08-15-2021, 12:19 PM | #23 | |
378
Rep 348
What’s the matter with you Lol? Hope in addition to learning about fueling during this exercise you learned a lesson about the purchasing process? |
08-15-2021, 12:34 PM | #24 | ||
Rep 1,244
Drives: 2017 Big Turbo BMW M2
08-15-2021, 12:35 PM | #25 |
378
Rep 348
08-15-2021, 12:37 PM | #26 |
Rep 1,244
I plan to add a hpfp later on for better fueling. will that still be able to support it ? I'll probably need something that cam support up to 600whp but unsure what size I need
08-15-2021, 12:38 PM | #27 | |
378
Rep 348
I’ve done way dumber stuff. The process works. |
08-15-2021, 12:39 PM | #28 |
378
Rep 348
Upgrade components as necessary. The CSF should take you far. Once you’re sure it’s the limiting factor, sell it and upgrade.
08-15-2021, 01:13 PM | #29 | ||
Rep 2,526
08-15-2021, 01:44 PM | #30 | |||
Rep 1,244
08-15-2021, 01:46 PM | #31 | |
Rep 1,244
08-15-2021, 02:29 PM | #32 | ||||
Rep 147
08-15-2021, 02:31 PM | #33 | |||||
Rep 1,244
08-15-2021, 02:52 PM | #34 | ||||||
Rep 147
08-15-2021, 02:54 PM | #35 | |||||||
Rep 1,244
08-15-2021, 03:02 PM | #36 | |
Rep 3,696
I also don’t think you’re going to get 500whp on 93 even with an HPFP and a Stage 3 turbo. I think you’ll be octane limited to get to that power level. But, some of the Stage 3 guys would need to share some Dynojet curves to confirm that or not. |
08-15-2021, 03:02 PM | #37 | ||||||||
Rep 2,526
08-15-2021, 03:43 PM | #38 |
Rep 4,146
As mentioned before, the Evo 2 is not a good choice. There is another guy on the F30 side struggling with IATs on the Evo2 on a PS2 turbo. It also has the lowest total heat capacity of all the intercoolers mentioned here.
If you want to cut corners, anything will work. The $450 VRSF, or even $380 ARM (ER clone) would suffice. I’ll echo that a Evo 3 would be the best choice, but you have to decide what’s best for you. |
08-15-2021, 03:55 PM | #39 | |
Rep 1,244
08-15-2021, 05:13 PM | #40 | ||
Rep 147
08-15-2021, 05:16 PM | #41 | |||
Rep 1,244
08-15-2021, 05:28 PM | #42 | ||||
Rep 147
I was running a tte550 then, when i put the new turbo on i decided to change the pump and nostrum was Ecutek recommended, the pump has been spot on, and i can't recommend Nostrum enough. I guess its down to personal preference. |
08-15-2021, 05:34 PM | #43 | |||||
Rep 1,244
