08-12-2020, 01:54 PM | #67 | |
~Spyder
638
Rep 870
Drives: '19 M2C Hockenheim 6sp
Before this exhaust popping feature, I wasn't even considering BimmerLINK, except for registering a new battery... |
JustinHEMI7445.00 |
08-12-2020, 01:58 PM | #68 | |
Not great. Not terrible
7445
Rep 2,700
Current: 2024 BMW X3 M40i.
08-12-2020, 02:47 PM | #69 |
Rep 500
Hopefully its coded as a permanent enable/disable feature, and not like the exhaust valve control via Bimmerlink, where you have to set your preference every time you start the car.
08-12-2020, 02:57 PM | #70 | |
~Spyder
638
Rep 870
FYI - I made him aware of this thread that started it all. Until a few days ago, the singular way to turn off exhaust pops was only via a tune. Recently, the Burkhart AK-display and now the BimmerLink can also do that. We like options... |
JustinHEMI7445.00 |
08-12-2020, 05:30 PM | #71 | |
Rep 555
IG: M2C_SO |
08-13-2020, 07:01 AM | #73 | |
~Spyder
638
Rep 870
I also asked the developer if this will permanently disable the pops or I need to do it again every time I start the car. I'll update the community with my findings. I'm pretty stoked nevertheless, in 24 hrs, seemingly we got an easy to use and cost effective solution. Remains to be seen if it actually works and if it's permanent...if so, Stephan with BimmerCode/BimmerLink deserve 5 stars across the board! EDIT- unsure how difficult will it be to code this feature into BimmerCode for a more permanent solution.
Skål från Sverige...via Texas y-all
08-13-2020, 10:48 AM | #74 | |
~Spyder
638
Rep 870
BUT...don't both apps (BCode and BLink) communicate to the ECU via the dongle's BLE connection and the OBD port to toggle flags ON/OFF for certain features? Dongles like the Veepeak OBDCheck BLE act a comms bridge between the phone app and the car's ECU/DME: - the BLE is used to receive commands from apps residing on the phone [primarily a half duplex communication as it always listens for phone commands; normally it won't allow to 'write/send' anything back to the phone, with perhaps the exception of an ACK - acknowledgement flag] - while the CANbus wiring system is used to communicate and control various microprocessors inside the car [this is a full duplex with asynchronous Read/Write capabilities] Maybe I got this wrong, but to my knowledge, at a very high level the data flows this way: 1. The BLE (Bluetooth Low Energy) is used to communicate to the phone app itself. A certain command is set from BimmerLink/BimmerCode apps, then sent to the OBD port via the BLE communication protocol running on the dongle (e.g. VeePeak) 2. Using the OBD port, the dongle 'receives command', and it then sends it via the CAN bus wiring system to the ECU for execution 3. For any flag/feature to remain permanent, the appropriate command needs to be written such that the ECU stores it. If my simpleton explanation above is true, why would the BLE connection need to always be on for a more permanent approach? Feel free to correct any statements, I'm a student of knowledge and wish to learn how things work. Last edited by No_curebimmer; 08-13-2020 at 11:14 AM.. |
08-13-2020, 10:42 PM | #75 |
~Spyder
638
Rep 870
So, this evening I received my Veepeak OBDCheck BLE dongle; plugged it in and easily connected it via the BimmerLink beta version that Stephan sent.
