install.
01-01-2019, 06:24 AM | #95 |
Rep 2,856
Where are the burbles? Did you put it in sport plus mode?
Is this valve open or closed? Looks like open MR |
01-01-2019, 10:47 AM | #96 |
Rep 244
01-01-2019, 11:07 AM | #97 |
Rep 1,200
Thank god is right! Burbles are the worst for this car...BMW needs to have their head checked for enabling any of this feature.
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration 1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder |
Proctor750426.00 |
01-02-2019, 09:56 AM | #98 |
Rep 1,083
According to the video description
Short video of my Eisenmann exhaust. First revs are in comfort mode with closed valves and the second part is in sport plus mode with open valves. If putting on this exhaust eliminated the burbles, I'm so down for one of these!
01-02-2019, 10:26 AM | #99 | |
Rep 2,856
MR |
Meanie546.50 Ceramic Rabbit85.50 |
01-03-2019, 12:49 PM | #100 |
CSOUSAX603
119
Rep 130
Drives: 2019 F82 M2C SO DCT+EP
01-04-2019, 11:22 AM | #102 |
Rep 203
It has the midpipe as well.
2017 M240i - Sold
2019 M2C - Sold 2022 M3 Manual - Current 2023 X3MC - Current |
01-05-2019, 12:53 PM | #103 |
Rep 2,856
On a German car? You are taking a massive risk. How are you gonna get it through the TuV?
As far as I heard this is a criminal tax offense in Germany and could get you jail time if you remove the OPFs and run a non-homologated set up illegally. Of course, it could be you know someone at the TuV that is able to let you have this set up. MR |
01-06-2019, 11:51 AM | #104 | |
Rep 203
01-06-2019, 02:40 PM | #106 |
Rep 57
Sounds great, did you resolve the question about the gap between the top of the tail pipe and the diffuser? Is it the same as stock, looks like the pipes maybe a little bit lower?
02-02-2019, 12:06 AM | #107 |
Rep 281
Does anybody have any video, sound clips or opinions about the Eisenmann mid pipe paired with the stock axle back? I've heard clips of the AA mid pipe but not of the Eisenmann yet.
02-02-2019, 02:40 PM | #108 | |
Rep 2,856
MR |
02-02-2019, 02:47 PM | #109 | |
Rep 2,856
I could put two fingers between my Akrapovic end pipes and the rear diffuser, and with the Eisenmann it was more than three. I think you might be able to change it and put it higher, but this was the prototype similarly to what my set up is, so Eisenmann might already have corrected it for future systems. Also the aligning of the end pipes is wrong. The outer ones need to be sticking out more outwards, but that is something you can do quite easily change, I believe. All in all, just minor adjustment to make the fitting OK. MR |
02-04-2019, 09:59 AM | #110 |
Rep 2,856
As discussed over the weekend, Luis (StLuis51) and I have made a comparison of our exhaust systems. Both are prototypes and both have been fitted to different types of cars. Mine is a EU-spec M2C with a DCT and it is outfitted with the Akrapovic Slip-On plus Linkpipe making it a full cat-back system, and Luis has a US-spec M2C with a manual with the full cat-back system from Eisenmann with the normal end damper.
The video below shows the difference between both exhausts. First of all, we compared a static rev in valve closed and valve open mode. The clear difference between the systems in all modes is the tone. The Eisenmann is a lot higher pitched. The high pitch tone on the overrun is a lot louder than the Akrapovic exhaust and when you rev it to the max it even hurt my ears when I was just standing 2 meters from it. It is that loud valves open. The main reason is the way the exhaust is build. You will see on the Eisenmann that all four pipes come from the same end damper. The Akrapovic has a bypass for the outer two pipes. These pipes are valved, while the Eisenmann has both inner pipes valved. This is where the main difference lies between valve closed mode on the Akrapovic and on the Eisenmann. The Akrapovic is almost as silent as stock when the valves are closed. The Eisenmann screams at you even if the valves are closed. From a sound level point of view we would be looking at like level 7 valve closed with the Akrapovic, level 10 with the Eisenmann. When the valves are open, it becomes level 12 with the Akrapovic and 13 with the Eisenmann. The Eisenmann always feels a touch louder due to its higher pitched tune with higher revs, even though the dB value seems to be quite similar. In the end, the camera did not really pick up that high pitch sound track. On the subject of the burbles, the Akrapovic takes the win. The sound track of the Akrapovic is more characterful, deeper and wider. The Eisenmann wins on the high pitch level of the soundtrack, sound volume and the crackles at the top end, which the Handycam camera (without external mic) never recorded unfortunately. It is almost impossible to pick those up. On the inside, the Akrapovic has more tone across the range due to its lower and wider nature of the sound track. It fills the cabin more than the Eisenmann does. The Eisenmann is similar in its volume level, but less “cabin filling” due to its high pitch and less darker or bombastic sound track. This is just a difference in tone and resonance. All in all, the clear difference between the two is tone and character. The Akrapovic system gives you more freedom between being relatively quiet and loud due to the type of valve control. The Eisenmann system is either loud or a touch louder than already loud, there is no under the radar mode so to speak. The Akrapovic exhaust has a more characterful sound track, deeper, less shouty, you could call it more sophisticated. The Eisenmann is way more in your face, shouty and out there for everyone to hear every single time you drive the car. In some ways, you could compare the two sound wise (not looks wise ) as a baritone signer in a suite offering a controlled overture when you prefer (Akrapovic) versus Christina Aguilera in a funky dress trying to reach that high note every single time to rev it to the max (Eisenmann). That is how it felt after we tested both. MR |
