BMW M2 Forum > BMW M2 Discussions > What did you do to your M2 today?
      12-06-2020, 02:30 AM   #6887
SebsM2
SebsM2's Avatar
652
Drives: 2017 LBB M2
Originally Posted by AndrewC1989 View Post
Originally Posted by MONSTAR View Post
Highlighter yellow?
Not quite
This is too sick! I actually just got quoted for a satin dark bronze. I think it'll look pretty good against LBB. The only thing stopping me right now is that I just wrapped my roof black so I figured it may look weird.
Instagram: SebsM2
Build thread: A Tastefully Modded FBO M2
AndrewC198910931.00
      12-06-2020, 02:37 AM   #6888
SebsM2
SebsM2's Avatar
652
Drives: 2017 LBB M2
Wrapped my roof gloss black. Everyone local quoted me $400-$750 so I decided I'd take a stab at it before I get it done professionally. It turned out to be super easy with a second set of hands. Total cost of the project was $88 (wrap and Amazon tool kit) and a few hours of work. Really love how this car is coming together. Doing all the work on this car with friends makes it even more special.
Also ordered a restore44 front lip to replace my OEM winglets. Got it off another forum member for a great price. Now to source hardware... anyone have a clue what comes with these lips?
Instagram: SebsM2
AndrewC198910931.00
bollinm25.00
      12-06-2020, 02:58 AM   #6889
JustDrifting
JustDrifting's Avatar
232
Drives: BMW M2C
Originally Posted by BMWF87Melb View Post
Great - thanks for that. Might have to give this a shot myself then!
I installed an MP diffuser a few weeks ago. Here's a few tips:
1. There are 6 plastic 'push pin' rivets - unless removed these before it might not be immediately obvious that the central head needs gently prised away/out from the surround and then the pin will easily pull out. Use a thin flat head screw driver or edge of a blade working opposite sides of the head.
2. The outer two most locating pins are 8mm bolts with locating brackets behind on the bumper; very easy out/ in.
3. The original plastic diffuser has additional plastic guards around the exhaust (heavier plastic than the diffuse) presumably to prevent heat transfer around the exhaust pipe outlets - the do not get reinstalled with the MP / carbon diffuser.
4. A set of still plastic trim tools to release the clips works a treat; used a few layers of masking tape on the bumper surface (around the location of the clips) so as to not mark the paint when pressing the tool in / the clips popping out. Also, working a few of the release clips at a time seemed to ease the release (rather than one by one).
5. The install of the MP diffuser was very quick, simply pops into place with a little pressure/ short sharp pushes. Easier with two people to align the whole diffuser and working the outer edge in.
6. Some threadlock for the outer two screws is worth it as they are not particularly torqued (or will damage the carbon).
Hope this helps
Appreciate 4
AndrewC198910931.00
akkando5864.50
bollinm25.00
Fugly M35078.50
      12-06-2020, 04:14 AM   #6890
MikeF87LCI
MikeF87LCI's Avatar
Drives: BMW F87 M2C
Highlighter yellow?
Not quite
These look great... can't wait to see pics of them on the car!
AndrewC198910931.00
      12-06-2020, 07:01 AM   #6891
eldogo
eldogo's Avatar
Tanzania
274
Drives: BMW 328xi BMW X5 F15 BMW M2
2017 BMW M2  [0.00]
Charge pipe and boost pipe replacement
FMIC
Colder spark plugs
Got them done at TTFS for those in the DMV area.
Here's a video
      12-06-2020, 06:00 PM   #6892
SebsM2
SebsM2's Avatar
652
Drives: 2017 LBB M2
Originally Posted by artbrunson View Post
Originally Posted by SebsM2 View Post
Well, what I added was the full screen part of it. I had CarPlay from factory. Unfortunately, it defaults to 60/40 screen split and there is no way to change it without coding.
The appeal of Apple CarPlay in general is that it provides a similar interface compared to your iPhone. Plus, it handles text messages a lot better than bluetooth or bmw software.
If you have an iPhone and are a bit older, I think it's a beneficial add on to retrofit since it's one less interface to learn.
I had him add Carplay for my X3 to test it out and it works fine but 60/40 of course. He was very prompt and did it same day so great job! Apparently he has to spend an hour and $130 coding the car (the M2 would be also) to get it full screen. That includes jumper cables to a 2nd car for power he said, and that's too much work for me. Did you go through all of that? How was it?
