03-19-2020, 02:22 PM | #6007 | |
Luxury at the redline :)
9103
Rep 7,563
03-19-2020, 02:26 PM | #6008 |
Rep 4,541
Drives: 2015 328d xDrive
Blacking out the housing
03-19-2020, 02:32 PM | #6009 | |
9103
Rep 7,563
What did you do to your M2 today?
More power to you DIY Blacked Out Headlights https://f80.bimmerpost.com/forums/sh....php?t=1494304 |
AndrewC198910910.50 |
03-19-2020, 02:36 PM | #6010 |
Rep 1,466
That body colour engine cover looks great!
2018 ///M2 LCI, LBB, 6MT...
TheRealOrosie446.00 |
03-19-2020, 02:38 PM | #6011 | |
Rep 4,541
https://www.instagram.com/oneightynyc/ |
Poochie9103.00 NYC Bimmer259.50 |
03-19-2020, 08:40 PM | #6012 | |
Rep 309
Drives: 2018 M2 LBB - 6MT
03-19-2020, 10:42 PM | #6013 | |
Rep 1,466
I posted some photos in this thread: https://f87.bimmerpost.com/forums/sh...0#post25946770
No, I'm not running camber plates, but I don't think that would have an impact on the install. You have to replace the strut top hats with M2C / M3 / M4 parts because they have additional holes on the top that the brace bolts to; the stock parts have a single bolt hole for the steel brace. I did the install by raising the car on a Quickjack to the lowest position, removing the front wheels, and then jacking the lower control arm (with a rubber block) to take the weight of the strut. I then un-bolted the strut top nut, and slowly lowered the shock and spring down. Once the shock and spring were lowered and pulled out of the way under the wheel arch, I un-bolted the stock top hats and put the new ones in; in my case, with the optional (because they're not on the M2C) strut reinforcement rings. You could at this point add camber plates, but you'd need to make sure that the plates you're using have the three holes for the strut brace rather than being the single mount hole that the OG M2 uses. I think some newer camber plates have both mountings, but I'm not sure about that. With the top hats fitted, but not torqued down, I jacked up the shock and spring into place again, then tightened a new nut on top. This was slightly easier said than done because you do need to line up the shock shaft with the hole, and the spring and jack will not have this centered as you raise the jack. A helper would be very beneficial, but I was able to do it alone. I waited for the weight to be back on the wheels before torquing all the bolts down; there is quite a bit of adjustment possible before torquing down, so I wanted to make sure that I wasn't torquing the body in an odd state. Overall though, I'd suggest doing this modification before you do any other suspension work, including camber plates. Without this retrofit, the body is just not solid enough for the stiffness of stock springs and shocks, let alone uprated.
AndrewC198910910.50 gphung193.50 |
03-20-2020, 02:03 PM | #6014 |
Everyday I'm shuffling
449
Rep 1,098
Mine is in quaran..., sorry, shelter in place.
https://www.dropbox.com/s/sggm7t6bqw...54.51.jpg?dl=0 |
LFaist169.50 |
03-22-2020, 02:07 AM | #6016 | ||
9103
Rep 7,563
I also wonder what your shop is using to reseal your housings, clear silicone would be my guess.. Or if I can impose, an individual shop DIY on this mod would be divine but not press.. |
03-22-2020, 08:00 AM | #6017 |
6629
Rep 4,145
Drives: '18 M2 6MT
03-22-2020, 10:30 AM | #6018 |
Rep 830
03-23-2020, 04:45 PM | #6019 | |
Rep 4,541
03-25-2020, 05:29 PM | #6024 |
Rep 4,541
Got the car back from Oneighty! Headlights came out amazing, huge difference! Sorry for the glare/light, today's incredibly overcast so It was hard to get a good pic.
03-25-2020, 05:55 PM | #6025 | |
Rep 307
Wish I could do this, but the M2 is my daily and I just can't afford to be car less for awhile. |
03-28-2020, 04:59 PM | #6027 |
Gangnam Member
229
Rep 136
When I bought this car I thought the noise over the front reflector was kind of more drama than reality. Now that I have bought in and installed my own it really does change the look of the car. So today the painted reflectors went up front. Black inserts in the rear. And recently I replaced the mirrors with the Autoteknic three piece M2C inspired housings. I thought the stock signal would be fine but caved and bought the black sequentials. Oh, and LED bulbs all around with the rear fog hack. Social isolation for the win.
Over all a big wow. Black out completely.
Current: 2015 BMW X5d | 2017 BMW M2 | 1976 BMW 90S
Gone but not forgotten: 2016 BMW 228i, 2014 BMW 228i, 2008 BMW 535xiT, 1998 BMW 328iC, 1991 BMW 325iC Last edited by nelsdvn; 03-29-2020 at 06:32 AM.. |
03-28-2020, 06:29 PM | #6028 |
Rep 462
Not today but totally forgot to post this as it was done just before things got nuts in the US with covid.
Being in Chicagoland, I was fortunate enough to pop out to iND and have them install the wheel they so graciously helped me out with! I love a heated wheel but wanted OEM and full alcantara. Factory options for alcantera are not heated and not continuous coverage. iND had the answer! Factory heated wheel with custom full alcantera. Very happy with the final product! (also had to throw on the matte carbon trim to tie it all together - picked up used from the forum marketplace!)
"... if he fails, at least he fails while daring greatly, so that his place shall never be with those cold and timid souls who knew neither victory nor defeat.” —Theodore Roosevelt
Instagram@particulardude |
