01-10-2019, 11:30 AM | #1 |
Rep 210
The M3/4's run F: 255/35 R:275/35 stock on the same width wheels as us (9,10).
Some models come with F: 265/35 R: 285/35. Most M3/4 guys run F: 265/35 R: 295/30 or 35. I plan on putting the rear tires up front and buying 285/35 for the rear. Both are the max recommend size for the width and maintain the same circumference stagger (0.6") F/R. Has anyone else done this yet? Wanting to see how it looks with a meatier tire at stock ride height.
2020 X3MC, 2019 M2C
'14 F-150 Tremor, '99 Mustang Turbo |
01-10-2019, 11:38 AM | #2 |
Rep 2,251
There is more room for tire on the M3/4. I believe 265/35 tires will likely rub in front on an M2C, but 285/35 may be ok in the rear.
I recently put some 255/275 MP4S on and it's tight but so far so good... |
01-10-2019, 11:48 AM | #3 | |
Rep 210
Looks like I'll wait till these need replaced. I was going to go for it since I can use the 245 front tires on my other BMW but I can't use the 265's.
2020 X3MC, 2019 M2C
01-10-2019, 11:55 AM | #4 |
Rep 496
People have fitted 295's in the rear
2019 M2C DCT | Alpine White
Full AA exhaust (catless DP/signature exhaust) | M Performance Coilovers | Need to find some new wheels! |
01-10-2019, 12:01 PM | #5 |
Rep 3,659
Drives: 981 Cayman GTS
As soon as my rear tires are worn, I'm switching to 265/30/19 front and 295/30/19 rear.
Project_F871231.00 Die ///M Rakete671.00 |
01-10-2019, 01:12 PM | #6 |
Rep 212
265 in the front rubbed the front fender protector, I went to 255 barely any space, but works. 285 in the back no problem.
2019 M2C Sunset Orange/Black (Ohlins/swift coilovers, Ground Control Camber Plates, Dinan Heat exchanger, BM3 ECU tune, CF mirror caps, diffuser and rear spoiler, Vorsteiner V-FF 101 Patina Bronze wheels)
01-10-2019, 01:38 PM | #7 |
Rep 36
285/35 fits easily in the rear, and 265/35 works fine in the front (unless you plan to lower your car). You *might* get a touch of rubbing in the front on full lock, but it's negligible.
f87 s55
e92 n54 e30 m20 |
01-10-2019, 01:44 PM | #8 |
Rep 210
Do you have a picture of 255/285 setup? I'm assuming 35 sidewall on both?
2020 X3MC, 2019 M2C
01-10-2019, 01:45 PM | #9 |
Rep 3,659
01-10-2019, 05:09 PM | #10 |
Rep 212
Vorsteiner V-FF 101 Wheels
Front- 5x120 / 19x9.5 / +22 Offset / 265-35-19 Hankook V12 Evo 2 Rear- 5x120 / 19x10.5 / +34 Offset / 285-35-19 Hankook V12 Evo 2
dnizzle23.50 |
01-10-2019, 05:23 PM | #11 |
Rep 845
Yeah try 30 sidewall next time. Should fit great with 265/30 and 295/30
Instagram: @Project_F87
01-10-2019, 06:09 PM | #12 |
Rep 212
01-10-2019, 06:27 PM | #14 |
Rep 212
pretty much, iPhone XS MAX, it has been raining and the car is dirty. But, these are patina bronze, nicer looking on the SO than gold 763m.
01-11-2019, 09:09 AM | #15 |
Rep 75
Drives: M2 Comp
wonder if this is possible on 788m's?
01-11-2019, 09:16 AM | #16 |
Rep 210
2020 X3MC, 2019 M2C
02-03-2019, 12:21 PM | #17 |
Rep 357
I have Vorsteiner V-FF 103's in 19x9 et21 and 19x10.5 et40, fr/re respectively.
Waiting for Conti tires in 255/35 and 285/30, fr/re respectively. Yes, i'm getting Cont's only because I have access to them at a huge discount. Hopefully they will clear on stock suspension. Anyone used this combo? These will become my "street" wheels/tires. I will use my "stock" wheels/PSS tires for track. |
02-06-2019, 11:37 AM | #18 | |
Rep 212
02-07-2019, 06:05 PM | #19 |
Rep 199
Check out the wheel set up on this M2
265/35/19 F 285/30/20 R M763 Wheels and MPerformance Coilovers https://f87.bimmerpost.com/forums/sh....php?t=1392603 |
02-11-2019, 04:05 AM | #20 |
Rep 96
I'll Pass
I'm sure the larger tires will look a little better, but my concern is the change in handling; I'm not sure it will be better. The increase in grip means you'll likely need an increase in power to compensate. I went to a larger wheel on my 135i and car never quite let go in the rear the way it used to. And when it did, It wasn't a smooth slide. I think I'll trust BMW in what should be the appropriate setup.
02-11-2019, 04:17 AM | #21 | |
Rep 4,512
Current '22 X3M LCI.. |
AM///X3M361.50 |
02-11-2019, 07:46 AM | #22 |
Rep 244
surprised of these 285/35 and 30 setups.
I`m going with 255/30 and 295/25. or 235/30 and 275/25 lol, had that setup on my 6 series with 9/11" wheels. |
