09-01-2018, 03:11 PM | #1 |
Rep 86
Engine problem: lci m2
So about 2 weeks ago I noticed upon cold start, the revs would drop after about 2 seconds (which is Normal) but it dropped significantly more then usual. Like it almost stalled. Today I went to start it up and it did stall. Just wondering if anyone else has had this happen and what is likely the cause ? I didn't have any engine lights or anything on either. On a side note, how do I get the tire pressures ? All it shows is green lights on all 4 corners. Thanks!
09-01-2018, 03:43 PM | #2 |
Rep 573
I have had no similar issue. 9,500 miles.
09-01-2018, 03:44 PM | #3 | |
Rep 86
09-26-2018, 03:00 PM | #4 |
Rep 4,253
Go for a drive, get the oil warm, floor it in fifth gear from 1500rpm to redline a couple times. Report back. Sounds like adaptations to me.
///M Power
10-06-2018, 06:21 AM | #7 |
Rep 243
Drives: 2018 MGM 6MT M2
~5,000mi - no issues like you describe.
As far as tire pressure goes, I check manually as I have found the values reported by the TPMS to be a little off from what I get for cold values. |
Tiss'er78.50 |
10-06-2018, 11:16 AM | #8 |
Rep 350
I think Canadian LCIs do not have TPMS, it will never tell you pressures or temps. It uses wheel rotation sensors for detecting flats.
I think only the Canadian M2Cs have started to have TPMS. Early runflat BMWs may have had TPMS but for the longest time we've not had TPMS in Canada, only the latest generations have started introducing TPMS (again?) to Canada. |
