M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Why are people changing plugs BM3
      12-13-2019, 10:46 AM   #1
nismoman
Drives: 2017 LBBM2,2001 LSB M3,S52 E30
I've seen alot of recent threads where people are just jumping into BM3 and are saying that they should swap plugs to one range cooler for the OTS tunes on stock turbos. Why is this recommended? I've always understood that unless you are running some retardedly high boost or big turbos i.e. 500hp+ builds, factory plugs are sufficient.
currently running FBO, catless, bm3 stg2 93 for 7k miles and have seen no issues in logs or timing that are not related to fuel quality.
D CHOI581.00
      12-13-2019, 10:51 AM   #2
nioh_lbbm2
nioh_lbbm2's Avatar
1717
Stock is fine and confirmed eve for the S55 OTS maps.
This is directly from Halim on the BM3 fb group
D CHOI581.00
      12-13-2019, 11:41 AM   #3
nismoman
      12-13-2019, 11:49 AM   #4
Pray for Mojo
430
Drives: 2014 M235i & 2018 X3 M40i
Early adopters were all changing plugs, but over time there were a lot of people who didn't and had no issue. I think if your car is close to 50k miles you should change them regardless of heat range as good housekeeping. There's also speculation you should change more often on tuned vehicles, I have 20k on a set of NGKs and they were fine/gapped correctly when I pulled cylinder 1 in August. Never experience misfires on stock or 1 step colder, but I had poor timing due to octane initially and thought plugs might help.
      12-13-2019, 12:55 PM   #5
nismoman
Good to know/ agree w/ the maintenance. I have 9k on the clock so I have a bit to go. Yeah octane is killer with these tunes.
      12-16-2019, 11:35 AM   #6
mike@x-ph.com
mike@x-ph.com's Avatar
Truth is stock plugs are fine. Once they start getting older, it will misfire with higher boost. It will still keep up with stock boost.
Most people start complaining that there is something wrong with the tune since the problem does not happen with stock map
Tuners are just saving themselves the headache of dealing with the same issue all day and risking a bad reputation since most will just post a thread before taking 5 minutes to do any research
https://x-ph.com/sale/
Phone number 702-494-9435
      02-05-2020, 09:50 PM   #7
atlas
383
Can changing plugs improve performance, even if the stock ones were fine?
