04-03-2018, 06:22 PM | #1 |
Rep 1,459
Heat Soak?
To those who have been running stock M2's on the track or (very) spirited street driving: Are you experiencing any overheating / heat soak issues?
Looking forward to a few events this year, but concerned too since this is the my first turbo car. I don't want to mod to maintain manuf warranty. |
04-03-2018, 06:27 PM | #2 | |
Rep 3,681
04-03-2018, 09:46 PM | #4 |
Rep 3,681
M3 Adjuster7904.50 |
04-03-2018, 09:49 PM | #5 |
Rep 442
Drives: 2017 M2 6MT, 2022 X7 M50i
Running stock. No heat soak issues whatsoever. This car needs more grip than power on the track.
04-04-2018, 03:56 PM | #6 |
#savethemanuals
2426
Rep 1,967
After tossing these cars around in Thermal CA and knowing how hot it was and gets, I would not be too worried about heat soak. These cars are pretty durable.
04-05-2018, 07:15 PM | #7 |
Rep 3,402
I live in AZ so on the hottest days 118ish I will get some heatsoak but when I track it I do it during the fall, winter or spring so 90ish or below I have not had an issue. I have a stage 1 VF engineering tune. If your going to track during hot days and or mod from what I have read the CSF radiator mod is the way to go. The heat soak issue is largely due to insufficient radiator cooling resulting in high coolant temps and to protect itself the car pulls power. I have decided to not mod my car for this very reason. I will eventually do this and all of the other CSF cooling mods but not for a while.
Chances are that you will not have much of an issue with heat soak, I have driven the M2 at thermal on three occasions twice with temps over 90 degrees and those cars are driven with AC on and idle between sessions and heat soak is not an issue for them really. I assume on the 115 degree days just about any car is going to have some heat soak. |
04-06-2018, 10:44 AM | #8 | |
Rep 4,496
Fettled M135i EB AT - gone but not forgotten:
AW M2 DCT |
04-06-2018, 11:13 AM | #9 | |
Rep 3,681
Any boost increase mod really needs a larger intercooler. I would have power reduction 10min into a session on 85F and higher days. My Dinan IC fixed that, but I still get slight power reduction after 35min on 100F open track days. I’ll go with the full CSF cooling package when I get the Dinan big turbo later this year. Hoping I can run the AC full blast and still have lots of power! |
04-06-2018, 11:20 AM | #10 |
Rep 466
Drives: M2CS
My Dinan intercooler arrives in a couple of days. I have experienced heat soak in some other cars and it is not a nice thing. I'm taking precautionary measures now. And if it drives even better on the road, why not?
04-07-2018, 04:27 PM | #11 |
Rep 3,402
There is a fellow here that posted the data saying the opposite, says the coolant temps are the biggest issue, he put the CSF radiator in and says the issue is resolved. I believe he posted this in the tuning section but you might find his data interesting. I am no expert so I'm not arguing just thought I would share what he found.
12-10-2019, 02:36 PM | #12 | |
Rep 198
12-10-2019, 02:47 PM | #13 |
Rep 1,823
Wow, thread revive!
2 and a half years later and I can vouch for what ZM2 said. He was spot on. I'm stock in terms of engine and no noticeable heat soak on my car. Of course south Germany doesn't often see 100F weather but still.
2017 BMW M2 German Spec
ZM22785.00 |
12-10-2019, 03:18 PM | #14 |
Rep 3,681
12-10-2019, 04:13 PM | #15 |
Rep 565
There is no octane/flexfuel sensor on these cars, right? How will higher octane or ethanol prevent timing pull as temps go higher. There has to be more to it than just putting in higher octane or ethanol. Are you saying that higher octane or ethanol will prevent knocking/detonation (with high temps) which, in turn, will result in less timing pull? I am not trying to question you, ZM2, just trying to learn and confirm what I think I know about cars. Thanks!
ZM22785.00 |
12-10-2019, 04:16 PM | #16 | |
Rep 3,681
M2guru374.50 |
12-10-2019, 10:00 PM | #18 |
Rep 650
I have an Awron gauge which logged 140 plus IAT at Road Atlanta...the car felt like it was pulling timing. Put on Wagner Evo 1 comp ( plus larger oil cooler) and problem solved...temps are roughly 30 degrees lower.
12-11-2019, 06:41 AM | #19 |
Rep 1,190
How does the cooling system on this car compare to the F80/82? I assume the OG M2 is not as capable, is the M2C identical to its big brother or are there minor differences?
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
12-11-2019, 10:17 AM | #20 |
Rep 281
I ran my M2C at Willow Springs this year with just a BM3 stage one tune. The whole weekend it was 100-105 degrees and the car did awesome. Zero issues. The driver definitely had heat soak issues.
cptobvious2531.50 |
12-11-2019, 01:08 PM | #21 | |
Rep 6,631
OG m2 cooling is not good, small air to air IC instead of air to water. |
Racer201029.50 |