It WORKS, and it works flawlessly given my short tests - definitely the exhaust burbles upon throttle liftoff are removed. I can now say that I can hear the engine winding down upon deceleration or in between shifts (my M2C is a manual not DCT, and I definitely benefit from not hearing the burbles when shifting gears - when on, they just overpowered every engine and exhaust notes). I couldn't be happier, the engine and exhaust notes are cleaner, everything sounds just unobstructed. I SIMPLY LOVE IT -- Fantastic Job Stephan! Everything took barely 24 hrs to implement, from the moment I emailed him with a request to this evening's tests. Now that's TOP NOTCH support! The attached crappie mobile phone videos (sorry about the quality) are taken in my garage just this evening; didn't want to rip open the throttle as it was past 21:00 hrs and neighbors would have killed me. https://drive.google.com/drive/folde...20?usp=sharing (edit: both video clips were taken with Sport+ mode, engine fully warmed up) Highlights/Cliff Notes: 1. engine + exhaust notes are cleaner, unobstructed by the burbles. Without the burbles, I could hear what was happening under the bonnet and behind me. Before this, I had no idea how much the burbles covered up most of that action (especially in Sport+ mode) 2. Primarily tested in Sport+ mode, ASD and Exhaust Flap ON 3. My '19 M2C is 6 speed, with everything STOCK, even the exhaust. 4. The feature that was implemented in the BimmerLink to turn off burbles is called "Sound Tuning" 5. Change seems to be permanent - the car's ECU seemed to retain whatever changes I made, even after I disconnected the Veepeak and the app (stopped by the grocery store - burbles remained off when drove back home) 6. The car threw NO ERRORS 7. For some test samples, I kept the dongle connected to the car so I can make changes on the fly and test back to back: burbles ON vs. OFF. I can say without a doubt that I very much prefer the car without the burbles. To me they just sounded artificial, masking everything else that the engine and exhaust produce. The Take-away: the car now sounds like my old E46 330ci which I absolutely loved. The resulting sound is clean, guttural, sort of naturally aspirated. A truly gentleman's sports car noise, and that's how the Bavarians should have implemented from the factory. Thank you Stephan @BimmerLink/BimmerCode - you ROCK! Edit: the crappie videos above really do no justice...everything sounds x-times better in person. Bye-bye burbles!!!! Last edited by No_curebimmer; 08-14-2020 at 09:41 AM.. |
8
Daytona_550463.50 Lost in München43.50 JustinHEMI7445.00 Gizmo 335i370.00 ebisu81079.50 CSBM52722.50 Commanderwiggin2050.00 Capt Canuck704.00 |
08-14-2020, 07:56 AM | #77 |
Dom
1080
Rep 1,718
This is incredible! Is this widely available for everyone? I checked now and didn't see it as an option.
08-14-2020, 08:06 AM | #78 | |
~Spyder
638
Rep 870
I know this is a personal choice, no burbling for me at least. Until I tried it, I could not believe how much interference the burbling had with the natural engine and exhaust sounds...
ebisu81079.50 JustinHEMI7445.00 |
08-14-2020, 08:08 AM | #79 | |
Dom
1080
Rep 1,718
08-14-2020, 08:37 AM | #80 | |
Rep 621
08-14-2020, 09:34 AM | #81 | |
~Spyder
638
Rep 870
Anywho, I can confirm that burbles can definitely be easily turned off via BLink, I just need to do more extensive tests over the next few days to see if state changes remain permanent once the engine is turned OFF and without the Veepeak dongle plugged in and actively communicating w/ the BLink app. My ultimate goal is to "set it & forget it"...if you ever heard the E46 330ci engine/exhaust notes, you'd know what I mean, it was one sweet sounding machine. Now my stock M2C is dang-close to that. I wouldn't be surprised if this would become one of the most used/wanted feature in BimmerLink, as I can't stress enough how much cleaner the overall sound experience is without the burbles. **Again, this is a personal opinion and in no way I'm downplaying those who prefer the deceleration pops...they do sound cool and mean in their own right, just for me they mask whatever engine+exhaust action is going on** Now: should I get the full Dinan exhaust (from the downpipes onward) or wait for the AA equal length mid-pipe? Unsure if there's a price set yet for the EL AA midpipe, but it should be less than a full exhaust piping. |
08-14-2020, 10:58 AM | #83 |
~Spyder
638
Rep 870
08-14-2020, 11:28 AM | #84 | |
Rep 621
08-14-2020, 03:57 PM | #85 |
Rep 1,153
Is it just me, and I haven’t read this entire thread, but I seem to get way less burbles with traction control fully off. I’ve noticed on a few occasions. Just me?
08-15-2020, 01:54 AM | #86 | |
Rep 555
Good to know that you can turn off the burble permanently. I always wanted to get rid of that immature sound out of my car lol
IG: M2C_SO |
08-17-2020, 01:20 PM | #88 |
~Spyder
638
Rep 870
Usability update:
1. To recap, I've used a beta version of BimmerLINK app for iOS to remove the burbles (not yet available in the app stores) 2. removed Veepeak dongle from the OBD port- so there is no live connectivity between the app and the DME 3. Used the car several times over the weekend (with multiple engine starts/shut downs): the status remained unchanged...the burbles remained completely off!! This needs to be said again: I enjoy driving the car far more since I've coded out the burbles. Besides full car PPF (SunTek) and tinted windows which are cosmetic, this is the only 'tech mod' I've done, and it surely transformed the driving experience. Highly recommend it and super happy that Stephan @BimmerLink made it happen! Last edited by No_curebimmer; 08-17-2020 at 04:51 PM.. |
Lost in München43.50 |
