08-22-2021, 02:11 PM | #1 |
Rep 1,681
UPDATE: As of 11/2021, I have changed from the resonated equal length midpipe to the non resonated. You can find my thoughts on the change on pages 4 and 5 of this thread. I will link the video of the Remus Sport + Non Res Equal Length below this paragraph and the rest of the initial post pertains to the the original review of the non resonated equal length midpipe.
Remus Sport + NON Resonated Equal Length midpipe: ————————————————————————— ORIGINAL POST: Just wanted to post a quick review on the Remus Sport + AA Res EL Midpipe combo. I guess you could say this is on the "quieter" spectrum of combos but don't be fooled, this combo transforms the car but might not be enough for some members. Shout out to mike@x-ph.com, Cynthia, and his team,. The Remus Sport took roughly 3 months after the whole supplier fiasco and him and his team were very responsive to my emails and my indecisiveness to switch from the single mid pipe to the resonated. I also want to throw some "facts" out there before diving in: -I have had ASD disabled since pretty much picking up the car-I have a moonroof (if that affects in cabin sounds)-This is our only car and my wife does occasionally drive it so too loud of an exhaust was unfortunately out of the question. -DCT transmission-I park in an indoor community garage for both home and work Ok so first the appearance between stock and this combo is night and day. As you all know, we get rid of the ugly diaper and now I can finally appreciate the diffuser. It's astonishing how much of the diffuser is lost due to the diaper and I now feel I get my money's worth from it. Second, the tips are huge and truly makes the car look more aggressive looking from behind or from the side. I went with the 102mm CF option from Remus because I had dreamed of them ever since my OG M2 but never got the urge to splurge on an exhaust then. Now onto the sound. On start up, the cold start is more than livable. It definitely has a presence when turning on the car but you won't be setting off alarms. This for me is a huge plus especially with a 2021 model that (for now) is not tunable. Dies down after 30 seconds but if you're inside the car with windows up, you'll survive. Efficient mode has gotten a nice little buff but the missus also admits its not a huge change in volume but more in tone. Much deeper tone and I'd say maybe 10% increase in volume in this mode. There is no drone in efficient or flaps closed. Sport and Sport + is where you will notice the biggest difference. First, with flaps open there is now a grumbling sound while idling with the windows down and music off. This was not the case before. Very deep sound in all RPM's with WOT really screaming. Downshifts now have a nice sound where they were basically non existent on stock. There is the "VRRRAP" sound also when hitting the 6-7k RPM range which was also basically non existent on stock. Windows up I notice that I have to crank my music up a bit higher if I want to tune out the exhaust. But you can still easily have a convo or listen to music. Windows down is where you can really hear the exhaust sing. If you are looking for a setup that screams even with windows down, then the Remus Race is the option you are looking for. Onto droning… There is drone present at the 2.5-3k RPM range when accelerating with flaps open in sport/sport +. In efficient or with flaps closed there is absolutely no drone. The drone is mostly present when accelerating in lower speeds around town, not so much on the highway. So in the end this setup is civil when you need to be and rowdy when you want to be. I have tried burbles on and off for about a day each. Still unsure what I will choose as my default but for now I will say, the burbles can be annoying cruising around a neighborhood. They have significantly gotten louder and a bit longer. The day that I drove with them off though, I did find myself yearning for something after letting off the gas. Hopefully once a tune is available, I'll be able to customize a bit of burbles but that's an issue for the future. Overall I think this setup has done everything I wanted it to do. There is no rasp, a much deeper tone, high RPM's sound great now, and the backend looks a thousand times better. Hard to quantify these things but I guess I would say this setup is 30-40% louder than stock. The only thing I would say is that I do find myself maybe wishing it was a tad louder and with that, I may look into changing my resonated pipes for non resonated to compare. I showed some family and friends the setup and they can't see why I would want it louder but for several members here, I can see this setup not being enough. I may also try one of the controllers to set the exhaust flaps to always open and see if that satisfies my desire for a "little" more sound. Below is a sound clip comparing stock to my setup. After hearing different setups around my area I can only say, videos never do these setups justice. It is louder in person as has been the case with the other setups I have heard from other forum members. I will try my best to get sound clips of some fly-bys but due to the storm here in the NY/NJ area I didn't have time to find a good street to record. And as always, headphones are best to hear the difference
Current: ///M2C
G01 X3 xDrive30i Past: ///M2 997.1 Turbo ///M3 E92 Last edited by Nicname; 08-22-2021 at 02:40 PM.. |
12
aftercorbu404.50 CoffeeLife397.00 M-Pilot4861.50 iWayne103.50 Vulpe310.50 Navy Davy220.00 rdriggett130.50 Wolf_Zero37.50 Capt Canuck704.00 No_curebimmer645.00 inTgr8r2434.50 6speed_M25203.00 |
08-22-2021, 03:09 PM | #2 |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
Niceee. Glad you got it installed. I figured the sport+el would be a great combo. When the weather clears, have your wife go WOT and just drive around while you stand outside and listen. Once you hear it that way, pretty sure you will think its loud enough
-2021 M2C, HS, 6MT
-AST 5100, AP Racing 9660, BMW-788M, RF-GT4, BW-TA5R, APR GT 250 Wing & Front Splitter -TMS Diffuser, TMS F80 Skid Plate, HEX Armor PPF, CAN-Checked Data Logger, RaceBox -Recaro Pole Position , 2kBody Half Cage, Pinnacle Motorsports Half Cage (On order), CAE Shifter -Remus Race + BR EL Mid |
08-22-2021, 03:40 PM | #3 |
Rep 1,681
Very true. I had a buddy of mine rev it while I stood a few feet away and towards the high RPM's it made me wince a bit.
