12-27-2023, 12:45 PM | #1 |
Rep 63
M2CS rear wheel hop
Hello all. I hope you are having a great holiday season.
I’ve been wanting to post this concern for a while but had not gotten to it. Whenever I accelerate agressively, especially in 1st and 2nd gears, the rear wheels on my M2CS start bouncing up and down and the feel inside the cabin is somewhat upsetting. When new, I didn’t love the ride height of the car and thus messed around with a couple of ride height lowering kits from KW and BMW Performance but then reverted back to stock suspension as the lowered ride height seemed a little too much. Just in case you are wondering, the car is fitted with Michelin Pilot Sport 4S. The rear pressure is set at 34PSI with warmed up tires. I am unsure as to weather everyone experiences this issue and thus it is something normal or wether the suspension on my car is not functioning the way it should. On other performance cars, I don't get wheel hop. All I get when I got to the gas pedal aggressively is wheel spin. Stay safe! Last edited by Tigeroujimo; 12-27-2023 at 12:52 PM.. |
12-27-2023, 01:22 PM | #2 |
The Seeker
13863
Rep 3,323
Super common across all weather, tires, suspensions, wear, etc.
The short answer is that many things can cause it, but you'll likely not experience it under all temps, all tires, all weather, all (pick your poison). Owners have been chasing a fix for many years, and not all fixes work for every user, so it's a bit of a rabbit hole TBH. There are things you can do, tests, ways you might be able to nail down when it happens more than not, what you might personally change, etc, but no human can tell you; do this and it'll stop. It's not that sort of thing. Sorry to be the bearer of bad news, but it is what it is. While you're at it, chase the clicking from the front suspension too, you'll have a jolly old time chasing them both with fixes for the next year. If you get wheel hop, take note of the surface, temperature, tires, wear, etc, and then try it with a different set of tires, temps, precip, etc. |
Tornado1M1211.00 |
12-27-2023, 03:21 PM | #3 | |
Rep 3,842
12-27-2023, 03:54 PM | #4 | |
Rep 100
https://f87.bimmerpost.com/forums/sh....php?t=2068172 https://f87.bimmerpost.com/forums/sh....php?t=1834869 |
12-27-2023, 06:10 PM | #5 | |
Rep 553
I got the bracket/dual mounts when getting seals replaced, now when breaking traction it's a lot smoother & no violent drivetrain noise. There are several brands who do the bracket/mounts, I went with Powerflex & the purple bushings (2 rear & the 4 front), it did introduce a diff whine between 95-105kph which I'm OK with, if you regularly cruise at 100kph it would be tiresome. Another option is to add the bracket & 2nd rear mount but use an oem mount (making sure not to use the pre-2018 oil filled verson), I know someone who did this with no additional cabin noise. |
12-27-2023, 06:11 PM | #6 |
Rep 63
Thank you all for your feedback. Having understood that it is something common on these cars, my concern is gone. I will look into the suggested threads to see how I can improve the handling of the car.
Best! |
12-27-2023, 09:57 PM | #8 | |
Rep 63
12-28-2023, 03:23 AM | #9 |
Rep 2,203
Drives: G81 M3 Touring (Frozen Black)
12-28-2023, 03:44 AM | #10 |
Rep 1,334
///MPhatic13862.50 chris7197334.00 |
12-28-2023, 07:26 AM | #11 |
Rep 901
Drives: 2018 M3 Competition
I haven’t experienced wheel hop in the CS, but I guess you’re talking about launching it hard from a dig? 7,000 miles and I’ve pushed the car many times but I don’t think I’ve ever launched it 100% from a dead stop. Are you 6MT or DCT?
I’m on PSS and if anything the wheels spin almost silently if I mash the throttle from 30mph in 2nd. I don’t recommend that. The only time I almost got into trouble was a move like that when I couldn’t hear the wheel spin and when the boost kicked in the back end snapped pretty violently even though I was pointed straight. Luckily, I corrected, but it could have ended badly. I took my E46 M3 to the drag strip back in the day, and it had crazy wheel hop through 1st, maybe even a little bit in 2nd. Bottom line is these cars are not built for drag racing, even though they run high 11s/low 12s. |
12-28-2023, 08:52 AM | #13 | |
The Seeker
13863
Rep 3,323
Lowering didn't change my wheel hop, but tire choice certainly had an effect. |
12-28-2023, 02:42 PM | #14 |
Rep 63
On the M2CS, in addition to the bushing, did you also have to add the 2 point bracket or does the car come with it installed from the factory?
12-28-2023, 03:34 PM | #15 | |
Rep 1,334
chris7197334.00 ///MPhatic13862.50 |
12-28-2023, 04:57 PM | #16 |
Rep 63
12-28-2023, 05:17 PM | #19 |
Rep 7,298
12-28-2023, 06:22 PM | #20 | |
Rep 100
12-29-2023, 08:34 AM | #21 | |
Rep 63
I run OEM suspension on my car. |
12-29-2023, 12:58 PM | #22 |
Rep 1,334
