09-08-2020, 10:54 PM | #6535 |
Recovering RS4 owner
297
Rep 266
mitigated some slightly saggy exhaust tips by replacing the factory rubber hanger bushings with some polyurethane ones. Pulled things up about 1/2", which is exactly what was needed
AndrewC198910931.00 VisualEcho6636.50 Altra265.50 QM287.00 DarthFader133.50 Aust350z243.00 ///M TOWN16569.50 |
09-09-2020, 06:56 AM | #6536 | |
2530
Rep 1,908
Could you provide some pics of what you did. I can see the result, but not clear to me how you achieved the outcome. Thank you ///AVM |
09-09-2020, 07:40 AM | #6537 |
Rep 212
Drives: BMW F87 M2C
09-09-2020, 07:45 AM | #6538 |
Rep 4,551
Drives: 2015 328d xDrive
NYC Bimmer259.50 |
09-09-2020, 10:18 AM | #6539 | |
297
Rep 266
M4 gloss black slant cut tips. I removed the stock tips and cut off ~1.5" each pipe so they didn't stick out so far (2x) https://www.amazon.com/gp/product/B016AX887C |
09-09-2020, 11:48 AM | #6540 | |
Rep 4,551
I have just one side hanging a tad lower than the other so I bought a few that have multiple height options to play with: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
NYC Bimmer259.50 |
09-09-2020, 11:50 AM | #6541 |
Rep 130
Nice fix for the saggy exhaust! I've been meaning to do this since I installed Cyba tips. With aftermarket tips installed, the sag seems to be more noticeable.
09-09-2020, 12:05 PM | #6542 | |
297
Rep 266
AndrewC198910931.00 |
09-09-2020, 12:22 PM | #6543 | |
6637
Rep 4,145
Drives: '18 M2 6MT
09-09-2020, 12:24 PM | #6544 |
Rep 4,551
That's not very reassuring, lol. I ordered one of the polyurethane ones you got as well just to be safe. Thanks for the info.
NYC Bimmer259.50 |
09-09-2020, 12:30 PM | #6545 |
Rep 2,526
VisualEcho6636.50 |
09-09-2020, 04:31 PM | #6546 | |
Rep 307
09-09-2020, 05:33 PM | #6547 |
2530
Rep 1,908
09-09-2020, 07:54 PM | #6548 |
297
Rep 266
the stock rubber pieces have a slightly smaller diameter hole, so take some work to remove (use a lubricant) if you don't have an exhaust hanger tool. If you have the tool, it's a 2 minute job even with the car on the ground (though ramps make it a lot easier, I was just lazy)
09-09-2020, 08:14 PM | #6549 | |
2530
Rep 1,908
Honestly, this is a new topic to me, so forgive my questions. . . so, this 'tool' you reference, is it a couple bucks at AutoZone? Do you have to remove any bolts/screws, or do the stock part and new part just pop in and out? Thanks for taking the time to spell it out for me. ///AVM |
09-09-2020, 08:47 PM | #6550 | |
297
Rep 266
There are two posts on each side, one attached to the body, one to the muffler, and they are connected by a rubber bushing. The tool presses the bushing off the post using the post as leverage. The new bushing just presses on with minimal effort. I found it easiest to remove from the body first, and install on the muffler first. |
09-09-2020, 09:48 PM | #6551 |
6637
Rep 4,145
Drives: '18 M2 6MT
Cleaned it, then drove the damn thing on gravel.
09-10-2020, 03:18 PM | #6553 |
Rep 4,551
VisualEcho6636.50 NYC Bimmer259.50 |
09-10-2020, 03:44 PM | #6554 | |
Rep 13
I believe that I may have found a mount that will work. The one pictured on the right is the one that we normally offer for the F87 chassis - part number EXH032. The one pictured on the left is part number EXH001. The holes for the lugs appear to be almost, if not exactly, the same diameter. They are just closer together, which would raise the exhaust! I am still not certain that it would fit, seeing as how it is a completely different shape, but this was the best example that I could find! |
09-10-2020, 05:44 PM | #6556 | ||||||
Rep 177
You're awesome! Thanks for sharing this, my fabspeed exhaust hangs crazy low
2018 M2- Alpine White 6spd
some two wheeled fun and a tow rig |
