05-21-2021, 02:11 PM | #1 |
Rep 2,856
OPF Deleter that works is here...
Finally there is now an OPF deleter that works... You can read more about it below and check out the different versions available for 4, 6 and 8 cylinder cars: https://www.manhart-performance.de/s...f-cat-deleter/
I have spoken to the developer as well and I have heard from a fair few people who use the kit that it really works! Questions? Drop them in the replies below. Copied from a product page: The MANHART OPF/GPF Deleter by LEIB Engineering has arrived. The product offers the answer to a growing demand of clients who are looking for a suitable and easy solution that deals with the removal of OPF/GPF-filters, which are installed in the exhaust line from the engine to the rear end of the Fxx and Gxx model series. The Deleter was developed by LEIB Engineering as an answer to questions from many clients on how to deal with the removal of OPF/GPF-filters in case an exhaust system is being replaced. Customers that opt for an aftermarket exhaust system on their vehicle might run into issues with engine warning messages and limp mode sequences, which could only be dealt with via an ECU/DME mapping, remap or tune. For people who want to replace their exhaust with a new aftermarket cat-back system or a non-homologated slip-on/axle back system and don’t want to ECU/DME tune their car due to warranty concerns or the fact that the ECU in their car is still locked, the Deleter is the solution since it will deal with any OPF/GPF errors accordingly. OPF-Delete Removing the OPF/GPFs from the car has major impact on BMW vehicles produced after July 2018. Specific pressure sensors are able to detect that the flow through the exhaust becomes quicker when you remove the filters. The pressure alters and the sensor will throw an error message anywhere above 5000 rpm or after a specific mileage. This means that you cannot fully use your car that might have a brand new exhaust system without disabling this sensor. The Deleter will deal with the OPF-Delete and make sure that you won’t have any errors anymore when you decide to change your stock exhaust for a new aftermarket system. Disabling the sensor via an ECU/DME tune is not required anymore. For eight-cilinder vehicles we not only deliver the OPF-Deleter, but also an additional CAN MIL Deleter. This extra tool will also be installed and is required to not have any check engine light (CEL) after changing the catalyst(s) or GPF(s). The error entry that occures by changing the catalyst(s) and/or the GPF(s) will be disabled by the Deleter. In combination with an aftermarket downpipe Customers who will install de-cat "race" downpipes, will also be able to use the Deleter alongside a CAN MIL Deleter solution, which deals with the removal of the catalytic converters. Customers who will install aftermarket "sport" downpipes, will also be able to use the Deleter. Fitting a new downpipe and removing the OPF/GPF while using the OPF Deleter product only works successfully when an aftermarket downpipe allows for the connection to the pressure sensors. You have to keep the connection to the pressure sensors in place to allow the solution to work. The new downpipe must have the two tubes, which connect to the pressure sensors which are shown on the images above. Be aware that downpipes without the pressure sensor tubes can’t be used in connection to the product shown here. Installation The plug & play installation will take about 90 minutes without cutting or soldering. The installation is possible without any prior knowledge through available and illustrated installation instructions. Alternatively, we recommend installation by a specialist workshop or one of our dealers. By using the standard or OEM automotive connectors we are guaranteeing full functionality at any time. The key important factor of this product is that you won’t have any error messages, which are generated in the memory of the engine control unit and no aftermarket engine tune is required. |
05-21-2021, 04:00 PM | #2 |
Rep 658
05-22-2021, 06:35 AM | #3 | |
Rep 2,856
MR |
05-23-2021, 03:03 AM | #4 |
Rep 16
This is great news - I am looking to get my Milltek OPF back race exhaust fitted soon. Even though I have not read any issues with this specific exhaust triggering the EML I was concerned that the only way to resolve the issue previously was via a tune which I wasn't keen on. At least now if the EML does get triggered we now have a discreet solution that doesn't require a tune.
05-23-2021, 03:25 AM | #5 | |
Rep 775
05-23-2021, 05:00 AM | #6 |
Rep 16
05-23-2021, 06:36 AM | #7 |
Rep 154
As you mentioned this cannot be used basically with any aftermarket cattles/open downpipes on the market since they don't have the pressure nipples.
I'm using AK motions Data Display with cattles downpipes and AA El OPF delete and the AK motion is working great! No problems what so ever and I get the added benefits of all the sensor readings/ data etc, and most importantly the ability to control the exhaust flaps all in one cost effective package |
05-27-2021, 02:01 AM | #9 | |
Rep 2,856
MR |
05-27-2021, 02:02 AM | #10 |
Rep 2,856
05-28-2021, 01:39 AM | #11 | |
Rep 775
05-28-2021, 03:53 AM | #12 | ||
Rep 467
///M2 CS MB - M-DCT-2 NH - GLD 763M - Cup2
05-28-2021, 01:43 PM | #13 | |
Rep 2,856
MANHART kit was offered and promised by the developer, but then never finished. Simply proved too difficult, and the new solution is way easier and a lot more effective. MR |
05-28-2021, 01:48 PM | #14 | |
Rep 2,856
MR |
05-29-2021, 02:01 AM | #15 | ||
Rep 467
Many thanks ! opf deleter ordered
05-29-2021, 03:11 PM | #16 |
Rep 54
This sounds like a good solution but there are not enough detailed instructions to reach the OPF sensors . I wanted to buy it for MINI Cooper S that my wife uses . I asked for information but a week has passed and I have not received any response .
05-30-2021, 03:40 PM | #17 | |
Rep 2,856
MR |
06-05-2021, 02:59 AM | #18 |
Rep 8,970
[QUOTE=Talx;27619530]As you mentioned this cannot be used basically with any aftermarket cattles/open downpipes on the market since they don't have the pressure nipples.
I'm sure Supersprint make decat DPs with the pressure lines for opf sensors? |
06-16-2021, 12:17 PM | #19 |
Rep 13
I installed two months ago the LEIB OPF DELETER on 2021 M2cs.
Its works fine so far.. The only issue was that it took more then 1 hour disconnect the two sensors from the stock downpipes and installing them back again Only a small hand person can do it! the rest of the work was not to complicated. |
06-16-2021, 03:06 PM | #20 | |
Rep 54
06-26-2022, 03:55 PM | #22 |
Rep 2
gents, forgive me for reviving an old-ish thread. I have an issue with opf deleter and thought I'd ask a question here.
I have an M140i (I know not relevant to this thread) and had a BCS cat-back exhaust fitted. At the same time I have installed Leib opf deleter. Car gave me limp mode after approx 400 miles. I've done a reset using ISTA by following instructions in the installation manual. actually I did it twice to no avail. Limp mode comes back when car is doing consistently above 4-5k rpm. Pressure line has been retained. Deleter seems to have been installed correctly(sent photos to a place where I bought it from) and on quick visual inspection pressure lines are intact. Need to get my car up on a ramp to check underneath but with work, all the garages are closed by the time I'm finished. I've reached out to the place where I bought the deleter and they have sent an email to Leib. Whilst I am waiting, I thought I'd ask here in case someone had a similar situation or can advise what else I can check. After deleting opf, car became alive and I can feel it's not "suffocated" anymore. really don't want to go back to stock |
