04-11-2018, 06:37 AM | #45 | |
Rep 3,696
I’m dropped 1/2” in the front, 3/4” in the rear (track setup) and run 265/35 and 285/35 4Ss on the street on OEM rims. The front rubs the fender liner under compression bc it’s too tall. Will go 255/35 after these burn up. I’m also throwing on 265/30 and 295/30 on some track wheels this Friday. Will need a 5mm spacer in the front to get ET 28 to not rub the suspension. Overall, I’ve been very happy. Makes the car look much better slightly lower with fatter rubber, much less roll on track, and comfort wasn’t negatively impacted. Last edited by ZM2; 04-11-2018 at 09:08 AM.. |
04-11-2018, 10:26 AM | #46 |
Public Last Class
97
Rep 244
Drives: 2018 M2 DCT LBB
ZM2 are your track wheels 18 or 19?
04-11-2018, 12:08 PM | #47 |
Rep 3,696
I have two setups: 18x9.5 that I run 265/35 square, and 19x9.5 & 19x10.5 for the 265/30 & 295/30.
With the same tire the staggered setup will be quicker, so I wanted to give it a shot and it will become my arrive and drive set. My 18s will now be used for slicks. |
04-11-2018, 01:29 PM | #48 |
Public Last Class
97
Rep 244
Thank you, great info. I’m thinking to do your staggered track setup too. I should do the math but how do the tire diameters compare to stock and front to back?
04-11-2018, 02:25 PM | #49 |
Public Last Class
97
Rep 244
Okay I did the math. Front diameter is about 1/2 an inch smaller and rear is about 1/4 inch smaller. So not much difference between stock and this up size. Only one KM/H slower on the indicated speed.
The 295 looks nice and wide but in reality it’s only about and inch wider. |
04-11-2018, 03:02 PM | #50 | |
Rep 3,696
Also, VMR 710FF’s are the cheapest wheels you’ll find for the staggered 19 setup. My shop just got them in. Doing my test fit on Friday. |
04-22-2018, 09:10 AM | #51 | |
Rep 98
My first impressions is the adjustability is amazing. And I have little doubt that the stiffer track setup will prove to be dramatically improved. I had a test drive with the rebound settings 3 clicks off the hardest settings (front and rear) just to see how it felt, and it is amazingly stiff. I’m back to the factory rebound settings per the manual (9 clicks open on front and 12 clicks open in the back). My first track days on this new setup will be in 4 weeks. Can report back once I’m done. |
04-22-2018, 03:37 PM | #52 | |
Rep 923
04-22-2018, 05:31 PM | #53 |
Rep 98
The street settings are just fine for the street. The track settings on the street are way too stiff. This is the first time I've ever had adjustable coilovers and am, thus far, impressed.
Will report back after next track weekend in late May. |
07-03-2018, 07:32 PM | #54 |
on restriction from buying more cars
239
Rep 186
Any updates? I’m trying to figure out which way I go. Thanks.
07-04-2018, 09:09 PM | #55 |
Rep 98
07-05-2018, 04:15 PM | #56 |
239
Rep 186
Awesome. I think I’m going to do the same set up, but hold off on the 18” wheels until next season.
08-13-2018, 03:58 PM | #57 | |
Rep 127
TIA
1997 Dakar M3
1999 Cosmos M3 2004 Imola M3 CSL clone 2017 Alpine White M2 Performance Edition |
08-14-2018, 06:15 AM | #58 | |
Rep 700
Nitron NTR R3 | StopTech Trophy Sport STR-60 380x32mm / StopTech Trophy Sport STR-40 355x32mm | Bridgestone RE-71RS | ADV.1 | CDV Delete | TMS Rear Camber Arms | RE Diablo's | 4.10 Gears | Euro Headers | RTD REVO1 Short Shifter
04-08-2019, 08:06 AM | #59 |
Όλα ρόδες
760
Rep 560
Drives: BMW
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
Is there any info on the difference in spring rates between the standard and the M Perf suspension set?
04-08-2019, 10:44 AM | #60 | |
Rep 139
gnx759.50 |
05-26-2019, 02:26 PM | #62 |
844
Rep 1,962
01-24-2021, 10:26 AM | #63 |
381
Rep 731
Was wondering how you like your Ohlins? What improvements do you notice on Track and Street. Were your Spring Rates 90/190? I am about to install a set.
At a Point above 7,000 RPM.
01-24-2021, 04:56 PM | #64 | |
Rep 923
For me the car is only slightly lowered and for me this is perfect for daily driving. On a cold Nürburgring the Öhlins was also a real joy
01-24-2021, 06:03 PM | #65 | |
381
Rep 731
01-25-2021, 04:11 AM | #66 | |
Rep 483
chief1richard381.00 |
