04-07-2018, 08:19 PM | #155 |
Rep 780
Decibel-X
voyagergab633.00 |
04-08-2018, 02:26 AM | #156 | |
Rep 234
Drives: 325i Manual, M2 LBB DCT
04-09-2018, 01:40 PM | #158 |
Rep 234
04-09-2018, 02:55 PM | #160 |
Rep 780
Put them in took 45 minutes and I don't have huge hands!
Tough to get perfect... They will only quieten down sounds from the engine compartment, Sound still come around the door the same way. Interested to go for a motorway drive. Likey 2 days before I do new readings.
"I would rather cry in a BMW than smile on a bicycle." Ma Nuo Last edited by GregoryK; 04-09-2018 at 07:59 PM.. |
04-11-2018, 03:15 PM | #161 |
Rep 780
Wow. I ran the sound meter today at 120kph.
73 to 75 db. It is hard to believe! I did update the app but assume it still works the same! I guess more noise was coming from the lack of engine gasket than you might think. The car is still not quiet under hard acceleration but the the 350 kbps audio files sound decent at 90mph now. I can safely say. MISSION ACCOMPLISHED! Last edited by GregoryK; 04-12-2018 at 03:15 PM.. |
4
04-11-2018, 04:46 PM | #162 | |
Rep 172
04-11-2018, 05:36 PM | #163 |
Rep 1,083
Thanks for doing the research GregoryK
I've ordered up all these parts worth $420 CAD Door and front wheel noise Sealing side panel, left: 51487300693 Sealing side panel right: 51487300694 Sound insulation, engine compartment: 51487221993 Clips x 18, 51489119216 SOUND INSULATING WHEEL HOUSING REAR LEFT: 51487334357 SOUND INSULATING WHEEL HOUSING REAR RIGHT: 51487334358 Lateral trim panel rear Cover for side section, left: 41007294289 Cover for side section, right: 41007294290 Clips 12 x 51489119216 |
SDR5550.00 |
04-11-2018, 08:34 PM | #164 |
Rep 780
Don't forget
51487296055 SOUND INSULATION TRUNK LEFT 51471911992 Fixing plug x12 D = 8MM 51487296056 SOUND INSULATION TRUNK RIGHT
voyagergab633.00 SDR5550.00 |
04-11-2018, 09:33 PM | #165 |
Rep 1,083
04-11-2018, 11:51 PM | #166 | |
Rep 234
What happen with the door insulation 51487319479 51487319480 did u put these or they were there from the factory? |
04-11-2018, 11:56 PM | #167 |
Rep 234
voyagergab633.00 |
04-12-2018, 06:25 AM | #169 |
Rep 780
The wheel wells are in front of and behind the seats. The insulation is in 2 sections. The one you ordered goes behind the panels by the rear seats. The others go in the trunk.
voyagergab633.00 |
04-12-2018, 07:20 AM | #170 | |
Rep 243
Drives: 2018 MGM 6MT M2
04-12-2018, 08:39 AM | #171 | |
Rep 780
I took my wife for a drive and she said it was like being in a different car.
"I would rather cry in a BMW than smile on a bicycle." Ma Nuo Last edited by GregoryK; 04-12-2018 at 12:01 PM.. |
voyagergab633.00 |
04-22-2018, 11:13 AM | #174 |
Public Last Class
97
Rep 244
Drives: 2018 M2 DCT LBB
Appreciate you sharing your findings. I’m looking for the best way to reduce just the tire noise. It’s seems to be primarily the rear tires you hear? What would be the best bang for the buck/time to lower the tire noise?
04-22-2018, 03:27 PM | #175 |
Rep 1,466
I'm wondering this also... Panel in the rear side under the side panel arm rests, or the sound deadening over the wheel arches in the trunk?
04-22-2018, 03:34 PM | #176 | |
Rep 1,083
Once they arrive I can try the panels first and report back. |
