05-25-2020, 11:25 PM | #45 |
Rep 7,527
Bolt could have been vibrated loose gradually over time, so it just happened to loosen up now. If this was the case it doesn't matter how much power it made, it could occur stock or modded.
05-26-2020, 01:51 AM | #47 | |
Rep 4,976
Current Car: 2018 F80 M3CS, SMB, DCT, ZEC, MPE Recently Departed: 2020 F87 M2C, LBB, ZEC, 6MT (Euro Delivery Aug. 29, 2019, totaled by an idiot in a Camry who then ran from the scene) Wife's Prior Car: 2018 F80 M3, Yas Marina Blue, DCT, Black 19s, Carbon Structure Anthracite Cloth/Leather Combination, Driving Assistance Package (Euro Delivery Oct. 9, 2017) |
05-26-2020, 05:42 AM | #48 | ||
Rep 7,594
Drives: '19 M2C
Of course you increase your chance of a SCH with a tune regardless of transmission.
www.ReTuneTheDeTune.com
05-26-2020, 11:40 AM | #49 |
Rep 1,122
Ok so I've decided to take it to Vargas turbo's instead of performance technic. Vargas supplies the part so it makes sense to have them do the labor as well all for $3500 bucks. Now.. this is all not knowing the extent of my problem. Did it just slip or cause physical damage to the engine? I'm hoping because the car starts and was drivable it's the latter. I'll keep you guys posted later on today.
05-26-2020, 11:46 AM | #50 | |
Rep 1,295
05-26-2020, 12:30 PM | #51 |
Rep 1,122
Well just spoke to the shop and they're not gonna get to my car until next week! Pretty fucking annoying considering that's a pretty important detail to share. Exactly why I just wanted to go to performance technic!!
05-26-2020, 12:35 PM | #52 |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
Ah man.... that's super frustrating and not cool they didn't let you know prior to taking it to them.
-2021 M2C, HS, 6MT
-AST 5100, AP Racing 9660, BMW-788M, RF-GT4, BW-TA5R, APR GT 250 Wing & Front Splitter -TMS Diffuser, TMS F80 Skid Plate, HEX Armor PPF, CAN-Checked Data Logger, RaceBox -Recaro Pole Position , 2kBody Half Cage, Pinnacle Motorsports Half Cage (On order), CAE Shifter -Remus Race + BR EL Mid |
05-26-2020, 12:56 PM | #54 |
Rep 1,122
Well some good news as I'm msg back and forth with the shop. Was told that if the car starts and is driveable that I dodged a bullet and would more than likely just replace the hub and time it back. 🤞🏼🤞🏼🤞🏼🤞🏼
06-01-2020, 07:18 PM | #55 |
Rep 1,122
Wow, ok just got done speaking to Tony at Vargas turbo's and after inspection, codes read I not only spun the crank hub but on the verge of severe engine damage.
To put it in his words "We did not see any more damage, but you got REALLY REALLY lucky the timing was 2-3 teeth off which is a LOT. No engine damage from what we can tell. Count your lucky stars." |
pz6193280.00 chiefsubjugator90.50 |
06-01-2020, 07:55 PM | #56 | |
Rep 4,976
twboy1999290.50 |
06-01-2020, 08:03 PM | #57 | |
Rep 3,660
Drives: 981 Cayman GTS
This is exactly why I recommended him a few posts ago not to even let the car idle, let alone driving couple miles to a nearby shop. Just because the car still runs and is drivable after those DME error codes doesn't mean it's ok to run it. |
Thescout134947.00 msdss497.50 |
06-01-2020, 09:40 PM | #58 |
Rep 1,122
And after I pulled the codes I didn't turn the car on at all. It was towed right from my garage and thankful I did because yes I could of easily damaged more than just the crank hub. Looking forward to getting her back but this just leaves me unsure if I should follow through with a custom e85 tune I was planning to do.
M-Pilot4861.50 |
06-02-2020, 01:42 AM | #59 | |
Rep 6,638
06-02-2020, 08:03 AM | #60 |
Rep 24
06-02-2020, 10:44 AM | #61 | |
Rep 1,295
The general consensus is that the fix is basically 100% effective at preventing SCH again in the future while the bolt capture is “highly unlikely” but not impossible to not spin again. Whichever solution you get, you can also just do stage 2 (tune + downpipes) and pump gas for a while and go from there.
06-02-2020, 12:32 PM | #62 |
Rep 1,358
What's the cost spread between CBC and full up hub fix? At this point I would go full monty and be done with it. Then you are free to do whatever you want at any point in the future and never worry about it again.
06-03-2020, 12:17 AM | #63 |
Rep 1,122
Think it'll run you the same amount anywhere from $3-4k. To get it done at Vargas turbo's it's running me $3500 including their crank hub fix.
06-03-2020, 02:38 AM | #64 | ||
Luxury at the redline :)
9108
Rep 7,563
Bolt/plate capture is band-aid solution, not a true fix. A solid, single piece crank hub is the only permanent remedy, as far as I see. |
06-03-2020, 04:20 AM | #65 | |
Rep 7,527
Correct. The CBC prevents the bolt from vibrating loose which will cause severe engine damage as that means the whole hub will slip. However just because the bolt cannot back out doesn't mean friction of the grip disk cannot be broken leading to a slip, thus the CBC itself is not a full solution you also need a one piece crank hub meaning the timing gear is affixed the hub. The hub also needs to be either pinned to the crank which requires drilling of the crank, or somehow secured aka splined to the crank like the VTT spline lock crank hub. Also note the one piece crank hub itself is not a fix alone either because the bolt can still come loose via vibrations, so you will still need a CBC.
Poochie9107.50 |
06-03-2020, 12:34 PM | #66 | ||
Rep 6,638
https://f80.bimmerpost.com/forums/sh....php?t=1588786 |
