M2 Technical Topics > Suspension | Brakes | Chassis > Which Endlinks to buy
      01-28-2020, 11:26 AM   #1
GeraldM2
Drives: BMW M2 (F87) LBB 6MT
I just installed a set of Ohlins Coilovers on my car, and i want to get some front endlinks so i can corner balance the car. Which brand should i go with? Fall-line or SPL?
      01-29-2020, 12:53 AM   #2
MR RIZK
MR RIZK's Avatar
758
Drives: AW M2C
I used SPL on the 350z extensively and had no issues with any of their products. For me I would go SPL but maybe others will chime in.
wavyyyy1045.50
      01-29-2020, 10:46 AM   #3
mcvaughan
mcvaughan's Avatar
Drives: F87 Competition
SPL
Matt
      01-29-2020, 11:53 AM   #4
Anthony1s
756
Drives: 2018 Mineral Grey M2
I'm opposed to the SPL ones because they are not sealed. Meaning dirt will get into the bearing and damage it over time.
I have the Dinan ones, they are sealed but I'm not sure you can buy them separately. Will have to ask Dinan.
What I've found so far is that all front end links on the market are too short for a lowered car, and need to be completely maxed out to clear the control arm while the car is on a lift. Which isn't a problem at all during normal driving, but it is something I notice. Here's my thread on it.
https://f87.bimmerpost.com/forums/sh....php?t=1589062
The fall-line ones are sealed. Though they are the same length as OEM so you may run into the issue even more than I did, because the Dinan ones are shorter.
      01-29-2020, 12:47 PM   #5
mcvaughan
mcvaughan's Avatar
SPL was able to make me shorter links for my M4, so with that I think they have superior support. My M4 was more track than street though, so I can't comment on the sealed vs not.
Matt
      02-07-2020, 02:13 PM   #6
SEAT TIME RULES
SEAT TIME RULES's Avatar
1103
2020 BMW M2C  [5.00]
I'm going to install a TC Kline kit with the 400/700 lb spg setup.
Probably lowering it 1.5 " approx. Will I need to get some front and rear adj end links? If yes anyone use the HP Autosport ones?
2004 Mazda Rev It Up Finalist
2002-Present HPDE Instructor
      02-07-2020, 07:08 PM   #7
3t3p
New Zealand
455
I've never been able to understand what end links do?
      02-07-2020, 08:48 PM   #8
MR RIZK
MR RIZK's Avatar
758
Drives: AW M2C
https://www.cars.com/auto-repair/glo...-bar-end-link/
      02-07-2020, 11:16 PM   #9
booya_45
Drives: 2017 M2
End links are absolutely necessary to corner balance?
      02-08-2020, 03:30 AM   #10
M Fifty
844
Drives: M2 & 330CI
If you're a seller of adjustable end links - yes.
      02-08-2020, 11:31 AM   #11
Anthony1s
756
Yes, you do. Because without them the swaybar puts preload on the suspension. pre-load is additional force pushing the wheels down.
When you corner balance, you disconnect the swaybar to get rid of any pre-load. Then after the car is corner balanced, you reconnect the swaybar with the correct endlink adjustment to not add any preload while on the scales at idle suspension.
M2RAW121.00
omak81148.00
      02-08-2020, 12:02 PM   #12
M Fifty
844
Drives: M2 & 330CI
Unless you're setting the ride height significantly differently across the axle, they seem superfluous.
Obviously, if you are going further than the the play in the rollbar bushes and difference in size between the balljoint bolt on the end link and the fixing hole you will need these. In the meantime, just slacken the end link fixings while you corner weight and if it is binding fit an adjustable on one side.
HTH
      02-15-2020, 07:02 AM   #13
Big Fabri
Big Fabri's Avatar
Italy
95
Drives: Lamborghini Huracan
this is true but only if you go very very low to the ground
