M2 Technical Topics > Suspension | Brakes | Chassis > SPL Lower Control Arms for Camber and Track Width Adjustment
      07-01-2021, 11:07 AM   #1
FaRKle!
Most people use camber plates to gain negative camber on their BMWs, but you can also increase negative camber using an adjustable length wishbone/lower control arm and making it longer than the OE arms.
Other benefits of lengthening the wishbone/LCA are increasing caster, and increasing the track width. The caster increase helps maintain higher negative camber when the wheels are turned, and increased track width reduces roll on that axle. For reference, BMW increased the front track width on G8x by 1.5" over F8x.
Using these arms with the stock springs/struts I was able to achieve -2.3deg of negative camber at max extension, which produced about 8deg of caster, and widened the track width by 1" (and the rear by only 0.2").
Here's an overview on these arms, their features, and how they work.
Originally Posted by Index
0:00 Intro
0:14 SPL Arm Layout
1:17 Arm Length Adjustment
3:22 Roll Center Correction
4:11 Assembly Mock Up
5:40 Headlight Leveling Sensor
6:59 SPL Arm vs Camber Plates?
7:41 My Alignment and Conclusion
Appreciate 5
x233284.00
bentom2335.50
mcvaughan704.00
Doublej40.00
      06-13-2023, 04:12 PM   #2
E90convert
Drives: F87 M2 DCT, F15 X5
Hi there and thanks for sharing. I’m looking to increase camber on my stock suspension for track use. Would you recommend these over camber plates? Any long term feedback? The unsealed monoball is troublesome for me as well since I drive in the winter snow and salt.
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport
Sold in 2023 '12 F30 335i 8AT Sport Line
Sold in 2020 '08 E92 335xi 6MT
Sold in 2016 '08 E90 335i 6MT - FBO
      06-13-2023, 05:16 PM   #3
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
If you need camber, use camber plates, CSR does not use its arms to increase track width or negative camber, it uses them so that the 10.5 rims with 41mm of spacer do not protrude.
The spl arms look like parts of the transformer....
      06-13-2023, 05:36 PM   #4
E90convert
Thanks for sharing. How does the CSR increase camber?
      06-14-2023, 01:35 AM   #5
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
With camber plates, they use eye mount dampers in this way those plates allow more inclination than any other of aftermarket.
