01-23-2020, 08:14 AM | #23 |
Rep 198
Dinan_Engineering
My DME was mailed to Dinan and then tuned with HE a few months ago. Now I want to upgrade to HE+. However, my tuner says my DME needs to be sent to you guys for unlocking a second time. I thought I could reflash from HE to HE+ once the DME was unlocked, but I can't. My understanding is, I will have to have the DME removed a third time and sent to Dinan in order to load the stage 1 tune once I am out of warranty. Obviously, if I knew I had to spend $800 in labor and a week in the shop just to switch maps I might never have chosen Dinan in the first place. Would you care to comment more in detail as to why my car can't be permanently unlocked and how widespread this problem may be for other S55 owners?
01-23-2020, 08:27 AM | #24 | |
Rep 699
Well that sucks. |
01-23-2020, 08:32 AM | #25 | |
Rep 3,128
On Thursday/Friday we had a temporary glitch where the update process wasn't working. The software department pushed a programming update for testing of MG1 on the live server before it was fully vetted that caused some issues but that was resolved towards EOD on Friday. So the dealer may have just had unlucky timing and run into that which is causing the confusion maybe. Regardless, let me know the dealer or have the dealer reach out to Dinan support and we can go over whatever issues they may be running into. |
01-23-2020, 04:23 PM | #26 | |
Rep 198
I already resolved the matter with my dealer, Turner Sevice, I just want a better, more technical explanation than what Turner could give me. Also, so that others who may have the same issues as me don't end up spending $800 to switch maps. Last edited by DriverDaily; 01-23-2020 at 04:35 PM.. |
01-23-2020, 04:48 PM | #27 | |
Rep 3,128
For your specific case--- Talked to tech support and inquired about anything with Turner and it turns out your flash was just bad timing with the previously referenced errant update that messed up the updater services for those few days. You happened to be at the outset of the issue when we were unaware exactly how long the fix may take so rather then wait and hope for a timely resolution what was opted for was Turner sending it in so we could do it manually. At the time, not knowing resolution timetables, it was the most expedient solution. This was an issue with our server which caused this though so there should be no expense on your end with Dinan covering the labor to pull out / reinstall the DME. This was confirmed with tech support so Turner should be sending us a bill for that labor and not passing on that expense to you. All that said, the update that caused the issue has been rectified so no one else should have the problem. |
01-23-2020, 05:36 PM | #28 | |
Rep 198
02-01-2020, 03:15 PM | #30 | |
Rep 198
I had HE plus and an Eventuri intake installed. However, something is very wrong. The car idles rough on cold start and only made 375whp on Turner's Mustang Dyno. I was expecting 450+. My first guess is the MAF was installed incorrectly or clamps are loose and air is getting in after the MAF. Can't give my impressions until that is fixed. |
02-03-2020, 07:38 AM | #31 |
dentite
339
Rep 759
Drives: 718 GT4, M2C, JLU392, e92 M3
To clarify, if upgrading tunes from HE to HE+, there is no need for the dealer to flash back to stock file before loading the new software, hence no need to send the DME out to have it unlocked again?
02-03-2020, 08:31 AM | #32 |
Rep 3,128
04-18-2020, 08:26 PM | #33 |
Rep 19
How exactly does the matching warranty coverage work with a tune?
If lets say I'm denied warranty coverage from the dealer because I have a tune for a spun crank hub will I be covered? |
04-18-2020, 09:59 PM | #34 |
Rep 4,976
Read the warranty agreement on the site. And if something happens, Dinan should work directly with your dealer. At least that's how they used to do it, and how CarBahn does it now.
Current Car: 2018 F80 M3CS, SMB, DCT, ZEC, MPE Recently Departed: 2020 F87 M2C, LBB, ZEC, 6MT (Euro Delivery Aug. 29, 2019, totaled by an idiot in a Camry who then ran from the scene) Wife's Prior Car: 2018 F80 M3, Yas Marina Blue, DCT, Black 19s, Carbon Structure Anthracite Cloth/Leather Combination, Driving Assistance Package (Euro Delivery Oct. 9, 2017) |
