M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > M2C missing part of intake piping.
      03-13-2020, 05:55 AM   #89
Carbon_73
Russia
23
Drives: M2 Competition
Originally Posted by Commanderwiggin View Post
Carbon_73 what all did you remove to do the install/cutting properly? Looks like front bumper and possibly the headlights?
Removed the bumper and headlights.
      03-13-2020, 08:02 AM   #90
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Originally Posted by Carbon_73 View Post
No changes! Looks like from the factory : Thumsup:
Nice wheels fella - specs ?
Current '22 X3M LCI..
      03-13-2020, 10:58 AM   #91
Dav3
Dav3's Avatar
949
Drives: G87 M2/E89 35is/F21 M140i/GT4
Nice install!
How did you get around cutting the platic?
      03-19-2020, 03:29 AM   #92
Carbon_73
Russia
23
Apex EC-7
front: R19*9.5 ET28. Pirelli Trofeo R 265/30/19
rear: R19*10.5 ET45. Pirelli Trofeo R 295/30/19
      03-21-2020, 02:42 PM   #93
ROBM2C
ROBM2C's Avatar
Drives: BMW M2C , DATSUN 260z, Porche
These are fully factory-made parts from M3/M4. Everything is installed without problems! You only need to cut holes in the plastic.
Without 3D ))))
Nice fix ! Good job brother ! Thanks for the part #s too !
      03-21-2020, 02:57 PM   #94
flybigjet
Remove Before Flight
flybigjet's Avatar
Drives: M2C & Boeing's light twin
Nice work, Carbon_73 -- parts are now on order.
Query: Now that you've done this, do you think it could be done without removing the headlights and front bumper?
If yes, yay. If no, I'll keep them on hand until I upgrade the intercooler. No point in pulling the front clip once.
Thanks again!
      03-21-2020, 03:27 PM   #95
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
Thanks again!
The space to work with in the M2C is extremely tight, I'm guessing removal of the front bumper is a requirement for reworking the intake plumbing..
      03-22-2020, 04:18 AM   #96
JonLo
JonLoTW
Taiwan
Drives: BMW E36 Z3
Hi, everyone.
I installed corner pipes (13717613156, 13717613157) and meshes (13718507321) from the M3/M4 on my M2C. Everything works perfectly!
Hi Carbon_73,
Did you notice any change on IAT and throttle response after you install that?
      04-24-2020, 01:10 PM   #97
Project_F87
Project_F87's Avatar
Drives: 2020 M2C LBB 6MT
Originally Posted by Malakas View Post
That looks awesome.
I redesigned the elbow and included a ram air scoop. Also I tried to move it a bit forward .... Prototype 1 was tested, but there were some issues ... So on to prototype 2.
I've been luck enough to consult with some pro mechanics via a friend and discuss airflow velocities etc... Will present my findings here once completed.
Any updates on this/any way I can help also? Got quite a bit of experience with fluid dynamics
Instagram: @Project_F87
Malakas469.50
      04-25-2020, 09:07 AM   #98
Malakas
Drives: 2020 M2c
All thoughts are def appreciated.... will be tearing things apart to day to fit a prototype before I print a "final piece". I was able to re-design (due to extra home time) over and over, until I got rid of all the sharp bends, now its a more fluid shape which should decrease turbulent flow (ideally). Shoot me a DM with your email...
Ride: 2020 F87 M2C, 6MT Drive: Nine-Four Motorsports
Before:
2013 - 3.8L GTR, first DCT
2012 - 5.2L R8 v10, 6MT
2011 - 4.0L E92 M3, 6MT
      04-25-2020, 12:01 PM   #99
speedsnice
Drives: 2020 M2 Comp
I am interested in purchasing scoops of you decide to sell.
2023 X3 M40i @b58x3
2020 M2 Competition @s55m2
      04-25-2020, 12:04 PM   #100
Malakas
Drives: 2020 M2c
I think all members here can be part of a "development program" ;-)...
