01-18-2018, 09:41 PM | #1 |
Rep 1,263
2018 M2 N55 or 2019 S55 w/Pure Turbo mod
Gang,
Need your Opinions and dyno #'s with mods such as what I'm planning.... I've spent weeks on the boards going over builds on both the N55 & S55 motor. I'm looking to build a M2 for street & HPDE duty. I don't want to take the car up to the edge of reliability, heat soak at HPDE's etc. Do I go out and buy the current M2 at $54K (or a low mileage used one) and mod the N55 motor? Or do I wait till this summer to place an order on the new S55 M2 and mod it? The 2019 looks like its going to be $60+K. Both motors look like they are fuel delivery limited and I don't necessarily want to do the PI or Meth route to add power. I'll be happy running Pump 93 (live in New England) with the ability to run E85 or any blend for HPDE track days. On the N55 It looks like with the Pure Turbo I'll hit around 500WHP before running out of fuel. On the S55 the headroom is much higher...like 625-650 WHP with the Pure Turbo's. Bolt ons: Drop in filter(s), or intake HFC 200cel DP Proper tuning setup FMIC Catback System Charge Pipes I plan on running a D/A C/O setup with plates and a 2nd set of 275 or 285 track tires on 10" rims 4 corners. I'm leaning towards the S55 because I can get 500WHP from just a tune and bolt ons...then go nuts with the Pure Turbo setup when I get near the end of the factory warranty. So what are your thoughts on this? Why one over the other? THX HAZMAT
01-19-2018, 12:48 AM | #2 |
Rep 155
Fuel pump in the N55 tends to be the limitation to 400+ power.
Living Life Turn After Turn!
[/url] F87 M2 Performance Edition - 2017-current F15 X5 35d - 2014-2017 E36 M3 - 2009-2016 |
01-19-2018, 07:32 AM | #3 |
Rep 960
Q for you... for HDPE do you really need 600hp on a 3k lb car? It’s not a straight course right? If you can get the n55 bear 500ish feels like it would suffice? Plus you could lightEn up the car a smidge.
Granted you need to solve the fueling issue and possibly upgrade to a bigger turbo for reliability to get to the 500 range. |
01-19-2018, 07:53 AM | #4 |
Space Force - 4 Star General
11456
Rep 3,264
My thoughts exactly. More is not always better unless you are just looking for bragging rights. Just my opinion, you'll be slower with 600 Hp that you will be with 500 Hp. Above the mid 400s and traction becomes a real problem with this chassis.
Unless you are a rockstar driver who is highly skilled at driving a traction limited, 600 Hp, RWD car, I think it'll be a waste of money and potentially dangerous. I don't know your background or your abilities, but if you are anything like me or the 90% of the people on this forum, 600 Hp is just overkill. |
01-19-2018, 08:25 AM | #5 |
Rep 1,073
Drives: 1991 318is; 2017 M2
Has it actually been confirmed that the 2019 M2 has the S55? I thought so there was only talk of CS/GT4/CSL variant receiving the S55. I can't imagine the normal M2 would as well as it would be too close to the normal M4.
01-19-2018, 09:08 AM | #6 |
Rep 229
If supply was tough for the m2 now and they eol it this summer for a 10k more m2 comp, do all of these people on the forum think they can just walk in and get an allocation this easily?
18 M2 lbb manual exec (Euro Delivery) and PDC
11 e92 335i xdrive BSM/PE (Sold) 09 335i xdrive Monaco Blue (Traded) 02 330xi (Sold) |
01-19-2018, 09:21 AM | #7 |
Rep 358
2019 base M2 won't have the S55. Only CS and you won't get one unless you are already on a list. Also as previously stated why do you need 500+ for HPDE car... if you want a pure driving experience get an M2, mod appropriately (brakes, fueling, cooling, tune) and enjoy.
Cheers
F87 M2 - LBB - 6MT - Exec Package
insta - @LBB_M2 |
DOMs335D220.50 |
01-19-2018, 09:32 AM | #8 | |
Rep 207
I eventually removed the SC after a year. The difference/improvement in handling from the nearly 100 lbs removed from the front of the car, was remarkable. IMO, 400whp is just about the traction limit for the FR platform. Yes, you can change to steamrollers in the rear to handle the power but that takes away the intended handling character of the car. Running track tires for normal driving is not an appealing option to me either. So I think S55 makes sense for those that want that near 400whp and don’t want to mess with the ECU. My preference is to go with the N55 for better sound and quicker boost, then make up that gap to 400whp with DP and tune.
