05-31-2019, 09:42 AM | #1 |
Chief Senior Executive Managing VP of Orange Sales
585
Rep 2,581
Pure Turbos inlet pipe coming loose?
So, I have the Pure Turbo inlet pipe -- the solid metal one which connects directly to turbo and air intake without any plastic or other connections.
It has 2 o-rings in it on the turbo end, and is designed to stay in place by only fitment - yes, I called Pure Turbos and they confirmed this - it does not get fastened to anything. Does not reuse the 10mm thread/nut that the stock inlet was fastened to the turbo with. First time I installed it, it had not cleared the 2nd o-ring, and came out after some miles. That was when I called Pure Turbos. I re-installed it and got it as flush as possible, and it was so far in that at the top, it was touching the cylinder head, meaning, it could not possibly go in any further! See photo of fitment at turbo end below. It still came out. I'm wondering if it's possible that (a) I over-tightened the 2 clamps and rubber tube that connects the inlet pipe to the air intake, and vibration and the snug fitment causes the air intake to pull it out. Going to test that theory (b) This pipe is defective in some way? (c) It's just a bad design and doesn't function as it's supposed to. Does anyone have experience with this pipe and/or any other ideas on what might be going wrong? |
05-31-2019, 10:28 AM | #2 |
Rep 2,956
I'm not exactly sure why they wouldn't have just added a flange to be secured to the compressor housing. Engines move around and shake so I don't feel 100% confident that O-rings alone may suffice as a seal under positive pressure in this type of installation.
05-31-2019, 04:12 PM | #5 |
585
Rep 2,581
I spoke to Pure Turbos and sent them the photo I posted here, and was told that the tiny gap is the problem, it has to be completely flush, not just clear both o-rings.
Will try it again and see if it doesn't come out. |
05-31-2019, 04:40 PM | #6 |
Rep 699
Wouldn't it be vacuum if anything?
05-31-2019, 04:47 PM | #7 | |
585
Rep 2,581
So chances are, if you're not hearing a metallic whistle, it's still in perfectly. |
Pray for Mojo429.50 |
05-31-2019, 07:03 PM | #8 |
Rep 24
Under acceleration - The intake tube with filter up to the turbo compressor inlet is at a lower pressure than atmospheric pressure or vacuum. This is mainly due to the restriction of the air filter.
Under deceleration - and just momentarily the intake tube track would be higher than atmospheric as the same amount as the restriction back through the intake filter. Question is - is this residual back and forth pressure/vacuum enough to overcome the resistance of the o-rings and tension of the plastic intake tube. And add to the equation above the factor of 200*f heat and vibrations.... hmm |
05-31-2019, 08:04 PM | #9 |
Rep 699
06-01-2019, 04:55 AM | #10 |
585
Rep 2,581
Correct. However the solid metal tube is connected to the plastic stock air intake tube via a rubber tube and 2 clamps and that definitely puts tension on the metal inlet pipe, especially since the intake is forced toward the front of the car by that grommet right above the grilles.
06-01-2019, 07:29 PM | #12 |
585
Rep 2,581
Yeah kind of bummed and frustrated.
I took the pipe out today, oiled it up, adjusted the position and got it in further but it still had a tiny wiggle, and a short 2 mile test drive I still hear a faint whistle. Driving 1400 miles tomorrow so I will know if it backs out or not. Will keep checking at gas stops and have tools on me in case it comes out and I need to fix. Basically at this point, I am having a hard time trusting that it will stay in. I'm bringing the car to IND for a roof install, might ask them to take a look while the car is there to see if I'm crazy or not. |
06-02-2019, 09:30 PM | #14 |
Rep 1,115
It fits tightly if installed correctly and will stay in with the intake tube. There's no way it should be catching on the cylinder head, the flange is narrower than the turbo's.
06-03-2019, 06:18 AM | #15 |
Rep 4,515
Op
Sorry to read about your problems with the all metal one piece inlet pipe. FWIW I have 2 part plastic/metal - aka type 2 - inlet pipe - no issues. Had the same on my m135i - again no issues. BP
Current '22 X3M LCI.. |
06-03-2019, 07:51 AM | #16 |
Rep 99
Having the full metal one and no issue. Sits really really tight and was a pain getting in.
Last time I was under there to fiddle with the ewg it was still sitting as it should. |
06-03-2019, 11:36 AM | #17 |
585
Rep 2,581
Thanks guys
So, I think perhaps I might have accidentally pulled it just enough fo get loose when I put back the air intake. I'm going to redo it one more time and try again. 1400 mile trip yesterday, it had the whistle from the beginning (hence why I think it was my error wrt air intake reinstall) but this time it never fully backed out and the car was OK for the full drive. It seems like if you pull on it just a but too hard it will get loose enough to back out. Just my inexperienced thoughts. Glad to hear others are having none of these issues which makes it more likely user error on my part vs the pipe itself. |
06-03-2019, 11:38 AM | #18 | |
585
Rep 2,581
Can you post a photo or two of the top of your engine where the inlet pipe is to show clearance with the engine? I know posting photos can be a Pita. If anything PM me and I'll give you my phone number or email. Would really help me out to see one properly installed. Thanks! |
06-03-2019, 12:27 PM | #19 |
585
Rep 2,581
I would really appreciate also if you can post a photo of the top of engine, how it sits/angle, and clearance to engine.
06-03-2019, 02:41 PM | #20 | |
Rep 1,115
06-03-2019, 04:08 PM | #21 | |
585
Rep 2,581
Thanks anyway! |
