M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Bmw F series N55 HPFP upgrades
      01-07-2021, 11:32 AM   #397
SebsM2
SebsM2's Avatar
652
Drives: 2017 LBB M2
Originally Posted by -Eidos View Post
Originally Posted by SebsM2 View Post
Looking forward to this. I don't personally want to run wmi or PI so this will be my go to.
Yep! See my preliminary thread on it: https://f87.bimmerpost.com/forums/sh....php?t=1782572
Yep, I've been all over it
I've held off on the wmi kit I was looking at now.
Looking at a flex fuel kit instead now. My goal is to run 93 daily no pi, no wmi and hit high 400 wheel and then fill up with e50 on the weekends and hit mid 500s or 600 whp.
You think the bend calibration flex fuel kit will be switched out for something later? Or should I go ahead and start researching/purchasing
Instagram: SebsM2
Build thread: A Tastefully Modded FBO M2
      01-07-2021, 11:52 AM   #398
PLF69
PLF69's Avatar
3766
Drives: 2023 M3
may I ask a questions ?
Lets say you don't have access to E-fuel but want to open up the potential of your N55 M2, most easily available/reliable setup I guess would be a pure stage 2 and all required mods.
Ive been down the road of upgraded turbos combined with wmi (jb4 + mhd backend) on my past 135i but I'd rather avoid WMI from now on.
Questions: What is the horsepower threshold to need an upgraded High Flow pump ? What power can be expected from a pure 2 running 91-93 with stock pump ? Where will an upgraded High flow pump take us ?
What setup will run de coolest for track use ? WMI or E fuel ? If I ever go down the rabbit hole with the M2 I'd rather it to be the simplest one.
Thanks
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp
Daily: 2023 X5 45e
Daily/Family: 2021 Atlas Cross Sport 3.6
      01-07-2021, 12:06 PM   #399
-Eidos
@lbb_kev
491
Drives: 2018 BMW M2 (LBB)
I'd start researching on it. The kit is solid and the only thing that I can see being "replaced" is the Zeitronix ECA-2 if you eventually decide to go PI/WMI and upgrade to a more comprehensive controller to something like the Motiv ReFlex, which can control Flex fuel, PI, WMI, etc. You can run the ECA-2 and the ReFlex in parallel or consolidate all to the ReFlex and sell the ECA-2.
The filter, lines, and bracketry on the kit will be good for the long term. Will only need to replace the filter ($50) every 5k miles or so depending on how clean your fuel is.
You can do 520-530whp without a stage 3 HPFP set-up, as I did on the Dorch Stage 2 with the BW 7670 turbo. It's really dependent on your turbo choice and your goals
You'll also need a tuning solution to take advantage of the ethanol sensor/content analyzer. You'll have some time to research before BM3 releases their solution or you can go with EcuTek, which I'm running right now.
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage
SebsM2652.00
      01-08-2021, 08:47 AM   #400
cecaa850
Thanks
Simplest would probably be pump fuel and Boostane. With ECUTEC you can have one map for Boostane and one for normal pump fuel. You can toggle between the two without reflashing.
      01-22-2021, 04:15 AM   #401
F87source
F87source's Avatar
Drives: Bmw M2
Originally Posted by detroitm2 View Post
Pricing:
"Our price will most likely stay around the 1300-1400 range but I will know for sure in 2 weeks as we are restructuring our pricing in prep for 2021."
Pricing just jumped to $1650. If it's going to stay there then imo it's definitely not worth it over spool or dorch which offer life time warranty for $49 more.
      01-22-2021, 08:23 AM   #402
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
Pricing:
I'll check on this.
IMO, it depends on how it flows. If it truly flows better than Dorch or Spool, that answer is not as easy.
Motorcity BMWCCA Member
Instagram | YouTube
      01-22-2021, 08:50 AM   #403
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
In other news, I'm dropping my car off next week at Nostrum for HPFP install.
Instagram | YouTube
      01-22-2021, 01:35 PM   #404
F87source
F87source's Avatar
Drives: Bmw M2
I'll check on this.
I guess we will see, but I doubt it will flow more.
      01-22-2021, 02:15 PM   #405
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
What if I told you that:
1) The price on the site is going to change.
and
2) The lifetime warranty is coming extremely soon?
Instagram | YouTube
      01-22-2021, 02:57 PM   #406
F87source
F87source's Avatar
Drives: Bmw M2
and
If said price is going back to the $1300 range with lifetime warranty, then all of a sudden this is the best pump option currently available - if it holds up to expectations
If it's equally priced to the other options and results are similar then it's down to personal preference and if the check box tuning option is good, unlike xdi which causes a weird stutter.
