M2 Technical Topics > Suspension | Brakes | Chassis > Removing front strut nut
      01-29-2020, 09:37 PM   #1
243Racing
1448
I’ve seen 2 different DIYs for this and I came up with a question. I don’t have an impact driver. Is it possible (and advisable) to loosen the 18mm top strut nut on the front struts with just a wrench/breaker bar? One tutorial for the M4 a guy has a special “open” socket where he held the regular nut with a wrench while he loosened the strut nut.
TIA
      01-29-2020, 11:00 PM   #2
MR RIZK
MR RIZK's Avatar
758
Drives: AW M2C
The top nut may not undo unless you have the open socket as the piston may spin in unison. The impact driver spins the nut fast that's why it works but in saying that impact on top nuts are not recommended.
243Racing1447.50
M3SQRD2121.50
      01-30-2020, 09:53 AM   #3
Drop the hammer
Drives: '17 F87 M2 AW, Dct
Can put a 1/4 drive small socket with 4 inch extension onto the shaft (10mm if I recall correctly) then slip a larger 1/2 drive deep socket over top of it onto the nut. Then use 1/4 extension with 1/4 ratchet and use a pipe wrench or vice grip to turn larger deep socket over top. Much safer for the strut than using an impact as well.
      01-30-2020, 09:59 AM   #4
243Racing
1448
Thanks all. I went ahead and ordered the Schwaben strut socket , seems like the safest way to go.
      02-03-2020, 09:34 AM   #5
nearwater4me
Drives: '22 G82 Base
Where did you order the socket kit from?
I’ll be needing them in the near future, just wanted to get some info.
Thanks!
      02-03-2020, 10:58 AM   #6
243Racing
1448
Thanks!
I just ordered the individual socket. ECS had the best price incl tax and shipping. Pelican Parts also carries them.
      02-03-2020, 03:03 PM   #7
nearwater4me
Thanks for the info!
      02-03-2020, 03:04 PM   #8
Conissah
Conissah's Avatar
1576
Drives: 2018 M3
Would a box wrench and an allen key not work? Haven't checked the top of the strut, but I can't imagine it's super different from every car I have ever worked on.
      02-03-2020, 03:07 PM   #9
243Racing
1448
I was hoping this would work, however my struts don't have allen head bolts. I'm glad I checked before I started tearing the car apart to do the install.
      02-03-2020, 03:47 PM   #10
Mosely
Mosely's Avatar
594
Drives: '18 M2 | '20 X5 | '07 E92
I made this DIY: https://f87.bimmerpost.com/forums/sh....php?t=1595398
The recommended way is what I detailed in there, worked perfectly too not difficult and no issues on or off, you just need the 18mm pass through (make sure it's 12 pt, not hex). I bought a kit (crescent x6) or something that worked fine. Make sure you have a thin 1/4" 10mm that is at least 1-2" long to go through the middle (I had a few 10mm and only 1 worked).
I ordered the Shwaben tool at first but I'm pretty sure it only works for allen key cars or maybe if you have a tiny head 1/4" to get in there. I couldn't get it to work.
IG Photo Gallery:
instagram.com/dr_m2sko/
243Racing1447.50
      02-03-2020, 04:16 PM   #11
243Racing
1448
Great DIY - thanks for the link.
This is the one I found, where I learned of the Schwaben tool:
      02-03-2020, 05:41 PM   #12
Mosely
Mosely's Avatar
594
Looks much more difficult with that tool and the wrench and easier to strip the top mount. The pass through socket is much more secure and I don't know how you will reliably tighten the top mount nut to proper torque with the Schwaben set-up.
IG Photo Gallery:
      02-03-2020, 05:52 PM   #13
243Racing
1448
Yeah, and now I’m rethinking it some more with the additional info you provided about properly re-indexing and replacing certain bolts.
      02-04-2020, 01:28 PM   #14
M Fifty
844
Drives: M2 & 330CI
I would note that BMW don't suggest re-indexing in the official installation instructions for installing the M Performance Suspension. Make of that what you will.
      02-04-2020, 03:05 PM   #15
mr_lab_rat
mr_lab_rat's Avatar
564
Drives: 2017 M2, 2018 X1
You need an 18mm 12 point deep socket. I filed mine down on two sides so I can grab it with vise grips. 10mm on a 1/4inch to prevent the shock shaft from spinning.
      02-05-2020, 04:51 PM   #16
nearwater4me
Interesting. Always wondered how <1” drop could affect the wear in bushings.