Gone but not forgotten:
'14 Corvette Stingray (2014-2017) '05 Boxster S (2005 - 2014) '00 S2000 (2000-2005) |
01-19-2018, 09:54 AM | #9 | |
Rep 1,263
I'll run 305's on the rear on the street and a square setup at the track. I'll set the suspension up using my Solo DL and a pyrometer. The tune will be setup for a consistent, progressive, manageble boost curve. And most importantly the throttle settings will be setup to handle modulation at apex to track out.. Thx for the feedback so far.... HAZMAT
01-19-2018, 10:07 AM | #10 | |
Rep 1,263
"While the M2 Competition won’t be artificially limited, the number of units produced will be based on the production capacity and demand. First units will arrive to customers in late summer"
01-19-2018, 10:09 AM | #11 | |
Rep 796
If it helps the n55 fuel limitations are about to be a thing of the past. A few people are working on packaging and selling the dual s55 HPFP's on the M2 n55. Meaning Pure stage 2 can find its limits without meth or PI. I'm thinking that's around the 550whp-600whp range. A few upsides to the M2 and it's powertrain for me are 1: simplicity of the single setup. 2: cheaper parts 3: better sound. 4. I'm thinking the ps2 power delivery on the n55 M2 will probably be more linear and enjoyable vs the s55 but that's just me! |
01-19-2018, 11:54 AM | #12 | |
11456
Rep 3,264
01-19-2018, 11:57 AM | #13 | |
11456
Rep 3,264
01-19-2018, 12:00 PM | #14 | |
Rep 1,263
I also agree that the N55 motor is more linear than the S55. Which is very important to me. I'd rather have a smooth spool up and then a flat TQ curve in the higher RPM's than what the S55 motors produce.
01-19-2018, 12:18 PM | #15 | ||
Rep 796
For comparison sake, PS2 on the N55 is cheaper. When combined with supporting mods it should be much cheaper. One vs two of everything for the hard parts. That could be offset depending on the cost of the S55 HPFP conversion, but I'm betting the value/savings will remain. |
01-19-2018, 02:17 PM | #16 | |
Rep 6,634
01-19-2018, 02:21 PM | #17 | ||
Rep 358
insta - @LBB_M2 |
01-19-2018, 02:41 PM | #18 |
Rep 25
I realize its all rumors right now, but what is it that makes it seem so unlikely to you?
M2 Competition - waiting...
2007 Z4M - SOLD |
01-19-2018, 02:43 PM | #19 |
Rep 6,634
It's in the stickied "CS" threads on the front page. Basically the N55 base M2 is hitting end of production after MY18 and the only thing left at that time on the internal BMW schedule was the M2 Competition. No B58 version has been seen in testing so it seems almost impossible that would come out of nowhere.
01-19-2018, 02:45 PM | #20 | |
Rep 358
The M2 is BMW's "budget" entry level M car. With the S55 we would see a significant price increase. I'd think it'd also effect M3/4 sales. It would also probably piss off a good number of N55 M2 owners.
insta - @LBB_M2 |
01-19-2018, 02:50 PM | #21 |
Rep 6,634
http://f87.bimmerpost.com/forums/sho...&postcount=136 "Well well well... To be honest, I never even bothered to check the EOP of the original M2. Just never thought I would discover anything newsworthy... June 2018. Let the outrage begin." http://f87.bimmerpost.com/forums/sho...85&postcount=1 'M2 COMPETITION' UPDATE #4 (DECEMBER 2017) Autumn 2017: 'M2 Competition' PR campaign cars have been built (see here); Winter 2017-2018: release and presentation of the M2 Competition (presentation location currently still unknown, but guessed to be the Geneva International Motor Show in March 2018 as likely venue - see here); mid 2018: M2 Competition (3.0 S55 engine - 302kW) replaces the base M2 (3.0 N55 engine - 272 kW); |
AlexCirci496.50 |
01-19-2018, 03:08 PM | #22 | |
Rep 1,606
'17 M2 San Marino Blue, 6MT; 2011 335iS, 2007 328i, 19 Ram 1500, '18 Yamaha MT-07, '14 Kawasaki Ninja 1000. SOLD: '16 European Delivery M3 San Marino Blue, 6MT. '13 335iS, 2002 M3 6MT, 1997 M3, 1998 M3, 1996 328is (picked up in Munich at OLD ED Center), '88 Mustang GT 5.0, '84.5 Mustang SVO Turbo, '77 Rabbit,a cool 1992 Taurus SHO, and KTMs.
AlexCirci496.50 |