No. Nothing like that. I plugged in an enet cable and pressed a button on my computer lol
Instagram: SebsM2
      12-06-2020, 07:45 PM   #6893
BMWF87Melb
Drives: VW Golf
Hope this helps
Great - thanks!
The instructions are much appreciated. I'm much more confident now hearing more first hand experience that the stock diffuser isn't too hard to get out.
Your car looks great too!
      12-06-2020, 08:51 PM   #6894
SebsM2
SebsM2's Avatar
652
Drives: 2017 LBB M2
Here's a better pic of the roof wrap
Instagram: SebsM2
      12-06-2020, 10:12 PM   #6895
rcouchh
rcouchh's Avatar
Drives: BSM G87
Not quite
Hey that's my buddy's shop
AndrewC198910931.00
      12-07-2020, 03:29 PM   #6896
MikeF87LCI
MikeF87LCI's Avatar
Drives: BMW F87 M2C
Added some carbon 😎
Appreciate 6
MONSTAR517.00
AndrewC198910931.00
SebsM2652.00
cb8042351.00
GPGP226.50
      12-07-2020, 11:56 PM   #6897
SebsM2
SebsM2's Avatar
652
Drives: 2017 LBB M2
Put in the eton front speakers after having to order a second set after I bought some broken ones from a forum member
I was so impressed with the sound quality that I went and ordered the rear shelf JL speakers too.
Instagram: SebsM2
      12-08-2020, 06:45 AM   #6898
WOT Bimmer
WOT Bimmer's Avatar
Drives: 2018 BMW M2
That's awesome! I've considered doing this. Any close up pics? Tips or comments on the DIY?
      12-08-2020, 08:24 AM   #6899
SebsM2
SebsM2's Avatar
652
Drives: 2017 LBB M2
There are more pics here:
I followed this video:
A couple of tips:
1. get a good tool kit on Amazon
2. Get a high quality wrap
3. Work slowly
4. Have a second set of hands to help
5. Use a heat gun
Instagram: SebsM2
dtmurf481.50
      12-08-2020, 11:31 AM   #6900
dtmurf
dtmurf's Avatar
482
1996 BMW 318is  [4.75]
2012 Audi Q5  [4.50]
2017 BMW M2  [10.00]
Nice job! I've consider this but I can't make up my mind about changing out the kidney grille from chrome to black...I'm usually pretty decisive but I keep going back and forth on it.
Maybe if I did the roof, the kidney grille issue would work itself out lol
'17 M2 DCT Long Beach Blue
      12-08-2020, 11:39 AM   #6901
lax01
Drives: 2017 M2
Delayed weekend post:
Drove to Cambria and had a socially distant weekend getaway:
Then drove to Paso Robles and parked under the container we stayed in:
      12-08-2020, 12:56 PM   #6902
MikeF87LCI
MikeF87LCI's Avatar
Drives: BMW F87 M2C
Busy few weeks for new car additions...picked up some genuine bmw angle cut exhaust tips from eBay dirt cheap. Installed this evening took a few pics. Undecided if to keep the chrome or paint them.
      12-08-2020, 01:33 PM   #6903
SebsM2
SebsM2's Avatar
652
Drives: 2017 LBB M2
I think it depends on how much chrome you have/plan on keeping on the rest of the car.
Black tips will look cleaner for longer!
Instagram: SebsM2
JMon3y26.00
      12-08-2020, 09:30 PM   #6904
JMon3y
Josh
JMon3y's Avatar
2019 BMW M2  [0.00]
Added some Carbon Fiber! I think it looks better than the silver.
dtmurf481.50
WOT Bimmer1226.50
cb8042351.00
      12-08-2020, 09:32 PM   #6905
TT1351
TT1351's Avatar
508
Drives: 135, GTS, E30 M3+
Installed Euro warning triangle in trunk.
      12-08-2020, 10:03 PM   #6906
M2Power
Carbon does look nicer. Where did you pick these up?
JMon3y26.00
      12-08-2020, 10:10 PM   #6907
JMon3y
Josh
JMon3y's Avatar
2019 BMW M2  [0.00]
Though the dealer, they are OEM. It's an easy install. My only complaint is that they make you buy them individually.
      12-09-2020, 09:23 AM   #6908
ae03440
ae03440's Avatar
240
Drives: 18' M2 & 20' X3 M40i
Not quite
Any pics of these installed?
