04-12-2021, 08:44 PM | #70 | |
New BMW owner
325
Rep 843
Thanks for the quick reply. V2 it is.
04-16-2021, 07:09 PM | #75 | |
16567
Rep 8,425
Well I like their design better than the rest
04-16-2021, 08:47 PM | #76 |
Rep 259
Does anyone know if removing the bracket for the water pump along with movinf rhe water pump aside will be beneficial? Will removing the bracket make more room to access the top right DV bolt?
04-17-2021, 01:11 AM | #78 | |
16567
Rep 8,425
I have seen several YouTube videos that show just that Doing the DV at the same time as the inlet is probably a really good idea
04-17-2021, 05:19 PM | #80 |
#gotboost
517
Rep 861
Its basically impossible without undoing the waterpump bracket and pushing it aside. The down side is that it actually doesn't open up that much extra space. If you have any desire at all to do the diverter valve, do it at the same time. Once you finish this you are never going to want to get in there again
2018 F87 M2 (09/2020 - )
Dinan Cold Air Intake |Dinan Axle Back | VRSF 6.5" Intercooler | VRSF Catless Downpipe | VRSF Charge Pipes | BM3 | MST Inlet v2 | Turbosmart VR11 2013 F30 328i (12/2015 - 09/2020) SOLD! |
04-19-2021, 04:42 AM | #81 | |
Rep 83
04-20-2021, 02:30 AM | #82 | |
New BMW owner
325
Rep 843
He posted this a page ago....
04-20-2021, 01:11 PM | #83 |
Rep 1,389
Just,
pay, a mechanic |
Sundinisagod107.00 |
04-22-2021, 12:49 PM | #84 |
Rep 266
Instead of going from the bottom remove the intake tube and go from the top of the engine to get to that bolt. I find you have more room that way and you're going in blind for that bolt either way. Just make sure you have a ball head hex it makes a big difference.
Dj_Quik120.00 |
04-28-2021, 01:18 AM | #85 |
Rep 259
///M TOWN16566.50 VisualEcho6636.50 |
04-28-2021, 09:14 AM | #86 | |
Rep 92
A 5mm ball end allen is a must for removing / installing the upper right DV bolt. A straight allen will not allow enough clearance for the turbosmart DV bolt. I got the top right from the top of the engine bay and the other 2 easily from the bottom. Getting the top right bolt started is likely the hardest part. I also put a very light film of oil on the various connection points for the MST inlet. It helped rotate the fittings around while installing. Getting the hose clamp installed on the turbo side of the inlet was a bit tricky.
2011.5 E92 M3 - Gone but not forgotten
2018 F87 M2 - The new hotness |
04-28-2021, 01:26 PM | #87 | |
Rep 259
04-28-2021, 01:45 PM | #88 |
Rep 266
Here's my account of my install. I did everything at once took my time and it took 2 days/maybe 12 total hrs.
https://f87.bimmerpost.com/forums/sh....php?t=1767952 |
///MPhatic13862.50 |
