01-08-2024, 01:05 PM | #23 | |
Rep 7,429
01-12-2024, 08:49 PM | #24 |
Rep 14
01-13-2024, 12:09 PM | #25 |
24198
Rep 190,807
My issue with silicone charge pipe is the higher failure rate. I'd rather get an aluminum pipe with better reliability than risk it for an unknown and minimal improvement in IAT
WeekendWarriorz670.00 FMOS Racing117.00 |
02-06-2024, 09:29 AM | #26 |
Rep 139
Drives: '20 BMW F87 M2C
I know this post is about charge pipes.. but for what it's worth, I've known of two TMICs (one being mine) that failed and began leaking coolant into the intake manifold. In both cases, it was hard to determine that there was a leak just from inspection on the outside. No codes, etc. We were only informed by a drivetrain malfunction warning when the car was under load/boost (at the track). If you drive normally and don't constantly do any pulls, it's hard to tell you have an issue since no codes are thrown.
Like those said, it's a common failure but should be under warranty and can be replaced by the dealer. I ended up replacing mine under warranty, but I still have a brand new Mishimoto intercooler waiting to be installed. I guess I'm waiting for it to fail again before changing it out, but will periodically check the coolant reservoir to insure there's still coolant. https://f80.bimmerpost.com/forums/sh....php?t=1570544 |
m2ss1790.00 |
02-06-2024, 11:07 AM | #27 | |
24198
Rep 190,807
I recommend closely monitoring the top cooler since it's prone to failure, especially as these cars get older, it'll only get worse
okla_m2c96.50 |
02-06-2024, 11:41 AM | #28 | |
1922
Rep 4,922
I've had the same issue happen twice with the stock cooler as well and it took me awhile to get a code for it. Luckily I started noticing extremely high Iats because the car never threw a light till I did a extended highway pull. As far as the charge pipe's our charge pipe work extremely well and are very durable compared to the silcoln and if you plan on doing any type of injection we have the bungs already attached as well. As with all of our products we include a lifetime warranty which takes away a lot of the stress with buying aftermarket parts.
okla_m2c96.50 |
