07-22-2019, 11:20 PM | #1 |
Rep 31
2016 M2 turbo upgrade: worth it?
Those original 2016 M2 owners who have upgraded their turbo here's my question for you: have you found it worth the while for daily driving or track use? My mods are bm3, Wagner IC, akra exhaust, charge pipe and 200 cell downpipe. Appreciate your inputs!
07-22-2019, 11:43 PM | #2 |
Rep 1,122
I upgraded my OG M2 when I had it with Dinan big turbo setup alongside having full bolt on. Some decent power but if I had to do it again I would if gone with pure. Ultimately I don't think it was worth it for me. I know have a M2C
07-23-2019, 05:50 PM | #5 | |
24198
Rep 190,805
There is a lot more power to be gained by changing the map
07-23-2019, 06:31 PM | #6 | ||
Rep 314
Kiel McCaul
07-25-2019, 11:58 AM | #7 |
Rep 228
Can you elaborate as to why you would go with a pure setup? I probably will be upgrading my turbo in the future and want as much knowledge as possible. Thanks!
07-25-2019, 01:20 PM | #8 |
enthusiasm > practicality
4021
Rep 2,247
Drives: 987 CS | G35x
Pure (stage 2 turbo) is used when ~400 whp just doesn't cut it as with a stage 1 turbo (Dinan or Pure S1). Pure S2 can provide ~500 whp with supporting mods which makes for an absolute beast of a car. The main drawback is increased lag which can be irritating for daily driving. Another drawback is traction issues. For the street, a stage 1 turbo (Dinan or Pure S1) is more than sufficient. I'm running 295 PS4S rear rubber and still break loose in the first 3 gears during WOT in hot temps. I could only imagine what sort of havoc another 100 whp would do.
07-26-2019, 10:39 AM | #9 | |
Rep 228
07-26-2019, 12:23 PM | #10 | |
4021
Rep 2,247
450 whp isn't possible with this setup, no matter how good the tune is. Gotta go stage 2 with perhaps upgraded fueling. I think the M2's N55 with its forged internals can handle the added boost, just not sure how long before problems arise.
O Haiii191.50 |
07-29-2019, 11:47 PM | #11 | |
Rep 199
07-30-2019, 07:56 AM | #12 | |
4021
Rep 2,247
Adding stage 4 tune (with turbo) should net you 62 more whp (89whp [101 max advertised gain] for stage 4 minus 27 after removing stage 1). All of this math allegedly gets you to 430 whp which just isn't right. It's too high of a number. Dinan's advertised 101 bhp increase is too generous. Again, ~400 whp with stage 4 plus the downpipe is pretty accurate.
JTO245276.00 |
07-30-2019, 11:40 AM | #13 | |
Rep 228
Thank you for the simple yet informative info - makes a lot of sense now. I wish you were local to me so I can ask you for a test ride haha. How extensive is the installation of the "big turbo"? Something you can diy? |
07-30-2019, 01:11 PM | #14 |
4021
Rep 2,247
Unless your're really skilled, go to a local mechanic or BMW dealer. It shouldn't take long as it's a bolt-on component.
07-30-2019, 10:56 PM | #16 | |
Rep 390
Not sure why so many people are against. BMW builds a solid engine. Only upside to the N-series is the fact that it's a simpler design to work on....less to go wrong....but it certainly can make enough power that it becomes stupid on this platform. Why some folks want 600+ hp when more capable vehicles(better brakes/lighter weight/better layout) have less is beyond me.....think the new Vette. |
07-31-2019, 04:04 AM | #17 | |
Rep 2,577
The issue is in the M2 stock calibration which dumps too much fuel up top, trading power for a cooler in-cylinder temp so it can last WOT for a little longer. And piggyback can do very little about the AFR. There're many lesser N55s (even the PWGs), when flashed, making more power with less boost than M2 stock. The leaner AFR is one key to that. Among all N55s, the M235i works with Piggyback the best thanks to its good AFR setting from the factory. M235i is fact closer than M2 to obtaining 400whp from Dinan STG4 PKG. It's a very old and nerdy topic (piggyback vs flash) so I'll stop there. As matter of a fact, piggyback solution is long gone. The only market for it should be the PI/WMI integration and/or very high boost (22+psi) applications. @op Is M2 N55 turbo upgrade worth it? No, the M2 N55 is a very low tuning value in the first place. I started a thread last year for it, go check out. https://f87.bimmerpost.com/forums/sh....php?t=1551866 However, if we don't look outside of N55 platform, the fact that downpipe adds 10~15whp for 500~1000 USD and intercooler/intakes zero, makes the turbo upgrade look not bad. Going for 400+whp, bigger turbo is pretty much a requirement. And 450+whp is STG2 turbo territory. Between 400~450whp, there're various setups for different purposes. Below are a few setups I recommend with rough cost estimate. ~400whp: FBO + Flash + Good octane/Ethanol = 2k5 USD + Labor. ~420whp: FBO + STG1 turbo + Flash + Ethanol = 4k + Labor. 450+whp: FBO + STG2 turbo + Flash + HPFP+ Ethanol/Race Gas = 6~7k + Labor 500whp: FBO + STG2 turbo + Flash + Piggyback + WMI = 7k + Labor 500+whp: FBO + STG2 turbo + Flash + Piggyback +WMI + HPFP+LPFP + Ethanol/Race Gas = 9k + Labor Apparently there's diminishing gains like every other platform going up on power, especially above 400whp. Worth it or not everyone has an angle of looking at it. To each its own.
Lemania 2320
07-31-2019, 06:52 AM | #18 | |
4021
Rep 2,247
Check out post 56...It shows a 63 whp over stock with stage 4 plus downpipe. Baseline is 319whp (low reading). Therefore, if 330whp is a typical baseline, adding another 63 gets you to 393whp which is ~400.
07-31-2019, 10:04 AM | #19 | ||
Rep 31
07-31-2019, 10:22 AM | #20 | |
Rep 2,577
If you install WMI on stock turbo, better try ethanol and/or octane booster first as they work just as well if not better and they're free.
Lemania 2320
Louzy779.00 |
07-31-2019, 10:35 AM | #21 |
Rep 2,700
Having been trough all this with my past 135i N54, Stage 2 Turbos, wmi etc etc. The more I think about it, ordering an M2cs or buying a used M2 Comp would almost make more sense in my track/wknd car ownership..
07-31-2019, 02:09 PM | #22 | |
Rep 390
Some of us can't justify the financial loss from trading in...but it is nice to see there are options to upgrade for us. Just have to be willing to pay to play. |
