10-20-2018, 06:16 AM | #2091 |
Rep 1,237
Drives: M2 Competition
Yes as i have already answered a post before
10-23-2018, 12:03 PM | #2092 |
Rep 682
Just got an update today to v 2.14.
One of the "what's new" is: - SPORT+ coding in basic mode. Anyone know what that is?
10-23-2018, 12:11 PM | #2093 | |
Rep 1,237
It's probably aimed at all normal BMW's with DCT or Automatics which normally only offer "Drive" and "Sport" but not Sport Plus modes?
10-23-2018, 02:29 PM | #2095 | |
Rep 1,899
https://reddit.com/r/cars/comments/7...e_lights_when/ |
AndrewC198910929.50 |
10-24-2018, 03:30 AM | #2096 |
Food Critic
1086
Rep 1,015
Two things:
1. whenever I code something with bimmercode, I lose all of my saved shortcuts (1-8) and have to redo them all. Every time. 2. Is there a way to get both the driver and passenger mirrors to angle down when reversing? Additionally can I change the angle? Right now the passenger mirror angles down but it angles down way too far, I want it to be about half of that value. Any insight?
10-24-2018, 08:58 AM | #2097 | ||
Rep 4,551
Drives: 2015 328d xDrive
Tilt angle can be adjusted in Expert mode. Front Electronic Module > Expert Mode > ASP_BORDSTEINAUTOMATIK_DELTA > Custom Value |
NYC Bimmer259.50 |
10-24-2018, 07:32 PM | #2098 |
Food Critic
1086
Rep 1,015
Awesome thanks!!
10-24-2018, 08:24 PM | #2099 | |
Rep 444
2018 F87 LCI gone but not forgotten
2021 G80 6MT BSM |
10-25-2018, 12:58 AM | #2100 |
Food Critic
1086
Rep 1,015
Right, I'm aware of that, but it angles down waaay too far. My previous car had both mirrors angle down and it was only about halfway, so you can see both the ground and behind you. Extremely helpful and easy to park in reverse. Not so much with the M2 mirrors... I'm still getting used to it.
randyt224.50 AndrewC198910929.50 |
10-27-2018, 12:33 PM | #2101 |
Rep 5
Anti-Glare High Beam (AGHB)
Hi guys - I do not think it is possible to code Anti-Glare High Beam using Bimmercode. Has anyone done this using some other method, and if so, how? I like the simplicity of using Bimmercode but also want to see about AGHB. I may have to pay someone to remote code my AGHB and then I can use Bimmercode to experiment on my own with the other things.
10-27-2018, 02:34 PM | #2102 | |
Rep 682
10-27-2018, 02:52 PM | #2103 | ||
Rep 1,899
10-27-2018, 03:29 PM | #2104 | |
Rep 797
10-29-2018, 01:29 AM | #2105 | |
Food Critic
1086
Rep 1,015
Just curious if anyone knows why when I code the car it deletes all my shortcuts?
10-29-2018, 02:22 AM | #2106 | ||
Rep 797
10-29-2018, 08:00 AM | #2107 |
Rep 326
10-29-2018, 08:04 AM | #2108 |
Rep 1,237
Having this as well, but only if i code something in headunit
10-29-2018, 08:54 AM | #2109 | |
Rep 326
Drives: 2021 X5M
I have not checked if you can backup user profile to USB then restore them from there after coding maybe |
///M Houbi1655.00 |
10-29-2018, 12:59 PM | #2110 | ||
Rep 1,237
10-30-2018, 08:02 PM | #2111 |
Rep 43
I coded my left rear fog light today using the following:
ECU Module Option Default New Value FEM_BODY 3060 NSL_Verbaut nicht_verbaut Verbaut REM 3063 Mapping_Nebelschlussl_L_output off nsl_l However, when I push the button to activate, I get the error "Left two-stage brake lamp malfunction." The error clears when I turn the car off and back on. Do I need to code out the Dynamic Brake Force to avoid this error? |
10-30-2018, 08:41 PM | #2112 | |
Rep 4,551
https://f87.bimmerpost.com/forums/sh...8&postcount=50 |
NYC Bimmer259.50 |
