M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Speed in each Gear
      01-26-2020, 07:16 PM   #1
Ilikemike
Ilikemike's Avatar
251
Drives: E92: F82: M2C: M2 CS (Now)
Speed in each Gear
Wondering what the manual M2 competition's max speed in each gear, anyone know?
      01-26-2020, 07:50 PM   #2
Kohner86
Drives: 2020 M2C
You could probably compute it from data in the manual. From memory 1st tops out around 40 and 2nd around 75, 3rd around 110.
      01-26-2020, 08:02 PM   #3
Ilikemike
Ilikemike's Avatar
251
Thanks but there ought to be a road test with that data, I just haven't found it 🙂
      01-26-2020, 09:54 PM   #4
Zoomzoommo
Zoomzoommo's Avatar
53
Drives: 2020 M2C
      01-26-2020, 10:08 PM   #5
Daytona_550
Daytona_550's Avatar
Drives: '20 M2C / '08 550i / '23 330i
These gear ratios came from a Road & Track (or maybe Motor Trend) review of the M2C. I have them loaded on Harry's Laptimer. Hope it helps!
Ilikemike250.50
      01-27-2020, 12:58 AM   #6
VIERsr
Switzerland
2621
Originally Posted by Zoomzoommo View Post
The tire diameter is 26.30 in.
      01-27-2020, 07:42 AM   #7
Zoomzoommo
Zoomzoommo's Avatar
53
Drives: 2020 M2C
VIERsr2620.50
      01-27-2020, 01:55 PM   #8
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
Joking aside, that depends on tread wear, pressure and load....
Under acceleration squat will reduce rear tyre diameter too.
All very approximate of course
But 110 top of third seems about right.
      01-27-2020, 05:50 PM   #9
Drop the hammer
Drives: '17 F87 M2 AW, Dct
Can someone run the numbers for a dct? I don’t have the gear ratios.
      01-27-2020, 09:17 PM   #10
Zoomzoommo
Zoomzoommo's Avatar
53
Drives: 2020 M2C
The gear calculator I used only accepts up to 6 forward gear ratios...
      01-28-2020, 10:46 AM   #11
AZ-Wildcat
AZ-Wildcat's Avatar
620
Drives: BMW HS M2C DCT
Obviously goes by in a blur, but 1st-3rd seem VERY close for DCT. I was doing some "testing" last weekend.
      01-28-2020, 02:37 PM   #12
alan7467
Drives: 2022 Sketchers
This calculator is a bit clunky to setup, but it allows for up to 8 gears:
https://www.blocklayer.com/rpm-gear.aspx
Here's the output I got for DCT:
Edit - might as well post the graph for the manual...
2022 Sketchers
natmad667.00
Got f1?681.00
      01-29-2020, 08:10 PM   #13
natmad
Drives: M2C 6MT, M3C Build Week 43
Alan7476, thanks for posting the graphs above!
Gives me a good visual on the rpm drops with each gear change.
I’m surprised the first to second drop in rpms is bigger on the DCT than the manual.
      01-30-2020, 02:14 PM   #14
cecaa850
The N55 dct M2 will do 120 in 4'th. I've been doing a bunch of 4'th gear pulls lately while going through the tuning process. Hadn't checked the other gears.
