02-21-2020, 10:55 PM | #111 |
Rep 3,286
Drives: 2002 M5;2007 M Coupe;2020 M2C
My previous F80 M3 ZCP was my first experience with an adaptive suspension and I was quite disappointed. Maybe my car was not functioning correctly; maybe the 20 inch wheels are to blame. The car crashed across any road imperfections, even in the "comfort" suspension setting. I find the M2C passive suspension much better. My favorite passive suspension remains the one in my E39 M5; it is so well-balanced (the "small" 18 inch wheels help). The passive suspension in my Z4M coupe is much firmer but does fit the car perfectly.
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
CSBM52756.00 |
02-21-2020, 11:17 PM | #112 | |
Rep 1,049
MMMBRAP975.50 |
02-21-2020, 11:19 PM | #113 | |
Luxury at the redline :)
9108
Rep 7,563
I feel the same about not having a 14 inch penis.. I mean, who wants a dick so big that you pass out every time you get an erection because your heart can't keep with the blood demand. A small penis is a *good* thing.. I'm J/k |
cptobvious2531.50 |
02-21-2020, 11:51 PM | #114 | |
Remove Before Flight
6913
Rep 1,616
BWAHAHAHAAAAA!!! |
02-23-2020, 10:48 PM | #116 |
6913
Rep 1,616
02-24-2020, 07:27 AM | #117 |
Rep 3,323
Ignoring Poochie's endowment issues (more power to ya, of course), I had adaptive dampers on my 340i. It was a noticeable change on that car with the 19's it came with, less so on the 18's I was using for winter wheels. I came away from that car feeling that the sidewalls made more of a difference in ride quality than the adaptive suspension did.
02-24-2020, 07:58 AM | #118 | |
Rep 2,700
I really think BMW uses this tech more to improve ride quality than to improve performance.
02-24-2020, 08:14 AM | #119 |
2531
Rep 1,908
243Racing1447.50 cptobvious2531.50 |
02-24-2020, 08:21 AM | #120 |
9108
Rep 7,563
Whatever, I would take a couple inches off the top for a 911 Turbo..
02-24-2020, 12:27 PM | #121 |
Rep 18
02-24-2020, 12:32 PM | #122 | |
2531
Rep 1,908
///AVM |
02-24-2020, 08:44 PM | #124 |
Rep 843
Correct me if I'm wrong, but doesn't adaptive suspension also add quite a bit of weight?
02-24-2020, 08:59 PM | #125 | |
Rep 1,049
Suspension OEM Rear Adaptive Bumpstop = 0.12 lbs (each side) Suspension OEM Rear Adaptive Spring/Cup/Rubber Pads w/ Bumpstop = 6.80 lbs (each side) Suspension OEM Rear Adaptive Spring = 5.74 lbs (each side) Suspension OEM Rear Adaptive Strut/Top Mount/Bump Stop/Dust Shield = 6.28 lbs (each side) Suspension OEM Front Adaptive Full Strut/Spring Assembly = 13.6 lbs (each side) Suspension OEM Front Adaptive Top Mount = 3.0 lbs (each side) Suspension OEM Front Adaptive Spring = 3.64 lbs (each side) https://f80.bimmerpost.com/forums/sh....php?t=1077612 Don't know what the OEM non-adaptive equivalent is, so it's hard to tell. I would guess 20 or so pounds. That's just a guess though. Last edited by Conissah; 02-25-2020 at 08:13 AM.. |
MMMBRAP975.50 |
02-24-2020, 11:57 PM | #126 |
Rep 7,340
I'm pretty sure the weight difference is negligible. There aren't really any parts of it that could weigh all that much, maybe a couple small DC motors. The dampers are probably very similar other than one being electronically adjustable. The wiring may even already be present in the regular M2 based on how that works for other cars.
MMMBRAP975.50 |
02-26-2020, 04:59 AM | #129 |
Rep 422
02-26-2020, 07:33 AM | #131 |
2531
Rep 1,908
Ratcher
There are laws in place that vary by state and country regarding 'fender flares.' The requirement, where present, is dictated by how far the tires extend outward relative to the fender edge. My assumption is that the M2CS has larger tires and extend further out to/past fender edge than the M2C . . . although, it is very possible that even the 21' M2C will be required to have the fender flares? Regarding the picture you posted of the Audi with the very large plastic fender 'trim,' that is more a design aesthetic and fender protector (e.g., against rust) than a true fender 'flare' that is required to protect other cars on the road. Personally, the fender flare shown on the M2CS is not that troubling; hardly noticeable or aesthetically displeasing. Of course, others may a different opinion. ///AVM |
243Racing1447.50 |
02-26-2020, 08:11 AM | #132 | |
1448
Rep 1,414
