03-26-2022, 10:25 PM | #1 |
Rep 20
New Wheel Hop M2C
Hey guys, recently noticed new wheel hop in my car. 2021 M2C, bought it new, have had it for 16 months now, around 14k miles. Around 2 months ago noticed I started getting wheel hop on my winter wheels/tires which used to break away smoothly...figured its probably just a problem with my winter set. Put on summer tires (entirely stock setup) and it's still getting wheel hop instead of breaking away smoothly. Just back in October car was breaking traction smoothly; now it hops all over the place. The car does need an alignment since someone hit the front wheel back in December; could that be the issue? I really know nothing about suspension in general so any advice would help, thanks!
03-27-2022, 09:09 AM | #2 | |
Rep 317
Toys- ‘21 M2C, '20 718 GT4 (going), '14 981 CS (going), '09 C4S (gone)
-Inbound- '23 GT4 RS, 22 718 GTS 4.0 |
03-27-2022, 05:37 PM | #4 |
Rep 200
Drives: 2021 M2C
wheel hop is exaggerated by many variables. As tires age, they tend to get harder, and thus more wheel hop. Also, a summer tire will hop more in cold weather. Certain tire brands do it more.
When I had old Pirellis on one of my cars, they would hop so bad that it would scare me on a slow sharp turn (ackermann effect). It completely went away when I put new Michelin MP4S on (by the way, MP4S do it less than PSS) Tire pressures, and street surface also has some effect. So realistically, what I'm trying to say is that tires will do this, and it's hard to narrow down why it happens. Wheel alignment isn't generally one of the reasons, as far as I know. Last edited by Up4speed; 03-27-2022 at 05:46 PM.. |
03-27-2022, 06:15 PM | #5 |
Rep 6,937
Drives: 2018 M2 AW DCT
I have only experienced wheel hop on wet roads when I accelerate too fast.
03-27-2022, 07:13 PM | #6 | |
Rep 20
chris7197334.00 |
03-27-2022, 07:44 PM | #7 |
Rep 100
Does DSC exacerbate wheel hop? It's happened a few times on my car but always when I'm in MDM mode. I've not experienced when driving with DSC off. Guessing the difference is from MDM limiting how much/how long wheel spin can go on... and how this may help rear tires to alternate between grip and spin.
For any engineers/techs, wheel hop cannot be a surprise to BMW. How much of this can the drivetrain handle on a prolonged basis? I'm never searching for wheel hop... rather thinking about the strain put on the drivetrain, drive shaft, rear end, etc. when it has happened. |
03-27-2022, 08:39 PM | #8 | |
Rep 20
03-27-2022, 11:23 PM | #9 |
Rep 837
I was just going to ask what settings you normally drive in. I consider myself fairly competent with my footwork but I can never get Sport+ to be smooth on anything but smooth roads. Sport+ throttle feels like an all or nothing affair and it feels like it fights the stability control rather than cooperate with it.
03-28-2022, 09:44 AM | #10 | |
Rep 200
Drives: 2021 M2C
Unfortunately, I'm saying a lot of nothing! lol But I can say, that in my experience, it was always the tires when I had a problem with wheel hop in any of my cars. |
03-28-2022, 10:58 AM | #11 |
Rep 3,953
Every recent BMW I have owned has had wheel hop. Normal operation for rear wheel drive cars with independent rear suspension.
Moflow2484.50 |
03-28-2022, 07:31 PM | #13 |
Rep 1,602
I agree with David and MMMBRAP. My 350Z had wheel hop roughly as bad as this car. I live in the northwest where its wet most of the time and wheel hop is just a thing that happens if you want independent rear suspension. It's annoying, but you just learn to drive around it.
03-29-2022, 02:34 AM | #14 |
Rep 127
Generally the sure way to eliminate wheel hop in any independent rear rwd car is to have all spherical bearings in the rear suspension, i.e. no elastomer bushings, and a solid mounted diff. And by solid I don't mean firmer rubber or poly bushings.
Whether this is practical for a street car or not is a whole other matter though. |
03-30-2022, 11:12 AM | #15 | |
Rep 215
Under load, the entire suspension deflects and distorts - not only along the axis of the rear springs and shocks (squat), but in complex ways where it compresses/twists control arms/loads bushings. Drive axles twist and "wind up" like a torsion spring. Compliance in the tire rubber tread/sidewall itself also contributes to this stored energy. Taking a look at what wheel hop IS, you can then see ways to reduce it: Once the tire loses traction under forward thrust, grip 'falls off the cliff', and this stored energy in the entire suspension/driveline is rapidly released until the energy is fully released, where wheel speed slows down enough for grip to suddenly restore. The lose-grip/restore-grip process repeats at a resonant frequency according to all of the components involved, and tends to amplify pretty badly to where you feel/hear the juddering and risk breaking something. One way to stop the hop is powering through it to get wheel speed up incredibly high, but you'll often break something on the way there (spider gears, pinion, axles, CV joints, diff case... It's really violent and these parts are not cheap) It's a complicated problem with many variables. Some are easier to control/adjust than others. Pretty much every thing you can do to mitigate the issue seems to really be about either changing the resonant frequency of the wheel hop, or reducing the ability of the suspension system itself to store energy as an elastic spring at all (exclusive of the actual spring/damper)
On some cars, it can be super easy and well-known "fix"... But on M2's I think it's a more complicated problem to "solve" since so many of the rear axle components are suspended with rubber bushings, which add elastic compliance, and thusly store energy like a spring does. I haven't heard of many simple success stories. I'd love to know if there's a few really nice bang-for-buck "fixes" on our platform. Personally, my desire to fix this is for having fun, not really for accelerating from a dig, not for drag, and not for track racing. General hooning. If I want to lay some rubber, I typically have to get the thing sliding sideways so that the tires are always past the grip-cliff in a vector that is very stiff (sideways!), and the problem goes away. Breaking traction in a straight line usually causes crazy hop and I have to back out immediately, which is no fun! Last edited by bitcore; 03-30-2022 at 11:25 AM.. |
Moflow2484.50 |
03-30-2022, 01:48 PM | #16 |
Rep 2,291
Or, just wait until the weather gets warmer. Over in the PWN, it's still in the 30s at night. Tires get harder the colder it gets and lose contact with the pavement. Wait until it's in the 60s or warmer, warm up the tires properly and try it again. I would bet you wont get any hop and will be happy again.
Present: 2023 M2 BSM W/Carbon everything, 6 Speed
Past:2020 M2C HS Executive, 6 Speed |
03-30-2022, 06:20 PM | #17 | |
Rep 100
03-31-2022, 06:11 PM | #18 | |
378
Rep 348
Moflow2484.50 |
03-31-2022, 09:21 PM | #19 |
Rep 151
What tire pressure are you running? Sometimes installers/dealers way over-inflate the tires, which might exascerbate the car's inherent problem.
04-01-2022, 11:47 PM | #20 |
Rep 20
Thank you all for your thoughtful/helpful responses; I really learned a lot from you guys and truly appreciate it! Had no idea that there were so many factors that go into this.
04-01-2022, 11:48 PM | #21 |
Rep 20
Running 34/35 all around. It's also still pretty cold in Chicago, hasn't really been above 50's since I put the summers back on.
Tags |
m2c, wheel hop |
