10-23-2019, 04:59 AM | #199 | |||
Rep 65
Which suspension to use in order to get rid of spacers? |
10-23-2019, 10:34 AM | #200 |
Rep 719
Thanks Champ!!
I am going to order the 22 and know for sure I can get away without running a spacer. I assume you have zero rubbing on the front when you were running 7.5mm spacer. BTW how much are you lowered by. Thanks once again for all you help and input |
10-23-2019, 10:41 AM | #201 | |
Rep 719
running camber plates maybe he can chime in and comment. but either you way lower than he is and with a 5mm spacer you at ET 23. can you run the with no spacer and have enough clearance on Strut? |
10-23-2019, 03:33 PM | #202 | |
Rep 116
Mperformance coilovers and tck plates. -3.2 degrees negative camber. No rubbing inside or outside. |
whoop_ass355.00 |
10-23-2019, 11:29 PM | #203 | |
Rep 719
Exactly what I have been saying you can get away with going with the ET22 wheel but i think camber plates are a must to clear the fender. Waiting Patiently for Apex to release the EC-7R in 19" hurry up already APEX!! |
10-24-2019, 09:03 AM | #204 |
Rep 65
Can not, this is causing the issue...
10-24-2019, 11:33 AM | #205 |
Rep 719
10-24-2019, 02:35 PM | #206 | |
Rep 65
Hope I will have the perfect clearance because I am rubbing hard on the front right now. |
12-17-2019, 09:48 AM | #208 | |
Food Critic
1086
Rep 1,015
Also, any pics of folks using these wheels with 255/35 - 275/35 street tires?
12-17-2019, 01:38 PM | #209 | |
3511
Rep 6,732
We don't have any photos yet of that particular tire combo, but I'd also be prepared to dial in about -2º of front camber to ensure clearance with the spacers added. --Dylan
02-10-2020, 03:36 AM | #210 |
Rep 130
Planning on running 19 ec-7 with street tyres pss/ps4s. 265/30 front and 285/30 rear. Anyone running this with lowering springs for example H&R 30mm front and 20mm rear?
02-21-2020, 01:57 AM | #211 |
Rep 719
ye i don't see a problem as the issue comes with the spring perch of the coilover kits, stock strut has plenty space and with going with a shorter 30 profile tire it fits no problem.
02-27-2020, 12:19 PM | #212 |
Rep 940
05-13-2020, 09:21 PM | #214 |
Rep 1,647
What suspension are you running here? Any spacers on the front? I'll be running the same wheel/tire setup, most likely with Ohlins. Hoping to avoid needing spacers.
05-16-2020, 05:25 PM | #215 | |
Rep 521
Montaver2140.00 |
05-19-2020, 08:10 AM | #216 |
Rep 943
Updated picture for the wheel reference.
Running 255/275 combo as suggested in the original post for RE-71R. Suspension is M Performance.
05-21-2020, 01:59 AM | #217 |
Rep 183
Man Apex really dropped the ball on this wheel release from the get go. It should not take 10 pages of posts to decipher what works and what doesnt. First they say camber plates are needed, then they kind of back pedal and say well dont need them. Then you got a whole butt load of people needing to run spacers on these so called M2 specific wheels. This is a joke. If you want to offer a wheel set up that would work on the M2/M2C fine. But don't say as if it its custom built for the M2 when you gotta run camber plates and/or spacers to get things not to rub of suspension components or the actual damn sheetmetal of the car. If you are having issues with the front, offer a half inch narrower wheel with a custom offset that will work without any camber plates or spacers for stock or modestly lowered set ups. I'm suprised no one has the balls to say it like it is.
2019 M2C Sunset Orange 6MT
Eventuri Intakes Eisenmann Valved Full Exhaust |
05-21-2020, 08:17 AM | #218 | |
Rep 943
no issues here with MPerf Suspension running on 255/275 RE-71R. no camber plates. no spacers.
F80_Katz764.00 |
05-22-2020, 10:44 AM | #219 | |
F80_Katz
764
Rep 439
Drives: 2020 M2 Competition
That being said, the real issue is how available they are. Back ordered with a couple month wait usually turns people off. I'd get another set just for the hell of it if they were in stock. |
05-22-2020, 11:43 AM | #220 | |
Rep 141
