05-15-2021, 09:45 PM | #1 |
New BMW owner
325
Rep 843
Burbles & Stage 1 93 octane
Hi guys.
Seems to have a whole lot more burbles now than the stock on Sport +. I would estimate about 3-4 seconds duration now. One time I even heard a "bang" which might be what I have heard describe as "gunshot". Is that normal? Not really liking it ...seems to go on for far too long. I'm now hearing this fast subtle blr-rrrr-rrrr-rrrr sound that I wasn't hearing before when I quickly let go of the throttle during more aggressive driving. I love that. Is that the diverter valve? I'm playing around w/ the CUSTOM settings now. Any idea if the numbers showing on the Custom is the OTS ...or the Original? It says 1.5s but I'm sure it's way more than that. If there's a setting for Comfort (no label), Sport (labeled as Sport).... where's for the Sport+? It's what I use for my canyon runs.
05-18-2021, 03:38 PM | #2 |
Rep 266
I noticed a longer duration and more aggressive burbles with the OTS map as well. I lowered the aggressiveness to 4 and duration of the burbles to .5 so as keep attention away from authorities.
05-18-2021, 03:49 PM | #3 |
Rep 570
I noticed this as well. You can change it quite easily in the BM3 system.
With my sport cat, dinan res delete, and dinan exhaust with the valve open, the OTS burbles are way too aggressive in volume, tone, length of time and those gun shots you mentioned. Just getting off the throttle was embarrassing. Even with the valve closed, it was a lot. I'm actually running with no burbles currently, but I plan on adding some back in. |
05-18-2021, 03:56 PM | #4 |
Rep 602
The brrrrt sound is something I've heard even on stock cars. Not sure exactly what it is, but I love it too. I know the guys over in the 2 series forum have been trying to tune it in but haven't been successful.
To answer your question, what's set as custom is just a pre-set custom setting. It's not the original (OEM) or ots. Sport and sport+ both follow the settings for sport. Try out no burbles, you may really like it.
05-18-2021, 07:23 PM | #5 |
6637
Rep 4,145
Drives: '18 M2 6MT
So weird. I adore the pops/bangs/burbles, and absolutely hate the long fart sound on throttle lift. Can't wait to get BM3 after my warranty is out and turn more burbles on and this damn cold start off.
05-18-2021, 08:43 PM | #6 |
Rep 2,577
There is the stock burble option in the map config.
Lemania 2320
VisualEcho6636.50 |
05-18-2021, 08:51 PM | #7 |
6637
Rep 4,145
Drives: '18 M2 6MT
05-18-2021, 09:02 PM | #8 | |
Rep 289
05-18-2021, 10:32 PM | #9 | |
Rep 2,577
I've disabled burble since early 2018.
Lemania 2320
05-19-2021, 11:08 AM | #11 | |
6637
Rep 4,145
Drives: '18 M2 6MT
You can hear it here at 1:33 & 1:41 & 3:19 & 4:53. |
05-20-2021, 02:23 AM | #12 | |
New BMW owner
325
Rep 843
To be honest i don't consider myself to be an expert on this car, I'm a newbie and sometimes i feel I'm not that senstive. But to answer that, I feel that it's not as smooth on low gear but the RPM seems to get up there faster. Seems can be described as "free-er". I guess that's due to the increased power. When on my canyon runs, it's all good and fun. Sometimes I hear the tires chirp on shifts.
05-20-2021, 07:22 AM | #13 |
6637
Rep 4,145
Drives: '18 M2 6MT
Hey brother, it takes all kinds! It's something in the engine management software for sure, as it doesn't happen in comfort, only Sport and Sport+.
05-20-2021, 09:53 AM | #14 |
Rep 1,899
I had this same concern and messaged BM3 support directly. Halim gave me a customized map that brought the "stock" burbles back to truly stock. I suggest you guys reach out to him if you want the same.
CalAcacian549.50 tenkies147.00 |
05-22-2021, 02:52 AM | #15 | |||
Rep 2,577
It sounds to me that you see the details regarding the burble, care to elaborate to start more discussion?
Lemania 2320
VisualEcho6636.50 |
05-22-2021, 06:54 AM | #16 | |
Rep 289
05-22-2021, 08:26 AM | #17 |
6637
Rep 4,145
Drives: '18 M2 6MT
Interesting, as it's not as present on any other boosted BMW that I know of. When I get BM3 I'll ask them if it can be tuned out anyway, you never know.
05-23-2021, 04:24 AM | #18 | ||||
Rep 62
06-09-2021, 11:25 PM | #19 |
New BMW owner
325
Rep 843
When I get my AA hi-flow downpipe which after ~2 months I'm still waiting, I'm going to remove the ASD altogether using BM3 which should turn the burbles off too. I have a good feeling I'd like that more than the ones being pumped by the speakers.
Come on AA, ship my downpipes already. Crazy wait times.
06-09-2021, 11:29 PM | #20 |
New BMW owner
325
Rep 843
Gunshots: are they not the same as a backfire when the car (rich) has too much unburnt fuel and goes into the manifold to explode? Or when there's a leak on our exhaust and the oxygen reacts w/ the unburnt fumes and explodes.
This is supposed to be bad for the engine isn't it?
06-10-2021, 03:42 AM | #21 |
Rep 1,389
My burbles and bangs much more since MHD stage 2. I never even went into the actual burble settings slider so assume it's running stock. However don't know if the stage 2 map has active burble coding in above baseline or it's a result of increased air/fuel/power whatever.
08-24-2021, 04:26 AM | #22 |
Rep 62
So I have figured out how to have the true oem factory burbles back on the car whilst running stage 2+ MHD map.
I have the luxury of having a bm3 licence aswell. To get stock factory burbles: 1. Disable active sound in bm3 diagnostics interface. 2. Disable burbles in MHD map configuration Video here: https://youtube.com/shorts/HLzyT8Dp8io?feature=share Don't ask me why this works but I am absolutely chuffed I have the factory stock burbles back! |
