Classifieds Section > Sponsors Classifieds > HP Autosport ||Macht Schnell Competition Wheel Spacer Kit
      09-23-2022, 11:47 AM   #177
HP Autosport
Drives: F80 M3
bump
      10-11-2022, 09:26 PM   #178
HP Autosport
Drives: F80 M3
bump
      11-02-2022, 09:08 PM   #179
HP Autosport
Drives: F80 M3
bump
      11-29-2022, 11:00 PM   #180
HP Autosport
Drives: F80 M3
bump
      12-15-2022, 05:58 PM   #181
HP Autosport
Drives: F80 M3
bump
      01-04-2023, 04:43 PM   #182
HP Autosport
Drives: F80 M3
bump
      01-24-2023, 08:35 PM   #183
HP Autosport
Drives: F80 M3
Machined from 6061-T6 aerospace aluminum, these adapters are strong as well as lightweight to limit unsprung/reciprocating weight for maximum performance on or off the track. Spacer edges are also chamfered to allow for easy installation/removal if needed. After machining, the spacers are then anodized for additional strength, anti-corrosion & wear resistance.
A wider track stance increases lateral stability as well as giving your BMW a much more aggressive appearance after installation. Spacers also are used to correct wheel gap normally seen on otherwise stock suspension setups, pushing the wheels outward - filling the fenders.
Included with our Competition Wheel Spacer Kits are a full set of extended lug bolts. All wheel fasteners are hardened and tempered to strength class 10.9 or 10 according to DIN/ISO standard 898 and meet the statutory requirements of all countries - including the US.
Competition Wheel Spacer kit Features:
- Machined from 6061-T6 aerospace aluminum
- Chamfered edges allows installation & removal quick and easy
- Black anodized finish for additional strength and corrosion/wear resistance
- Improve handling by reducing body roll with a wider wheel base
- Included zinc plated corrosion-resistant wheel fasteners
Competition Wheel Spacer kit Contents:
- (2) Competition Wheel Spacers
- (10) extended-length zinc plated coated wheel fasteners
      02-13-2023, 08:05 PM   #184
HP Autosport
Drives: F80 M3
bump
      03-06-2023, 01:06 PM   #185
HP Autosport
Drives: F80 M3
bump
      03-22-2023, 08:56 PM   #186
HP Autosport
Drives: F80 M3
bump
      04-05-2023, 07:08 PM   #187
HP Autosport
Drives: F80 M3
bump
      04-25-2023, 02:14 PM   #188
HP Autosport
Drives: F80 M3
bump
      05-23-2023, 05:39 PM   #189
HP Autosport
Drives: F80 M3
bump
      06-13-2023, 03:52 PM   #190
HP Autosport
Drives: F80 M3
bump
