M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Fitment question
      02-13-2020, 04:22 AM   #1
hz101
Drives: 2021 M3C
Fitment question
I am thinking of going with the following aftermarket setup:
Wheels:
Front: 19" diameter, 8.5" width, 33mm offset
Back: 19" diameter, 9.5" width, 35mm offset
Tires:
Front: 245/35R19
Back: 265/35R19
Will there be any fitment issues? Any rubbing or need for spacers, etc.?
Appreciate any input!
      02-13-2020, 07:27 AM   #2
CTSean
Drives: LCI BSM MT M2
Those wheels are 1/2" narrower than stock
The front wheels will stick out 10 mm LESS than stock and the rear plane / backspacing is basically the same
The rear wheels will stick out the same as stock and logically the backspacing will be 1/2" less than stock
The tires are the same as stock
they will of course not rub because the diameter is the same and the new wheels fit inside the space of the stock wheels
You can look up here
https://www.willtheyfit.com/index.ph...8-5&offset2=33
hz101169.50
      02-13-2020, 07:43 AM   #3
hz101
Drives: 2021 M3C
Thank you for helping out a wheel noob!
      02-13-2020, 10:58 PM   #4
mr_lab_rat
mr_lab_rat's Avatar
564
Drives: 2017 M2, 2018 X1
You don't need spacers but adding 20mm front and 10mm rear would make the wheels flush with fenders.
      02-14-2020, 11:41 AM   #5
AlpsRider
AlpsRider's Avatar
2864
You might want to double check brake clearance.
      02-14-2020, 12:46 PM   #6
hz101
Drives: 2021 M3C
Getting the Rohana RFX5 wheels:
https://www.fitmentindustries.com/bu...l=M2&trim=Base
They should fit without any issues according to Fitment Industries. Will post pictures once I get them mounted!
      02-15-2020, 01:24 PM   #7
hz101
Drives: 2021 M3C
Do spacers affect driving dynamics at all?
      02-15-2020, 02:07 PM   #8
AlpsRider
AlpsRider's Avatar
2864
Yes, your mileage may vary.
      02-15-2020, 09:33 PM   #9
mr_lab_rat
mr_lab_rat's Avatar
564
Not significantly if you just add the same thickness front and rear to OEM wheels but in your case we are trying to bring non OEM wheels closer to stock fitment.
      02-16-2020, 08:56 AM   #10
hz101
Drives: 2021 M3C
I keep reading many downsides of using spacers. Guess I will only use them if the fitment doesn't look too good.
      02-16-2020, 09:11 AM   #11
CTSean
Can you just get wheels with a "shallower" offset so they stick out more than (or at least the same as) stock? The current wheels you are talking about will be deeper set in front than stock
I see they have the same front wheel with +20 offset - that at least puts the outer face of the wheel the same as stock (ok technically 2mm farther out).
      02-16-2020, 09:33 AM   #12
hz101
Drives: 2021 M3C
I really like the design of these wheels lol but yeah you're right they will be deeper in than stock. I could just add 10mm spacers at the front and not the back.
      02-16-2020, 09:38 AM   #13
hz101
Drives: 2021 M3C
The +20 is out of stock on this site...
