M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Removal of the secondary cat on M2.....
      06-14-2019, 03:21 PM   #1
widetyres
279
Drives: M3 E92 DCT, 2012
...but the M2 doesn't have 2nd cats I hear you say!....
...and that was my belief, however, I've been educated through a Facebook post that the M2 does have a secondary cat that can be removed!
Within the OEM downpipe, there are two separate cat monoliths, one after the other with a void in-between. Only the first cat is monitored, and this can be clearly seen by looking at any pic of an OEM cat and the lambda placement.
As a result, you can smash out the un-monitored cat. The result will be no CEL, just a bit more exhaust noise and maybe a bit more power.
Has anyone on here done this? I haven't seen any threads about this before.
Anyone know of of any videos showing this?
Cheers.
      06-14-2019, 04:47 PM   #2
cecaa850
You'd have to pull the pipe to do it correctly otherwise you'd stop up your muffler with pieces of catalyst.
      03-15-2021, 05:04 PM   #3
3LiterBeater
Drives: BMW M2, Porsche 944 Turbo
Wanted to bump this. Interesting way to eliminate the "pre" cat element which I'd assume is the most restricting.
Has anyone done this?
