02-06-2018, 01:16 AM | #288 |
Rep 6,635
02-06-2018, 09:38 AM | #289 |
Rep 485
Mine sounded like I was dragging a thin piece of sheet metal backing down my driveway the other day, then kind of shrieked/squealed going forward. Definitely a pebble. I pushed on the brake shield on all four corners, drove a bit and it finally grabbed hard enough to break into small enough pieces to fall out.
terrywang94.00 |
03-25-2018, 03:18 PM | #290 |
Rep 1,459
This has happened to me 3 or 4 times in the last couple days! Can anyone confirm if the puma number listed in the first post is accurate, and if their dealership agreed to repair? I'm concerned I'll be given a hard time since it's tough to duplicate.
03-26-2018, 09:48 AM | #291 |
Rep 1,644
It was officially added to the same tsb as m3/m4 last August. Dealers should be doing now at request without issue. Not sure if it applies to 2018 models or not though (supposedly comes with the fix).
I will say since i had it done last year on my 2017 I have not heard it. |
07-11-2018, 06:44 PM | #292 |
Rep 573
I have 8,200 miles on my MT 2018 and today I heard the "soda can crunch noise" (and it was not the same as the pebble in the brake shield which I have had before). It was a pretty scary noise - almost pulled over to look under the car! I was going about 10-20 mph. Later that same trip (out to eat and back) it never did it again. Has anyone else had this issue on a 2018?
AndrewC198910929.50 |
07-14-2018, 12:44 PM | #293 |
Rep 211
Ticking noise when turning
I have 2018 with 6000km. I just noticed when I was in an underground parking lot I heard a faint tick noise when turning. Anyone else experience this? Going to take it into the dealer to see if they find anything
arquitecto535.50 |
07-14-2018, 05:03 PM | #295 |
Rep 134
Drives: BMW M2 Coupé (BSM)
have you taken the wheels off your car recently?
a common issue causing this are the wheel bolts not torqued properly at 140NM. Many reported cases on the forum |
arquitecto535.50 |
07-15-2018, 04:03 AM | #296 |
Rep 88
Good to know. Hearing this on mine as well. Interestingly, had the same issue with my M240 so wondering if this is a 2 series issue or possibly caused by potholes?
07-15-2018, 11:44 PM | #297 |
Rep 220
I know EXACTLY what this is. Pebbles in your rotor shields. Take it in and get them emptied out. There's a TSB for it as well, I think with a new shield.
I had it in for exactly that and first they blamed my aftermarket wheel centers. But the problem persisted after they removed them. Took them a while but they figured it out. They're back but still pretty quiet, and one day when I'm not so lazy I'll dig up the TSB and have them run it. If you pay attention, you can probably hear it when you're close to a J-wall or something else that bounces the sound back at you. |
07-16-2018, 09:17 PM | #298 | |
Rep 4,551
Drives: 2015 328d xDrive
07-17-2018, 08:49 AM | #299 |
Rep 289
Drives: '18 M2 MG 6MT, '03 E39
I hear the same thing when turning in my parking garage. It sounds exactly like the sound steel brake discs make when they start clicking when parked after a drive.
It is so similar in fact that I always thought it was due to the brakes being designed as “floating calipers” and being free to expand and contract but never checked in to it any further since I thought it was normal. There is an M4 in my garage with the same brakes and wheels and it also makes an identical sound. Also, the LCI models already come from the factory with the updated brake shield so not sure if that would be the same fix as in Pre-LCI with the original shield design. The only difference from the brake clicking noise from previous cars is that on the M2 it happens when turning and is a lot more repetitive in frequency. It seems directly proportional to the load going through the wheel and tire. That is what lead me think of the brakes being the culprit but the wheels being loose theory would create a similar scenario. I will have to check my lugs to see if they are loose and see if that makes the sound go away.
Current Car | 2018 ///M2 MG 6MT
Previous Car | 2003 E39 530i Sport Last edited by arquitecto; 07-17-2018 at 08:55 AM.. |
07-17-2018, 10:22 AM | #300 |
Rep 1,889
Drives: M5 CS / iX 50i
See the bottom repair order.
https://www.instagram.com/day_laborer/ (DM me from this account) Email: nextlevelautobrokersdc@gmail.com Part-time with Next Level Auto Brokers, LLC https://www.instagram.com/nextlevelautobrokers/ |
arquitecto535.50 terrywang94.00 |
07-17-2018, 01:42 PM | #301 |
Rep 211
Thanks guys, will be taking it in this week. Hopefully no issues with the fix.
Though, the SA told me if they find no issues they will charge me a diagnostics fee..... |
08-06-2018, 07:39 PM | #302 | |
Rep 220
Just curious, how did this turn out? based on the post 2 up, it seems to have been a different solution (and cause) that what I was told by my dealer. I'll try to find the invoice and post it here for future searches. But am very curious how yours turned out. |
08-16-2018, 04:38 PM | #303 | |
Rep 220
I think this thread has died out, but thought I'd add my invoice and the "fix" my dealer applied for what seems to be the same symptoms as OP.
It was an easy fix, but they didn't know that when we scheduled it. So they gave me a loaner 230i, which I thought was fun until I wanted to go somewhere. Anyway, I got hit while I was driving their car, bummer for them but I'm glad I was in a loaner! Quote:
Last edited by CantComplain; 08-16-2018 at 04:44 PM.. Reason: trying to get the *(%$# photo to work |
terrywang94.00 |
08-16-2018, 05:23 PM | #304 | |
Rep 6,930
Drives: 2018 M2 AW DCT
08-17-2018, 03:57 PM | #305 |
Rep 573
Can someone tell me what is actually clicking? I notice this during track days when turning - and it's so consistent and regular that it's not junk hitting the shield. How does the "drive flange" contact the rotor and what is the "drive flange?"
08-17-2018, 10:43 PM | #306 |
Rep 797
It's small pieces of road debris or rocks stuck in the brake shield. You can fix it by removing the wheels and pressing back the brake shields slightly.
However the noise will always return. It's a flawed design, and I had this same exact noise on my 135i, m235i, and F80 M3 |
08-18-2018, 08:17 AM | #307 | |
Rep 573
08-19-2018, 04:43 AM | #308 |
Rep 88
Do not assume the clicking noise is minor. Took my M2 in for the same issue and it was a busted strut that needed to be replaced. I was afraid it might be as I hit a really bad pothole a couple of weeks earlier and the steering was feeling a tad loose though it was hard to tell. The invoice is in my glove box, but will update later with the actual diagnosis. I do remember the price though $1321 parts and labor. Ouch!
terrywang94.00 |
