06-21-2019, 10:05 AM | #1 |
756
Rep 2,149
Does Bootmod3 work with the lastest BMW Update?
I know it doesn't work on the M2C after "I think" the April 19th update. Can anyone confirm it's the same for the M2 or not?
My car is in the shop now for a taillight issue, and I asked them not to update or reset any software without speaking with me first, because I don't want to lose my tune or coding. |
06-24-2019, 11:53 AM | #2 | |
Rep 775
06-24-2019, 05:36 PM | #4 |
Rep 1,466
I had my iDrive screen replaced last weekend, and by comparing coding before and after, I can see that they did update the NBT coding, presumably for a slightly different screen type. I didn't have a full I-Step update done, and neither requested or requested not to.
I was worried, for the same reasons as you, so reached out to cookiesowns because he seems to find out the contents of I-Step updates pretty frequently. He didn't think there was an N55 DME update for quite a while, but also couldn't confirm it either. He feels that since the N55 is EOL, only very limited changes were likely to be made. If you don't hear back from Halim@HCP or proTUNING Freaks, I wouldn't worry too much. Having said that, I would be interested to know for sure too.
2018 ///M2 LCI, LBB, 6MT...
06-24-2019, 11:55 PM | #5 | |
Rep 6,635
07-01-2019, 06:35 PM | #6 |
721
Rep 364
This applies to the M2C only.
N55 M2, no worries |
Anthony1s755.50 ngliuxiang37.50 |
07-02-2019, 01:49 PM | #7 |
Rep 181
Hi all, I'm just trying to follow along here, just looking for clarification.
My ISTEP is currently getting updated at the dealership, will this simply wipe out all the 'convenience' settings I've programmed the FEM with (ie folding, disclaimer notifications, seatbelt chimes etc) or will it also wipe out my stg2 tune? |
07-02-2019, 08:48 PM | #8 | |
Rep 6,635
07-02-2019, 09:30 PM | #9 | ||
Luxury at the redline :)
9105
Rep 7,563
BTW, with BMW's new April 2019 update, the S55 uses the same ECU as the N55, so I highly doubt that the latest software doesn't affect the new firewall of all vehicles, regardless of what the vendor claims. There have been reports of BMW blocking new B58 software also from allowing flash tunes, so why would BMW conveniently not patch the new N55 software, if that's their ultimate goal. I believe it would still be blocked but would loved to be proven wrong. |
07-03-2019, 01:27 AM | #11 | |
9105
Rep 7,563
Warranty or not, even a discontinued vehicles still have their software revised from time to time. The N55's last year of production was only two MY ago, it's still a relevant motor, in terms of warranty and software. But what do I know.. |
07-03-2019, 10:29 AM | #12 |
oooooo
53
Rep 320
Around May 15th I had the latest update installed chasing a COM / NAV issue and successfully flashed BM3 back on the car the following day. No issues for N55 unless BMW has kicked out another update in the last 5-6 weeks
2011 135i - Gone but not forgotten | 2017 M2 - Powering out of a corner near you!
akkando5864.50 |
07-03-2019, 01:08 PM | #13 | |
Rep 181
I just got my car back from being updated and can confirm that yes, the tune did indeed get wiped out along with all my other 'convenience' settings from bimmercode. I was able to successfully reflash bm3. It DID need to unlock DME. Here are some of my logs: 2019-07-03 11:53:48,733 INFO - Detected different version of software on the DME from the map being flashed. 2019-07-03 11:53:48,733 INFO - Running full flash instead of quick map switch due to detecting software differences between the map and DME. 2019-07-03 11:53:48,740 INFO - Flashing Stage 2 93 octane Their version numbers are a bit different from what is discussed here - On my service record it stated the version I had was 16-11-502. Updated to 19-03-546. I can confirm my version was evo_Jxxx and it is now evo_Qxxx. No problems at all with reflashing bm3. Thank goodness too, that drive from the dealership felt night and day compared to running a stg 2 tune - makes you really appreciate how big a difference a tune really is! |
Poochie9104.50 |
07-03-2019, 01:28 PM | #14 | ||
9105
Rep 7,563
Thanks for the confirmation! |