      01-22-2021, 03:29 PM   #407
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
I can tell you with certainty that the lifetime warranty is being announced very soon. (The S55 pumps they just announced carries a lifetime warranty). I'm unsure on the final price, but I think everyone should be happy with it.
Instagram | YouTube
      01-22-2021, 03:58 PM   #408
F87source
F87source's Avatar
Drives: Bmw M2
Good to hear they changed their mind on the warranty, if they didn't then imo they would be near the back of the pack when it comes to what a potential customer might pick as all of these pumps are so close to each other in terms of offering that every little bit will count.
I also am looking forward to seeing how much it will cost.
      01-29-2021, 10:25 AM   #409
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
A bit of an update on my Nostrum HPFP install. I mentioned in a couple other threads, but I thought I'd collect the info here.
My car was dropped off Monday at Nostrum. They did a quick inspection and put it on the dyno to get a baseline. My car is FBO at the moment, and I have the Bend Calibration Flex Fuel kit with the ID F750 fuel filter, flex fuel sensor, and Zeitronix ECA-2 can-bus content analyzer.
On the baseline dyno, the car made 384whp and 445wtq.
After that, they installed the Nostrum HPFP, and got their tuning numbers needed for BM3. Since it's going to take a bit to get the OTS maps updated to support the pump, we decided to go ahead and switch the car over to Ecutek and do a full flex fuel tune.
They finished tuning the base map on Ecutek yesterday for 93 octane fuel. I've been told the car made 405WHP on straight 93 octane!
Today, they are finishing up the Ethanol tuning, and I'm expecting it to be somewhere near 450WHP on a conservative ethanol mix. I'm picking the car up this evening and I'll hopefully have a bunch more info (data, dyno charts, etc) to share. Additionally, I'll be posting up another video in the coming weeks to do a review. I gave the media person at Nostrum one of my gopro's to collect some content for me, so I'm excited to get that back and start editing.
With regards to pricing on the Nostrum pump, I've been told the new price, but it has not been updated on the website yet. Once they do that, I'll be happy to share it. But if everything works out as I expected, the Nostrum HPFP may be the new number 1 player in the fueling game on the N55 platform as far as value is concerned.
Stay Tuned!
Instagram | YouTube
      01-29-2021, 11:02 AM   #410
designatedposter
Drives: m235i
"After that, they installed the Nostrum HPFP, and got their tuning numbers needed for BM3."
what do you mean by that? they submitted the necessary parameters to bm3? i thought you were on mhd?
M235i rwd 6mt
      01-29-2021, 11:15 AM   #411
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
Yes, they are sending the data over to PTF to add the Nostrum pump to the OTS maps on BM3.
Nope, never used MHD.
Instagram | YouTube
      01-29-2021, 01:05 PM   #412
F87source
F87source's Avatar
Drives: Bmw M2
Stay Tuned!
What dyno? Dynojet? And what was the correction factor?
Otherwise if that's a dynojet with sae or STD=5 correction then that's really really good numbers.
Also your stock tune baseline is abnormally high even with FBO, just another thing to consider.
      01-29-2021, 01:06 PM   #413
F87source
F87source's Avatar
Drives: Bmw M2
You should ask them to support MHD as well, for us mhd guys.
      01-29-2021, 01:14 PM   #414
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
I should have the charts and stuff later that will show that. The dyno they use is a dynojet. I'll see if I can find out what the correction factor was.
The baseline wasn't a stock tune. It was FBO with the BM3 Stage 2 93 octane map. My car did dyno just over 400WHP on the racegas tune over the summer, so I think the numbers are pretty close. And that was also on a dynojet.
Instagram | YouTube
Daleb263.00
F87source7251.50
      01-29-2021, 01:17 PM   #415
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
I'll certainly ask about it. Though I'd imagine if they have the BM3 maps it wouldnt be hard to adapt them to MHD.
Instagram | YouTube
      01-29-2021, 01:32 PM   #416
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
Minor update. While tuning for E85. the LPFP couldn't keep up. They went ahead and upgraded it as well. I do not have the specs yet but may have them later today.
Instagram | YouTube
      01-29-2021, 01:58 PM   #417
F87source
F87source's Avatar
Drives: Bmw M2
Yeah I expected that, lpfps can't flow enough to max out a stage 2 hpfp upgrade, however I didn't expect you to be able to max out a stage 2 hpfp on the stock turbo, or come close enough to make the lpfp dip low enough to cause issues.
Anyways I look forward to your results.
      01-29-2021, 02:09 PM   #418
ZM2
Drives: 2017 LBB M2
I think this all comes down to the E85 mix your tuning with. E50 and seem to not need an LPFP upgrade, unless you throw on a big turbo.
Are you doing full E85 or a mix?
