11-14-2018, 01:46 PM | #45 |
Rep 212
Drives: 2024 M3 Comp xDrive
Does the downpipe in your opinion change the way the car drives? By looking at those dyno results it seems like it significantly changes the torque/hp map shapes and would probably affect power delivery.
11-14-2018, 02:11 PM | #46 |
Rep 4,541
Drives: 2015 328d xDrive
Yes, a difference can totally be felt. The turbo spools a little faster so the throttle response feels better and more instantaneous. There's a little bump in power as well but not a ton.
m2for2225.00 |
11-14-2018, 05:26 PM | #48 |
Rep 4,541
If you're just getting a straight pipe literally any brand will do.
If you want a catted DP I would suggest Fabspeed or Remus as they use high quality HJS cats. Akra stuff is nice but it's super overpriced IMO.
NYC Bimmer259.50 |
11-14-2018, 05:28 PM | #49 |
1004
Rep 1,653
WHat sportcat are you running? Why didn't you pass? Did you have a cel? did your tune turn the O2 sensors off?
11-15-2018, 12:35 PM | #50 |
Rep 212
got that, but my concern is about the top end. It seems like the stock engine keeps more power in the high end of the rev range. Would I feel that lack of power up there?
11-15-2018, 12:37 PM | #51 |
Driver
391
Rep 650
didnt know remus had a sport cat... it must be somewhat new
11-15-2018, 12:52 PM | #52 | |
Rep 4,541
It's been around for more than a year now because that's when I found out about it. I'd have gotten it had I known I was getting a Remus exhaust but the fabspeed cat is a high quality part so I don't mind. https://www.x-ph.com/remus-f-chassis...tted-downpipe/ |
m2for2225.00 NYC Bimmer259.50 |
11-15-2018, 01:36 PM | #54 |
Rep 289
AndrewC198910910.50 |
11-20-2018, 07:08 PM | #55 |
Rep 4
Anyone with an aftermarket DP and/or mid pipe (resonator delete) have any issues with the dealership such as an unwillingness to work on the car at all, and/or warranty or maintenance plan coverage?
11-20-2018, 07:25 PM | #56 |
Rep 4,541
My dealer installed my res delete and downpipe so they clearly don't give a damn. YMMV.
NYC Bimmer259.50 |
11-29-2018, 05:33 PM | #57 |
Performance Attaché
57
Rep 54
Hey Andrewc89,
Others have mentioned a possible drone with the Dinan res delete. I believe you mentioned "no drone" earlier, but I just want to confirm. I have zero interest in DRONE! Thinking of pulling the trigger on this and I'll be set up like your second vid. Res delete w/ stock exhaust. TIA |
11-29-2018, 05:41 PM | #58 | |
Rep 4,541
Dogs6357.00 |
07-05-2019, 05:04 PM | #59 |
Rep 643
Old thread. But I’ll revive it.
Is the res delete install purely Bolton or cutting pipe? Fabspeed cat is also remove oem replace fabspeed? I’d like to do it on jack stands .... unless I rent a lift at a local shop |
07-05-2019, 05:06 PM | #60 | |
Rep 4,541
Sport cat is bolt on.
07-06-2019, 04:58 PM | #62 |
Rep 643
07-06-2019, 06:00 PM | #63 |
enthusiasm > practicality
4021
Rep 2,247
Drives: 987 CS | G35x
There's definitely drone while cruising at high speed. It's simply the price you pay for such a raw and enthralling exhaust setup.
07-08-2019, 11:47 AM | #64 |
24072
Rep 190,597
+1
06-03-2020, 07:31 PM | #65 | |
6629
Rep 4,145
Drives: '18 M2 6MT
You say there is no additional drone if you delete the resonator on a stock exhaust. What I'm trying to figure out is if the deletion of the resonator does cause more drone when you do the sport-cat. Like, if you plan to do a sport-cat, keep the resonator type of thing. I know I'm getting a sport-cat when my warranty runs out, but I'd like to have the resonator delete as well, so I'm trying to figure out if the sport-cat + resonator delete is a bad idea. Your thoughts? |
06-03-2020, 07:44 PM | #66 | |
Rep 4,541
NYC Bimmer259.50 Sundinisagod107.00 |
