M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Anyone running 265/285 tire setup yet?
      01-16-2020, 02:39 PM   #45
Expert@ApexWheels
Expert@ApexWheels's Avatar
3511
Drives: M3
Originally Posted by Andi-M2 View Post
Thx for your listing, Max!
Just wanted to ask for your recommendation:
I've got a set of Protrack One in 10x18 +20 and 10,5x18 +40 and plan to run 265/35 front and 285/35 rear. Car is lowered on KW CS 3-way.
Would you think, 265/30 and 285/30 (or even 295/30) is a better choice?
The wheel set is only for track use.
That's an aggressive front fitment, but with a good amount of negative camber, it will clear the fender edge. Since this is a track setup, you'll want to dial in a healthy amount of negative camber anyways (tire dependent, but ideally beyond -3º up front). We outfitted Tyspeeds M2 club racer and Pikes Peak hill climb car with a 18x10.5" square setup with 295/30-18 Toyo RR's, so with the right adjustments we know what this chassis is capable of
Keep in mind, KW's are notorious for eating up inner clearance due to their silhouette and overall spring stack height with helpers, so depending on the tire size and brand that you go with, you may very well need to run slim spacers up front or modify the spring configuration (run shorter main springs and/or remove the helpers) to raise the lower spring perch so it sits above the tire rather than next to it.
In regards to ideal tire size, it will come down to a number of contributing factors including how the car is set up, your personal preference and driving style, as well as tire availability. Do you have a particular compound in mind? This will help narrow down which tire configuration(s) you could potentially go with quite quickly
Any of the following configurations are on the table with your wheel specs:
F: 265/35-18
R: 275/35-18
F: 265/35-18
R: 285/35-18
F: 265/35-18
R: 295/35-18
F: 265/35-18
R: 295/30-18
F: 275/35-18
R: 285/35-18
F: 275/35-18
R: 295/35-18
F: 275/35-18
R: 295/30-18
      01-16-2020, 03:30 PM   #46
Anthony1s
756
Drives: 2018 Mineral Grey M2
F: 265/35-18
R: 275/35-18
F: 265/35-18
R: 285/35-18
F: 265/35-18
R: 295/35-18
F: 265/35-18
R: 295/30-18
F: 275/35-18
R: 285/35-18
F: 275/35-18
R: 295/35-18
F: 275/35-18
R: 295/30-18
Can you please respond to my previous question. How does 285/35 on a 19x10 wheel have negative handling due to tire bulge, when your recommended 295/30 on a 19x10.5 wheel is the same proportionly?
      01-19-2020, 04:30 PM   #47
YasPlz_CSL
Drives: 2023 BMW M4 CSL
265/30 - 295/30 here
Check out more pics - @Hockenheim_M2C on insta
      01-20-2020, 01:19 AM   #48
Andi-M2
Andi-M2's Avatar
Germany
193
Drives: M2 F87
F: 265/35-18
R: 275/35-18
F: 265/35-18
R: 285/35-18
F: 265/35-18
R: 295/35-18
F: 265/35-18
R: 295/30-18
F: 275/35-18
R: 285/35-18
F: 275/35-18
R: 295/35-18
F: 275/35-18
R: 295/30-18
Thx for your recommendations!
For this, I will go with 265/35 + 295/30-18, as well.
