07-30-2021, 01:24 AM | #1 |
Battle Tactician
453
Rep 306
Best intake for performance gains?
Did the bootmod3 stage 2 tune with downpipe, charge pipe and intercooler. Trying to squeeze out every last drop of power without going E85, meth injection or stage 2 turbo. What intakes provide actual performance gains? I realize they wont add much, but I would be content with even 5 extra HP.
Looking at injen right now because it sounds good, doesn't look stupid and doesn't cost a lot but ultimately performance is all I care about. Any thoughts? |
07-30-2021, 01:42 AM | #2 | |
Rep 7,431
honestly with the stock turbo and even ps2 you won't find any power gains to be had with an intake. If you want real gains get a turbo inlet that is actually the major bottle neck of the intake system on these cars. Intakes are for noise and pretty much nothing else imo.
07-30-2021, 01:56 AM | #3 | |
Battle Tactician
453
Rep 306
07-30-2021, 02:21 AM | #4 | |
Rep 7,431
Oh yeah and heat soak could cause you to loose power but I doubt it is very likely because of the intake duct on the m2 forcing cool air into the intake area, so as long as you keep the stock intake bottom the ducting will still be there. Honestly I think stock is best, bmw finally did a damn good job with this one part to the point where I don't think an upgrade is needed unless you want the sound.
DailyDownshift453.00 |
07-30-2021, 02:26 AM | #5 | |
Battle Tactician
453
Rep 306
07-30-2021, 02:28 AM | #6 | |
Rep 7,431
https://f87.bimmerpost.com/forums/sh...4&postcount=11 2) This is what the stock intake bottom looks like: https://www.ecstuning.com/b-genuine-...x/11122334344/ Look at that massive orange cut out for the mppk boxes, it virtually eliminates all restriction. The only time I believe the stock intake tube will be a bottle neck is if you push insane power like 700 whp+. Otherwise I don't think even a stage 2 turbo sucks enough air to cause a problem.
07-30-2021, 02:51 AM | #7 | |
Rep 7,431
So I recommend anyone with a metal tipped inlet use some silicone or PTFE lube (like bmw did on the stock plastic inlet which is why it was so fricken gooey when I removed it, bmw also put a bunch of silicone lube on the throttle body side charge pipe O-ring so they weren't worried with it getting into the engine) to provide lubrication and act as a film to hopefully prevent metal on metal contact as best as possible (and if there is metal on metal contact it will act as a goop to trap metal particles). https://www.super-lube.com/multi-pur...-syncolon-ptfe This is my personal favorite grease because of how high quality it is, it is food grade (doesn't matter at all), has an insanely high operating temperature range, hasn't ever gone goopy or slushy on me and stays in the same state as it was applied. Apply only to the outside edge of the inlet so it doesn't get sucked into the turbo. So my rating of inlets (X are rated the same): 1) MST silicone inlet - because it is proven to fit at the moment, it is really expensive though. X) BMS silicone inlet - it is really affordable and looks like it has good quality but I haven't seen fitment data. X) CTS silicone inlet - again affordable and looks like good quality. Again I personally would avoid all metal inlets they are absolutely garbage imo, they have no flex so all the stress ends up on your turbo inlet mouth and install/clearance is a nightmare.
DailyDownshift453.00 VicF87OG72.50 |
07-30-2021, 03:14 AM | #8 | |
Battle Tactician
453
Rep 306
07-30-2021, 03:22 AM | #9 | |
Rep 7,431
Install wasn't fun but wasn't bad imo.
07-30-2021, 02:33 PM | #10 |
Rep 201
Most people are doing the diverter valve (or blow off valve if wanting added noise) when they do the turbo inlet. Turbosmart would be my choice but gfb is popular too.
07-30-2021, 02:57 PM | #11 | |
Rep 7,431
Yes there is alot of be gained wgdc and throttle response wise with a diverter valve. I personally went with a gfb dv+ desire turbo smart being an option. I just personally like the gfb dv+ concept more and since the factory solenoid is very robust I wanted to retain that and replace the parts that aren't too good (aka the plastic piston).
07-31-2021, 10:01 AM | #12 | |
24199
Rep 190,807
Injen is our most popular intake, its the loudest as well
DailyDownshift453.00 ///M TOWN16569.50 |
08-14-2021, 08:04 PM | #13 | ||
Rep 7
So the best you'll get with an aftermarket intake, if you clean the filter regularly like on a race car, is no more power and slightly dirtier oil. And induction noise, which is the only "benefit" if that's what you want.
?I don?t know how many tenths that was. Too many.?
08-20-2021, 02:06 PM | #15 |
Rep 4,146
Stock with a drop in filter would get my vote. While a actual intake can improve performance slightly (CTS Turbo) it’s mostly noise.
The dry flow filter was show to not increase particulate matter in another members blackstone test, so no worries there. |
08-20-2021, 02:47 PM | #16 |
Rep 7,431
There's a Dyno of a k&n drop in by a member here and there was no performance gain. The stock Mahle filter without the carbon filtration layer is not restrictive at all and rivals after market drop in filters. Mahle did a really really good job with the stock filter.
08-20-2021, 06:30 PM | #18 | |
Rep 4,146
08-20-2021, 07:10 PM | #19 |
Rep 7,431
Scroll down a bit: https://f87.bimmerpost.com/forums/sh....php?t=1661597
08-20-2021, 10:30 PM | #20 | |
Rep 4,146
What is he tuning with? BM3 or MHD? (Likely MHD based on his location) If it’s MHD, it’s a load based tune, there won’t be any gains after the targets are met. The only may for him (or anyone) to note tangible differences is by driving and/or reviewing the logs for changes in MAF reading, WGDC and fuel trims (indicating less restriction) Last edited by AmuroRay; 08-20-2021 at 10:41 PM.. |
08-20-2021, 11:52 PM | #21 | |
Rep 7,431
I can't remember but I think someone here did a similar thing with either jb4 or bm3 since those were the first 2 tunes available. I'll look around.
08-22-2021, 09:45 AM | #22 | ||
Rep 4,146
But we KNOW Tube intakes make power on these cars, it always has: Quote:
