01-17-2020, 09:00 AM | #1 |
Wheelsucker
199
Rep 1,280
Aftermarket rotors
My drilled front rotors are starting to crack and wanted to replace them with slotted rotors when they go. Does anyone make slotted rotors to work with OEM non competition calipers?
01-17-2020, 10:12 AM | #2 |
Rep 1,262
01-17-2020, 10:40 AM | #4 |
Rep 4,510
Heres 2 more
Alcon https://f80.bimmerpost.com/forums/sh....php?t=1474110 Girodisc + others in this thread https://f87.bimmerpost.com/forums/sh...php?p=23104206
Current '22 X3M LCI.. |
01-17-2020, 03:09 PM | #6 |
Rep 650
I have been using Stoptech front rotors, they are 2 piece, lighter, push more air, last longer and are about the same price as OEM. One strange benefit is that when I leave on my PFC08 pads they make a lot less noise than factory rotors.
01-17-2020, 05:08 PM | #8 |
1448
Rep 1,414
Where are you getting that price? OE is around $500-$600/axle. The stop techs are $600 each
01-17-2020, 07:32 PM | #10 |
Rep 350
It is if you track and are getting a lot of heat into the rotor. They are hairline cracks and a common issue with drilled rotors. Slotted rotors are not prone to the same issues as drilled and are preferred for track use. Manufacturers just use drilled because they look cool.
01-18-2020, 06:39 AM | #12 |
Rep 650
I should have clarified :Once you buy the Stoptech ( about $525 each) you only replace the rings versus OEM....so after the initial purchase it’s the same. I also got my Stoptech during a vendor sale. Finally, I found my Stoptech lasted 50% longer ( with heavy track use) so they may actually be cheaper overall. I have gone through 2 sets of factory rotors and on my second set of Stoptech.
01-18-2020, 08:09 AM | #13 | |
1448
Rep 1,414
01-18-2020, 08:51 AM | #14 |
Wheelsucker
199
Rep 1,280
07-24-2020, 01:39 PM | #15 |
Rep 309
Drives: 2018 M2 LBB - 6MT
Bumping this thread. I see that Girodisc has the following items for the OG:
Fronts: https://www.girodisc.com/Girodisc-Fr...M4_p_6816.html Rears: https://www.girodisc.com/Girodisc-Re...M4_p_6846.html However, I can't find their replacement rings anywhere, despite the description saying: "Once the Girodisc system is in place, simply replace the cast iron rotor when needed." Does anyone know if there are F8X-specific replacement rings available? |
08-04-2020, 02:56 PM | #16 | |
3812
Rep 54,307
Drives: F80 M3
https://www.hpashop.com/Stoptech-Aer...?categoryId=-1 |
08-10-2020, 07:10 PM | #17 | |
1448
Rep 1,414
08-10-2020, 08:15 PM | #18 | |
Rep 427
What isn’t clear to me is whether the Girodisc or Stoptech rotors actually cool better and/or last longer than OE. Either or both could make the initial upfront cost worth it for me. Quieter is a nice side benefit, but a bit hard to justify the added cost on noise alone. On OE rotors, I was able to get 4 sets of RSL29s worth of use out of the front and rear rotors before the heat checking (front only) and wear were too bad for continued use. Anyone have enough time on either of these aftermarket two piece rotors to compare on wear? |
08-11-2020, 09:39 AM | #19 | |
1448
Rep 1,414
The only thing I can think of is that people who are spending big $ on M2 brakes are doing BBKs, and that explains the scarcity and ridiculous cost of aftermarket rotors. |
bentom2335.50 |
08-11-2020, 10:35 AM | #20 |
Rep 350
That is probably the case, the standard brakes on the M2 are very capable once pads are swapped and fluid is changed. I am definitely able to brake later and harder than many other cars when I'm out on track and I don't think experience/skill is the main difference. The 4 + 2 piston calipers and 2-piece rotors are decent, the only issue really is poor cooling.