Before:
      04-25-2020, 01:32 PM   #101
flybigjet
flybigjet's Avatar
Ok-- color me confused.
In this thread, the first part says "M4 intake parts won't fit, need to fabricate other parts".
Later on, it says, "M4 elbow and grill fit great with no mods/parts other than cutting two holes in plastic".
Now, it's "Need to 3D print parts".
What is it?
TIA.
R.
Venom375.00
msdss497.50
      04-25-2020, 03:19 PM   #102
Malakas
Drives: 2020 M2c
What is it?
TIA.
R.
The m3/m4 elbow joint will fit. It snaps in to the intake snorkel and then you need to cut the plastic trim so it has an opening for the cold air. That is an option.
The question I had was whether a piece could be made that does not require a 90 degree turn of the airflow - which while definitely better than stock ( which is closed off) - maybe less than optimal in terms of flow velocity, volume, and turbulence.
So I've been crafting a new 3D printed piece that fits into the stock intake snorkel and then allows a straighter path to clean air. Below are some of the mock ups I used just to test the measurements and the interface. It is NOT the actual design of the snorkel.
There are additional questions here: the stock BMW piece is narrowed already (see the picture) - does this matter? Unclear.
Will there be any difference in air flow between more of a ram air scoop and the stock m3/m4 piece? Unclear. My guess is that at slow speeds they would be the same and at higher speeds the ram air would push more air in... again it remains to be tested.
My plans include IAT comparisons and then we will dyno before and after with the biggest fans we can find. Then of course, we will get some track laps.
If nothing else, its been a fun project during these crazy times at home.
Before:
Appreciate 9
flybigjet6822.00
Poochie9104.50
hlm2c289.50
ashtaron141123.00
prompt292.00
Wah2778.50
cncmastr1590.00
      04-27-2020, 10:51 AM   #103
Project_F87
DM sent!
      04-27-2020, 12:51 PM   #104
Commanderwiggin
Commanderwiggin's Avatar
2050
Drives: M2C - X3M - Turbo E46 M3 - 45E
Count me in for a set when you have the final design!
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration
1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder
      04-29-2020, 07:58 PM   #105
speedsnice
I installed the passenger side elbow today, any tips for aligning the headlights? They have adjustments from every angle.
2023 X3 M40i @b58x3
      05-01-2020, 03:49 PM   #106
Project_F87
Which website did you order these from?
Also what are the part numbers?
      05-01-2020, 04:05 PM   #107
flybigjet
flybigjet's Avatar
BMW M3/M4 intake ducts
- Intake duct, left (13717613157)
- Intake duct, right (13717613156)
- Intake grill x2 (13718507321)
Appreciate 5
speedsnice1204.50
BAN_M2C4185.00
msdss497.50
Wah2778.50
omasou2088.00
      05-14-2020, 02:57 PM   #108
Malakas
Drives: 2020 M2c
https://f87.bimmerpost.com/forums/sh....php?t=1720577
First full prototype
Before:
      05-15-2020, 01:57 PM   #109
SEAT TIME RULES
SEAT TIME RULES's Avatar
1103
2020 BMW M2C  [5.00]
I was the OP for this thread and its great to see Malakas producing these parts.
As I mentioned in my first post intake temps are only 10-15 degrees warmer than actual outside temps.
They are higher when the car is moving slow, or idling of course. The 10-15 degree difference is after a few minutes of decent speed driving, I doubt the OEM setup will record such a low difference.
I made some bends from used plastic containers and sealed them. Turbo cars love cold air in their intakes :-)
2004 Mazda Rev It Up Finalist
2002-Present HPDE Instructor
      05-15-2020, 05:24 PM   #110
msdss
msdss's Avatar
Drives: Alpine White 2020 BMW M2C
So you were able to fit the OEM M4 parts w/o any issues or modifications?