Current: ///M2C
G01 X3 xDrive30i Past: ///M2 997.1 Turbo ///M3 E92 |
08-22-2021, 04:41 PM | #4 |
Rep 3,660
Drives: 981 Cayman GTS
I no longer have my M2C but I had been waiting for someone to post sound clips of this combo. This is easily my favorite EL setup so far. I used to have Remus Sport + AA single mid and it sounded pretty good but this sounds even better IMO
08-22-2021, 05:13 PM | #6 |
Rep 1,681
Current: ///M2C
08-22-2021, 05:15 PM | #7 | |
Rep 638
Drives: M2C
I'm curious about how Remus sport compares to AA one. And then I know nocurebimmer paired up with Dinan. Haha so many options… |
Nicname354.00 |
08-22-2021, 07:33 PM | #8 |
Rep 1,681
Your video/breakdown is what pushed me to actually order the Sport + single combo first but then I changed to the equal length.
Current: ///M2C
08-22-2021, 09:03 PM | #10 | |
Rep 1,681
Yeah it definitely feels/sounds like a proper M car for daily driving. I have heard the Remus Race and non resonated in person and that was probably the nicest sounding setup I've heard but it is louder than what I think I'd want given my situation. If this was my weekend/second car I think I would've been fine with the Race and resonated midpipe.
Current: ///M2C
08-22-2021, 10:32 PM | #11 |
Rep 402
Drives: F87 M2C
Awesome. Finally hearing the setup I've been thinking of. Looking forward to the drive-bys and possible unresonated in the future. Luckily I have several months until I save enough for one.
Past: 2011 Acqua Minerale Blue Hyundai Genesis Coupe 3.8 Past: 2017 Alpine White 440i F32 Current: 2020 Long Beach Blue M2 Competition PC Build: 5950x/6900xt |
Nicname354.00 |
08-23-2021, 09:09 AM | #12 |
24463
Rep 191,414
Congrats OP and thank you for your patience
Nicname354.00 |
08-23-2021, 09:10 AM | #13 |
Rep 180
[IMG]https://thumbs.gfycat.com/BrownFrigh...restricted.gif[/IMG] [IMG]https://c.tenor.com/NGvISEO4iREAAAAM/web-spider-man.gif[/IMG]
__________
2020 A/W M2C, 6 M/T, Executive Package, Moonroof Mods: 20% tints, Full PPF and Ceramic Pro, IND A/W reflectors, Remus Sport, AA EL (non-res), BMC Filters, BM clutch stop, ///M tire caps |
08-23-2021, 09:11 AM | #14 | |
Rep 1,681
I'm dying over here
Current: ///M2C
08-23-2021, 09:14 AM | #15 | ||
Rep 180
__________
Nicname354.00 |
08-24-2021, 04:30 PM | #19 |
Rep 1,681
I'm going to get some highway driving done tomorrow and I'll play close attention. As you can imagine I spent the first few days just gunning it and being infatuated with the new sounds.
Current: ///M2C
ESB1196.50 |
08-25-2021, 08:16 AM | #20 | |
Rep 35
I don't blame you, sounds flipping amazing! I am hoping for good news as I imagine if it did drone, you would've noticed rather quickly. My resonated EL should be coming in a few weeks and I am still undecided on the exhaust. |
Nicname354.00 |
08-25-2021, 09:05 AM | #21 | ||
Rep 1,681
Not what you wanted but this is some city driving under 4K rpm with only my driver window slightly cracked open. Moonroof is closed and I'm in sport + Street driving under 4k RPM Remus Sport + AA Res Equal length midpipe
Current: ///M2C
